Aura General Photos |
· · · 2006 - NYIAS Photos 51 photos 1 comments |
· · · 2007 - AURA XE 50 photos 6 comments |
· · · AURA - Member Photos 556 photos 171 comments |
· · · 2006 - NYIAS Photos 51 photos 1 comments | ||||||||
Thread Tools | Display Modes |
#1 | ||||
![]() Join Date: Jun 2005
2008 Aura. Picked it up w/ 19 on the clock in Feb of 2008. Been rollin' hard ever since. Only issue is I can get the
TMPS to resync and display for the right positions.
#2 | ||||
![]() Join Date: Feb 2000
Good report.
Which engine? What maintenance did you do?
#3 | ||||
You have gone through the setup mode and lower air pressure in each tire clockwise from drivers front? And it wont resync?
... Phaeton Driver says "Check your oil every week, the V6's don't notify you when they are low" 07 Aura XR 20K+ miles 1928 Ford/Dodge Streetrod
#4 | ||||
I haven't done any engine stuff yet (other than oil changes). Its all highway miles, so I'm gonna hold off on Trans fluid til 100k. Not sure what else I need to worry about. I also did the brakes at 45 k, and looks like I'll switch out the brakes and rotors once I hit 80k
As for the TPMS, I followed the directions from the manual, even brought down my front tire by about 15 or 16 psi, and still doesn't recognize it.
#5 | |||||
![]() I had to take them down to about 10 to 15 PSI before the horn sounded. It is advisable to have a compressor handy so you can inflate them after deflating. Another reason NOT to use Nitrogen ... Phaeton Driver says "Check your oil every week, the V6's don't notify you when they are low" 07 Aura XR 20K+ miles 1928 Ford/Dodge Streetrod
#6 | ||||
![]() Join Date: Aug 2009
I had this issue when i was resyncing my TPMS as well. I was going about it the wrong way though i think.
I read the manual and interperted it to say that you keep letting air out until the horn sounds. But when i started doing that the horn never sounded....that is until i stopped... as i moved on to the next three tires i relized you only have to let air out for about 3-5 seconds, then when you stop letting the air out the horn will honk. So the trigger, i found to be anyway, is when you stop letting the air out the system then tells you its synced with that tire and you can move on. I hope this helps out. don't want all you guys deflating all of your tires!
| Thread Tools | |
| Display Modes | |
| About to hit my first 1k miles!!!! | chillin05VUE | Vue General | 18 | 10-04-2008 02:39 PM |
| Just hit 1K miles. Yay! | STRNGUY | Aura General | 1 | 11-21-2007 02:17 PM |
| Just hit 100,000 miles | VTHokie00SL2 | S-Series General | 14 | 11-14-2006 02:45 AM |
| Just hit 100,000 Miles! | CodisSL2 | General Saturn Discussion | 21 | 02-17-2003 11:16 AM |
| Just hit 100k miles! | VTHokie00SL2 | General Saturn Discussion | 6 | 07-27-2001 12:19 PM |
