what's new (beta) - classifieds - forums - links - photos
Go Back   SaturnFans Forums > Models > Saturn Vue > 2008 Vue
Register Blogs FAQ Members List Calendar Chat Room Search Today's Posts Mark Forums Read
Old 11-05-2009, 01:13 AM   #1
rwfan99
rwfan99 is on a distinguished road
rwfan99's Avatar
2008 VUE 2.4L
2008 Astra XE
Default Dramatic loss in power/MPG
I took my 08 VUE XE (4cyl.) Into the dealership because I've noticed dramatic power loss and loss in fuel economy (4-5mpg decrease). Dealership said no codes came up and in their opinion, when test driving my VUE and a new one on the lot, didn't "feel" a problem. I drive my VUE 100 miles daily and so I know when it's not driving correctly. Wondering what could be the problem. I've also noticed the engine sounds like it is revving up too much and you can hear under the rear seats (muffler or cat. conv. perphaps?). It also seems sluggish and hesitates when accelerating. On the highway, it's constantly dropping into 3rd to stay at 75MPH with or without cruise on. Anyway, any insight or advice is helpful.
I mentioned to the dealership two things that happened recently that I could think might have caused this.
1. I ran it out of gas (yes, I should have known better)
2. I just replaced the tires (one size taller than OEM)
Dealership said my gear ratio, and ECU are going to respond different with the new tire size and perhaps causing what I'm noticing, but I find it hard to believe my MPG and power would be decreased that much. Also, I was informed that the VUE does not have a fuel filter, since I had asked if that was clogged due to running it empty.
I noticed this happening after having the oil/air/tires changed both within a day of each other.
I am at a loss. This post is all over the place but I'm getting really annoyed that my VUE is acting this way, and is proving to be somewhat dangerous on the Interstate with no power.
Add to rwfan99's Reputation
Rate the quality of this post and help rwfan99 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rwfan99 is offline   Reply With Quote
Old 11-05-2009, 11:35 AM   #2
twosaturns
twosaturns's Avatar
2004 VUE 2.2L
Default Re: Dramatic loss in power/MPG
you need to do the math on how much % bigger your tires are now. the MPH and MPG will both show lower than actual. you effectively raised your final drive ratio which would also cause it to downshift where it didn't used to.
another contributing factor could be a switch to winter fuel, which, foe me, drops economy 2-3 mpgs.
do a search on 'miata tire calculator' where you could plug in your sizes and it'll give you a % difference.
2004 VUE sport plus II pkg chili pepper red 71K
Add to twosaturns's Reputation
Rate the quality of this post and help twosaturns reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
twosaturns is offline   Reply With Quote
Old 11-06-2009, 09:28 AM   #3
Speakrz
Speakrz is on a distinguished road
Speakrz's Avatar
2008 VUE Red Line
Try this site for your tire calcs, it will tell you what your speed has changed to w/ the larger diameter tires size. powerdog.com/tiresize.cgi
You might want to get you exhaust system checked - maybe you have defective cats, resonator or muffler... the dealer should be able to help you with that or take it to a good muffler shop close to your location.
2008 Saturn Vue Redline
1996 Chevrolet Impala SS
Add to Speakrz's Reputation
Rate the quality of this post and help Speakrz reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Speakrz is offline   Reply With Quote
Old 11-06-2009, 10:14 AM   #4
Mic__
Mic__ is on a distinguished road
Mic__'s Avatar
HOw's is your air filter....those are natorious to kill mileage as they clog.
Also, you mpg figures need to be adjusted by the % change of tire rolling distance (i.e circumfirance)
2004 ION
2009 VUE XR
Add to Mic__'s Reputation
Rate the quality of this post and help Mic__ reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Mic__ is offline   Reply With Quote
Old 11-06-2009, 03:49 PM   #5
rwfan99
rwfan99's Avatar
2008 VUE 2.4L
2008 Astra XE
Thanks for the info guys. I will do my research on the tire size affecting performance. It was expected when I decided to change the tire diameter, I wasn't expecting the hesitation I was experiencing. That said, I took it to the dealer this morning and had them flush the injectors/fuel system. Driving back to work it was like night and day, I have immediately noticed a difference and feels like it used to. The true test will be this afternoon when I go home.
Old 11-07-2009, 12:30 PM   #6
ski2moro
ski2moro is on a distinguished road
never mind
Add to ski2moro's Reputation
Rate the quality of this post and help ski2moro reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ski2moro is offline   Reply With Quote
a few problems (mpg,oil loss,temp) 93SC2'in S-Series Tech 9 01-21-2009 10:51 PM
loss of mpg and a little hesitation Charged97 S-Series Tech 7 10-06-2006 11:42 AM
Power loss - WHY????? 97sleeper S-Series Tech 8 06-23-2006 08:52 PM
Loss of power hitmenqb Vue General 3 06-08-2005 01:38 AM
Turbo Hy-dramatic lubers Old Classifieds 0 04-26-2003 08:47 AM
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
