#1 | ||||
![]() Join Date: Nov 2009
Greetings,
Any ideas would be appreciated. 2001 SC2 87,000 miles problem - occasional poor performance seems to "gag" for air or fuel fix: wiggle the connector on the temp sensor that is near the air cleaner -this sensor is in front of the air cleaner on side of the plastic air duct. fix lasts for about 1 hr of running time replaced : the temp sensor and also the connector that clips onto it. sometimes runs great, other times "gags" seems to run great for about first 30 seconds upon start up check engine light permanently on mpg down about 3 mpg Anyone heard of a pattern of problems with this temp sensor? thanks for any help
#2 | ||||
![]() ![]() Join Date: Feb 2000
Location: Professional Driver on a Closed Course: Do Not Attempt.
if the "service engine soon" light is on - get the code read
... eRic 02sc2 fka eRic 96sc2 Detroit SCCA Solo 2001,2002 1st DSP Waterford Hills 2007 Fun Run 1st Detroit SCCA 2008 Triathalon 1st PF Detroit SCCA Solo 2009 ??? ST Crutchfield: pkeqe-6j8e3-d2qqe
#3 | ||||
Hi
Thanks for response code was a lean cylinder with my cheap code reader at shop they said there were many codes in the memory - they would clear them all and see what codes appeared from a fresh start if I wanted to have them do it but I am trying to avoid the cost since overall I can get by my original post above was hoping for a commonly known fix if this were a common SC2 issue.
#4 | ||||
That's not a code, that's a description. The code(s) will be five characters, a letter followed by four digits, probably beginning with P0. Get the code(s) and report them here.
| Thread Tools | |
| Display Modes | |
| 2001 L200 fuel pump | saluki | L-Series Tech | 5 | 02-07-2009 07:43 PM |
| 2001 SC2 no start/fuel problem - solution | 94sl2guy | S-Series Tech | 0 | 11-05-2008 12:25 PM |
| 94 SC2 -- Replace air-dam or purchase 95 SC2 Bumper | wscreate | S-Series Tech | 5 | 05-11-2007 02:22 PM |
| Cold Air Intake on my 2001 SC2 and taking hood liner out | atmalan | S-Series General | 4 | 03-30-2005 05:03 AM |
| 1994 SC2 vs. 2001/2002 SC2 | 94sc293sl1 | S-Series General | 24 | 01-23-2003 02:08 AM |
