what's new (beta) - classifieds - forums - links - photos
Go Back   SaturnFans Forums > Models > Saturn Aura > Aura General
Register Blogs FAQ Members List Calendar Chat Room Search Today's Posts Mark Forums Read
Aura General Photos
by AuraDrvr89
AURA - Member Photos
556 photos
171 comments
by Catbert
556 photos
171 comments
by dangerous1
556 photos
171 comments
by AuraDrvr89
556 photos
171 comments
Old 11-03-2009, 12:45 AM   #1
Roos85
Roos85 is on a distinguished road
2007 AURA XR
Default XM Radio
I have the proper radio and my radio has a CAT button. Does anyone know what else I need to do to get sattelite radio hooked up? Someone said an XM module, if this is so, where do I get it?
Add to Roos85's Reputation
Rate the quality of this post and help Roos85 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Roos85 is offline   Reply With Quote
Old 11-03-2009, 12:57 AM   #2
gregh2000
gregh2000 has a spectacular aura aboutgregh2000 has a spectacular aura about
2007 AURA XR
Default Re: XM Radio
To get XM you would need the proper head unit as you said you already have it then that is a first step. Then you need the XM antenna on the roof, not the standard onstar only one. All the cabling for the antenna, not sure if it is already there or not, and the XM module. That is the XM tuner, it is located on the rear deck near the rear passenger speaker.
Once you have all the parts you would have to go to the dealer and have them program the car and radio to accept the XM tuner and all of that fun stuff. It would probably be easier to get an aftermarket XM tuner and do it that way.
If you hit the band button and XM shows up as one of the bands then you already have XM, just need to call or go on the XM site and activate.
Add to gregh2000's Reputation
Rate the quality of this post and help gregh2000 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
gregh2000 is online now   Reply With Quote
Old 11-03-2009, 11:35 AM   #3
VWCarcrazy
VWCarcrazy is on a distinguished road
2008 AURA XE
If you do a search of the forum, you will see this has been covered several times before. You need quite a bit more than just a "module" if you want to access XM using your factory radio and buttons, etc. 1st, verify if your car already has XM (you can check with a Saturn dealer, using your serial number or you can follow the links in the e-Bay posting below). If your car is a 2007 model that did not have XM built-in from the factory, you can add it using a kit like the following:
http://cgi.ebay.com/ebaymotors/2007-...elliteQ5fRadio
I prefer this type of kit vs a "hang-on" unit that clutters up the dashboard. I have this brand in my Ford, and the seller has excellent instructions for installing (see the information in the link) and it was virtually plug and play. If you don't want to run the antenna out to the roof, you can place it discretely on the passenger side of the dash like I did. It works fine there.
You can swap out your factory radio for one with XM built-in, but it will be more expensive and the dealer will have to program it for you. Make sure if you purchase a used unit off e-Bay or an on-line site, that you get the serial number of the car the radio came out of. The dealer cannot/will not program the radio unless you have both the original serial number and a valid receipt proving the radio is legit and not stolen. Best luck.
2008 Aura XE 2.4L
Ocean Mist/Titanium
Add to VWCarcrazy's Reputation
Rate the quality of this post and help VWCarcrazy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
VWCarcrazy is offline   Reply With Quote
Can I replace my 01 SL1 CD/Radio with a newer GM Stock radio? SuperCujo S-Series General 46 01-27-2009 09:13 PM
96 SL SOHC radio wire to light on clock/radio turner dddaaa S-Series Tech 1 06-21-2008 04:53 PM
MP3 Factory Radio into a standard radio Vue baisley Vue General 9 01-04-2008 10:36 AM
Sirius radio FM interface with car radio firefox23508 Vue General 0 04-11-2007 01:48 PM
Need factory radio harness/plug for SAAS CD/Cass/FM/AM radio JButler1983 L-Series General 2 12-03-2006 04:48 PM
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
