what's new (beta) - classifieds - forums - links - photos
Go Back   SaturnFans Forums > Models > Saturn Ion > Ion General
Register Blogs FAQ Members List Calendar Chat Room Search Today's Posts Mark Forums Read
Old 11-03-2009, 03:10 PM   #1
cfg83
cfg83 is on a distinguished road
cfg83's Avatar
Question Ion-Centric repair list?
Hello -
I know my S-Series, but I don't know Ions. I am watching the classifieds for Ions and doing research on repairs that are Ion-specific (all cars have something you have to watch out for). I did some searching and found these :
- Ignition switch
- Control Arm Bushing
Is there a list of other stuff I should watch out for?
Thank You,
CarloSW2
Add to cfg83's Reputation
Rate the quality of this post and help cfg83 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cfg83 is offline   Reply With Quote
Old 11-03-2009, 03:21 PM   #2
SaturnIONSLVUE
SaturnIONSLVUE is on a distinguished road
2007 ION-2 Sedan
Default Re: Ion-Centric repair list?
Ignition switch problem is for pre-2007 models.
The 2007 ones have the fat key which does not have the probelm.
Also the door/window weather strips, need to be lubed, with dielectric grease.
Add to SaturnIONSLVUE's Reputation
Rate the quality of this post and help SaturnIONSLVUE reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SaturnIONSLVUE is offline   Reply With Quote
Old 11-03-2009, 05:11 PM   #3
plato
plato is on a distinguished road
2005 ION-2 Sedan
trunk lid scratching the top of the bumper
Add to plato's Reputation
Rate the quality of this post and help plato reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
plato is offline   Reply With Quote
Old 11-03-2009, 07:02 PM   #4
cfg83
cfg83's Avatar
Hello -
Thank you! I am cross-referencing with other threads I find in order to make this thread useful to others :
Considering used Ion - things to watch for?
http://www.saturnfans.com/forums/sho...d.php?t=128131
Maintenance questions
http://www.saturnfans.com/forums/sho...d.php?t=135504
CarloSW2
Old 11-04-2009, 08:40 AM   #5
Citation84
Citation84 will become famous soon enough
Citation84's Avatar
2005 ION-1 Sedan
Early run 2.2s had an timing chain oiling problem. Affected the L Series more than the ION, I think. Someone can elaborate, but it causes the engine to seize up when it causes the chain to fail.
05s still have the ignition and bushing problems, but shared over 800 03-04 improvements over the 03-04 with the then new 05 Cobalt.
Add to Citation84's Reputation
Rate the quality of this post and help Citation84 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Citation84 is offline   Reply With Quote
Old 11-04-2009, 02:54 PM   #6
cfg83
cfg83's Avatar
Hello -
The one I am interested in is a 2007, so many of the big problems look like they have been solved. Thanks to you guys, I know to look at the control arm bushing to see if it's "squished". The only big $ repair seems to be the steering column (electric motor overheat), but there are ways around that also.
CarloSW2
Old 11-05-2009, 08:36 AM   #7
Citation84
Citation84's Avatar
2005 ION-1 Sedan
Hope you get it. Be sure to post pictures.
Old 11-10-2009, 03:46 PM   #8
cfg83
cfg83's Avatar
Hello -
This is just an update to the list :
- Ignition switch : Repairable or bypassable. You don't need to stay OEM. Should be non-issue for "fat key" 2007 model.
- Control Arm Bushing : Every 20+K miles. There may be an aftermarket option. However, it is hard to know if this would last any longer than the OEM, and it costs bucko bucks ($121 for ONE bushing ) :
http://www.jbodyperformance.com/new/...catName=JP0925
- Power Steering Electric Motor : Maybe maintainable with motor swapping and/or cleaning.
- Door/Window weather strip Maintenance : Cleaning with dialectric grease.
- Trunk lid scratching the top of the bumper : Fixable with smartly placed moulding and/or rubber grommets.
- Intermediate Steering Shaft : This one's a bear (to me). It seems to be happening in *lots* of GM drivetrains, not just Delta platforms. Haven't found anyone who has solved it for the long term.
CarloSW2
Old 11-10-2009, 11:19 PM   #9
SaturnIONSLVUE
2007 ION-2 Sedan
steering electric motor overheat becase of low Tire PSI. make sure your tire PSI is never low or your steering motor will overheat since it is doing more work.
Old 11-11-2009, 12:17 AM   #10
Ltech20
Ltech20 is on a distinguished road
Ions are pretty fail safe. Don't expect much to go wrong other than control arm bushings/ stabalizer links/ sway bar bushings.
Add to Ltech20's Reputation
Rate the quality of this post and help Ltech20 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Ltech20 is offline   Reply With Quote
Old 11-11-2009, 08:03 AM   #11
Citation84
Citation84's Avatar
2005 ION-1 Sedan
Is the problem with the bushings just that they make noise? Do they affect safety, alignment, etc
If it's just that they're noisy with no affect on anything else, the next time they go, I will just let em be noisy.
help me with my DIY repair/maintenance list? wednesday S-Series General 37 05-06-2009 03:30 PM
GM PM list for 07 Ion? jimsz Ion General 8 03-03-2009 12:36 PM
Wheel Hub Centric Rings? Gawd Ion General 6 11-20-2006 10:33 AM
List of '03 ION 3 Problems - Can you help? Jeremy4152 Ion General 4 11-19-2005 07:41 PM
ION features list lewis2 Ion General 0 06-19-2002 07:29 AM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
