what's new (beta) - classifieds - forums - links - photos
Go Back   SaturnFans Forums > Models > Saturn S-Series > S-Series General
Register Blogs FAQ Members List Calendar Chat Room Search Today's Posts Mark Forums Read
Old 11-03-2009, 09:31 PM   #1
grelms
grelms is on a distinguished road
Default Starter
I know I need a new starter. Cash flow is low. What starters can I get from my wrecking yard. What years on a 99SC2 will work. SC2, SL2 or what. I'm sure it is better to get a new one. But I can get one from an 02 w/only 20k on it. What years can I use.
Add to grelms's Reputation
Rate the quality of this post and help grelms reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
grelms is offline   Reply With Quote
Old 11-03-2009, 09:42 PM   #2
westwind999
westwind999 is on a distinguished road
1999 SW1
Default Re: Starter
I think they're pretty much all the same. Check the different model years on RockAuto and see if the part numbers are the same. It'll also give you an idea of the replacement price. The starter is a bit of a bear to swap. Only a couple bolts but it's tricky to get the top bolt back in.
Old 11-05-2009, 01:31 PM   #3
fetchitfido is on a distinguished road
1993 SL2
1997 SC1
Default Re: Starter
Just find the newest/lowest mileage S-Series and yank 'er off. Though...I think something changed in the flyweel/flexplate for 3rd gen....try to stay 1st/2nd gen or 3rd gen to be safe.
1993 SL2m 161k
MP7 transmission swapped to MP3
8lb Fidenza flywheel and A/C+P/S delete
H&R Sport Springs
AEM CAI & '92 Header
Old 11-05-2009, 03:36 PM   #4
hholbein
hholbein is on a distinguished road
1997 SW2
1997
Default Re: Starter
I had good luck with the folks at DB Electrical. $50, and is working well. No quibble warranty. Certainly better than paying $25 for a ???? JY unit. They're in TN, so shipping should be pretty quick.
http://www.db-starter-alternator.com/
Add to hholbein's Reputation
starter scort_beater S-Series Tech 10 12-08-2005 07:04 PM
'95 Starter gmschrank Old Classifieds 1 09-16-2005 11:58 PM
starter help iced_theater S-Series Tech 3 06-26-2005 12:55 AM
FS: starter BlackBirdRacing Old Classifieds 0 09-22-2004 11:33 AM
Starter is Different MSGJVH Miscellaneous Tech 3 11-25-2002 11:13 PM
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
