what's new (beta) - classifieds - forums - links - photos
Go Back   SaturnFans Forums > Models > Saturn Vue > Vue Tech
Register Blogs FAQ Members List Calendar Chat Room Search Today's Posts Mark Forums Read
Old 11-05-2009, 01:36 PM   #1
XRL
XRL is on a distinguished road
XRL's Avatar
2004 VUE Red Line
Default Another exciting round of "guess what that noise is"
I get a noise in my passenger front wheel well ONLY. It happens most often when the passenger wheel is going over a bump, and the driver wheel is not. If both wheels go over a bump (speed bump for instance) no noise, if the driver wheel goes over a bump only, no noise. It almost sounds like the noise something would make when its pivoting.
The springs, shocks, and struts are all old, I need to replace these soon, but haven't given me any sort of issues as of yet. Strut mounts were replaced probably 10 months ago or ~ 10k miles. Passenger side wheels are very very slightly out of round, but not anything that should be noticeable.
Do you guys think its the strut mount, again? It's definitely a different noise than it made before. Are there sway bar end links in the front? I've always felt that my Vue has way too much body roll, perhaps this is part of it?
I Look forward to hearing your opinons. Thanks guys.
'04 Vue Redline AWD - Silver Nickel Metallic
Mods: Tinted tails & corners - Stealth Amp and Sub system - In-Dash Navigation - Nitto INVO 245/50/18s - Custom HID Projectors
Add to XRL's Reputation
XRL is online now   Reply With Quote
Old 11-05-2009, 03:33 PM   #2
VUEmaniac
VUEmaniac is on a distinguished road
Default Re: Another exciting round of "guess what that noise is"
Based on what I've read, my guess is one of these:
strut mount <--most likely
strut
sway bar endlink
worn brake caliper slide bushing
Add to VUEmaniac's Reputation
Rate the quality of this post and help VUEmaniac reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
VUEmaniac is offline   Reply With Quote
Old 11-05-2009, 04:07 PM   #3
djhhjd
djhhjd is on a distinguished road
djhhjd's Avatar
2009 Outlook XR
What is it that goes bad on a strut mount? Is it rubber or plastic? Is it possible to change the strut mount without taking out the strut and spring (compress the spring) and leaving the strut bolted up on the bottom thus avoiding a front end alignment? Providing the strut is still good. Maybe this is just grandious thinking on my part.
I've been "SATURNED"
Add to djhhjd's Reputation
Rate the quality of this post and help djhhjd reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
djhhjd is offline   Reply With Quote
Old 11-05-2009, 05:51 PM   #4
newbievueowner
newbievueowner is on a distinguished road
If you could get a spring compressor in there then I guess you could remove the strut mount without having to remove the bolt in the bottom (maybe). It may be a real bugger getting the center nut off the shock though as these are ususally rusted pretty good. If rusted, it will just cause the shock rod to spin.
Add to newbievueowner's Reputation
Rate the quality of this post and help newbievueowner reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
newbievueowner is offline   Reply With Quote
Old 11-11-2009, 07:02 PM   #5
BryanF
BryanF is on a distinguished road
Ever figure out what it was? I was having pretty much the exact same symptoms you described and I ended up having a bad sway bar endlink.
'05 VUE AWD w/Honda 3.5L V6
Add to BryanF's Reputation
Rate the quality of this post and help BryanF reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
BryanF is offline   Reply With Quote
Old 11-11-2009, 11:31 PM   #6
XRL
XRL's Avatar
2004 VUE Red Line
I haven't even started to look at it. But I'm thinking it's probably the end link because the mounts are somewhat new. I'll probably go ahead and take care of that when I install some new springs.
Old 11-12-2009, 10:34 AM   #7
RobPMI
RobPMI is on a distinguished road
Upper strut mount on the drivers side is being replaced on my 06 Vue Red Line at 52K miles (along with the torque converter). Quite possibly the same problem you are experiencing, symptoms are the same on my Vue.
Add to RobPMI's Reputation
Rate the quality of this post and help RobPMI reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RobPMI is offline   Reply With Quote
40-55mph Droning noise, car set on "vibrate" rayzur9 Vue Tech 5 10-12-2009 03:46 PM
"Exciting Times" Why dealerships closing melmar1999 General Saturn Discussion 17 03-20-2009 12:51 PM
2000 SL1 w/ Auto Trans - "Noise" and White Smoke jonsoini S-Series General 0 05-11-2005 11:58 AM
Another round of "will it fit?!?!" silverblueL200 L-Series General 17 11-04-2003 11:30 PM
Update on "Can you guess what I'm about to do?" amazinghl Mods and Performance 22 06-12-2003 06:23 PM
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
