what's new (beta) - classifieds - forums - links - photos
Go Back   SaturnFans Forums > Models > Saturn S-Series > S-Series Tech
Register Blogs FAQ Members List Calendar Chat Room Search Today's Posts Mark Forums Read
Old 11-03-2009, 09:49 PM   #1
mrriden
mrriden is on a distinguished road
mrriden's Avatar
2002 SL1
Default SES illuminated
My 2002 SC2 with 68,700miles has just lit the SES (not the wrench) Light. Car is running OK. Do I
1) Check the OBDII for codes?
2)Reset it (how)?
3) Perform a 65,000 mile maintenance (what needs attention / inspection)?
4) Some of the above
5)None of the above
6)Other
'02 SC2 'The Schnoot'
'94 SL2 'Beauty' (R.I.P.)
'02 SL1 'Silver Lining'
Add to mrriden's Reputation
Rate the quality of this post and help mrriden reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mrriden is offline   Reply With Quote
Old 11-03-2009, 09:59 PM   #2
2NDSOUT
2NDSOUT will become famous soon enough
2NDSOUT's Avatar
1997 SW2
Default Re: SES illuminated
2)Reset it (how)?
5)None of the above
6)Other
1) Get the codes read at Autozone for free, post them here so we can figure out what code you have.
2) Pull the 30 Amp Ignition Fuse in the UHJB or pull the Negative Battery Cable for 30 seconds and reinstall the Battery Cable.
3) Check your owner's manual, there is a maintenance schedule there. It would be a good reccommended thing to to a 65,000 mile check, esp. if it's been a while since you change vital fluids. Coolant, brakes, Power Steering Fluid, Air Filter, PCV Valve, etc...
So...yes; do ALL of the above.
Bryan
94 SL2 137K Miles
97 SW2 181K Miles
Garaged
94 SL2 HCE, "Pearl"
Rebuild
94 SC1 340,501 Miles
Original Engine/Auto Transmission
02/97-10/08
Then
92 SL1
05 VUE
91 SC
Add to 2NDSOUT's Reputation
Old 11-03-2009, 10:10 PM   #3
01SuperCoupe
01SuperCoupe is on a distinguished road
2009 Astra XE
I'm guessing that your in the States, if you are, and you have access to an AutoZone store, run in and get them to read your codes. After you get them, post 'em here and one or more of the resident Saturn "brain-e-acks" will likely chime in to save you some serious money.
As far as resetting the light yourself, you can do it by pulling the "PCM B" fuse from the under-hood fuse box for a minute or two. (with the key off, of course) If you do in fact have a genuine issue the light will return in short order.
When in stressful situations look to man's best friend for the best advice: "If you can't eat it and you can't play with it, just pee on it and walk away."
Add to 01SuperCoupe's Reputation
Rate the quality of this post and help 01SuperCoupe reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
01SuperCoupe is offline   Reply With Quote
Old 11-03-2009, 10:20 PM   #4
mrriden
mrriden's Avatar
2002 SL1
Thank you guys!
AutoZone is on my commute so will have the OBDII checked for stored codes on my way home tomorrow and post any found here.
I'll hold off on pulling the fuse in the under hood panel 'till after that.
I've always looked after the vital car juices changing them myself (oils and brake fluid) or having a shop flush (coolant) at regular intervals. Plugs, wires, hoses and belts are also self maintained.
See ya tomorrow
Old 11-03-2009, 11:00 PM   #5
adventureoflink
adventureoflink is on a distinguished road
adventureoflink's Avatar
Actually, this time, SCREW the shop flushing your coolant.
If you haven't done so, drain out that old coolant, flush your system out with electrosol and distilled water, then refill your system with 100% of either the green or yellow stuff, followed by a gallon of distilled water.
By all means, DO NOT let the coolant go 5 years or ESPECIALLY 150,000 miles, as it's dex-cool. it ruins motors long before that 150k point (and fwiw I've only seen ONE G.M. vehicle go past 150k miles within five years, and even still that was a 2005 chevy uplander and I rode in it in 2008, as part of someone's fleet).
'97 Saturn SL2.
DOB: 3/17/97
Date Obtained: 5/30/07
Status: Alive and Well
'95 GMC Vandura 3500.
DOB: 6/95
Date obtained: 7/10/09
Engine: 6.5L Diesel
Status: Dead
adventureoflink is online now   Reply With Quote
Old 11-04-2009, 09:55 PM   #6
mrriden
mrriden's Avatar
2002 SL1
the Autozone code printout is a bit cryptic in that it really doesn't seem to give the codes. for what it's worth here is the printout in it's entirety:
Definition
BBEVAP (evaporative emission system) small leak/no
BBflow condition
Explanation
BBthe evaporative emission system is monitored for
BBit's ability to hold vacuum.
Probable cause
BB1.- Defective or loose fuel cap
BB2.- EVAP canister or hose cracked-not connected
BB3.- Purge or vent solenoid defective
BB4.- Vacuum leak at engine
So no codes were given to me (makes me want to get my own scanner) bit it seems there is a leak somewhere in the EVAP plumbing. I do have a vacuum gauge and a Mighty Vac but not sure where to start. Cap seemed tight to me and I have not pulled the fuse to reset the lamp yet.
Old 11-05-2009, 12:24 PM   #7
alordofchaos is on a distinguished road
You can ask the guy at the AutoZone for the actual codes (they'll have to scan your car again). Have pen and paper ready to write it down.
A dirty air filter or clogged air intake can cause one of the evap codes. It's worth checking (and it's free to check; $5 or so to replace)
...Wait, what, I actually won that eBay auction?
Guess I now (12/08) own a 1998 SL2, silver 5 spd :p
Odometer increments, but not illuminated tommsaturn S-Series Tech 7 09-25-2008 11:44 AM
Illuminated Door Sills?? ecbahs Aura General 5 05-03-2008 10:05 AM
SES light illuminated (without wrench) adamsaulnier S-Series Tech 14 09-20-2007 03:53 PM
Instrument panel illuminated with DRL? VinceL Outlook General 4 06-27-2007 09:59 PM
Illuminated Power switches dgrzybow Ion General 13 10-19-2006 11:17 PM
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
