#1 | ||||
![]() Join Date: Nov 2009
as the title says i'm looking for a remote start unit for an 05 and was wondering if someone could recommend one. from what i gather there is no factory option for this year and some aftermarket units produce a warning light. any help would be appreciated. thanks
#2 | |||||
I also have a 2005 Vue ... and would like a remote starter ... but have not yet worked up the courage (or obtained knowledge) to do the install. There's probably a simple way to convince Passlock that the correct ignition key is being used but I've not taken the time to try sorting it out. Please post any solution you might run across.
#3 | ||||
![]() Join Date: May 2009
2004 VUE Red Line
For Passlock you need to get a bypass module. The XK06 is the one I'm going to use, it is nice because it doesn't require a key to be kept inside of the unit.
I'm planning on getting a Viper 5701, it's the top level alarm/remote start without an LCD screen. The only downside to it is that it has the new antenna/LED/valet switch all in one, so you have a blinking light in the windshield with a button to defeat the alarm. Real brilliant there guys. I'm gonna run a separate LED (I want red and not blue), and put the antenna somewhere not in the windshield. I might put it under the center dash with my gps antenna and run a separate valet switch somewhere else, I haven't decided yet. It's a relatively pricey unit, But I'll get everything I need for about $130. One of the few perks of installing this crap is I can get a good discount on it. If you were to buy the same unit, expect your total costs to be in excess of $400. ... '04 Vue Redline AWD - Silver Nickel Metallic Mods: Tinted tails & corners - Stealth Amp and Sub system - In-Dash Navigation - Nitto INVO 245/50/18s - Custom HID Projectors
#4 | ||||
I had a DEI Valet (wanna say 461R or something like that) installed several years ago on my '06. I still have my factory fobs and it works like a charm. No issues. I did not do the install, so I don't know what all was involved other than the unit itself and a bypass module.
lock button once locks the doors lock button twice I guess arms the factory alarm (horn beeps) lock button three times and the car starts runs for 12 minutes and then shuts off (configurable) press the lock button 3 more times and it shuts off. Also a kill switch under the hood. If the hood is raised, the car won't start. ... 2004 Vue AWD V6
#5 | |||||
... "Remember, if the women don't find you handsome, they should at least find you handy" -Red Green 2005 VUE V6 AWD 1999 Nissan Altima GLE (wifes car) 2006 Nissan Titan KC (work truck)
#6 | |||||
Again, I got this unit in the fall of '06 so if it is a bit different now I can't say. I don't have the LED status light that they are advertising now - unless maybe they didn't install it... Regardless, I like it a lot. No issues. I have the use of my factory fobs as well as the fob that came with it (I have never used the fob that came with it). One other feature is that while idling, the running lights stay on so you can tell it is running or confirm that it started. http://www.hornetcarsecurity.com/Pro...?ProductID=807 ... 2004 Vue AWD V6
#7 | ||||
![]() ![]() Join Date: Apr 2002
2002 VUE 2.2L
The factory alarm arms with the first press of the remote. The second press of lock is nothing but a confirmation beep that everything is closed and that the alarm is armed.
... 2002 VUE FWD4m - 105K -Power Pkg/Sunroof/CD/Alloys/Head Curtains 2008 smart fortwo Passion Coupe - 8K miles -White/Silver/Black Heated Leather -Alarm/Fogs/Comfort Pkg/6 Disc/Audio Pkg/Tach
#8 | ||||
2004 VUE Red Line
I click mine twice every time as well. I like the confirmation.
#9 | ||||
2002 VUE 2.2L
I do as well. I have also had the dual chirp on unlock turned on (requires a Tech-II)... that way I can hear if I have accidentally hit the buttons or anything when walking away.
My smart has an electronic chirp - I think I prefer it though because it is more discreet than the horn. It's alarm is also a whistle type noise though - not a horn honk. ... 2002 VUE FWD4m - 105K -Power Pkg/Sunroof/CD/Alloys/Head Curtains 2008 smart fortwo Passion Coupe - 8K miles -White/Silver/Black Heated Leather -Alarm/Fogs/Comfort Pkg/6 Disc/Audio Pkg/Tach
#10 | ||||
2004 VUE Red Line
I just don't like the noise of the honk. It sounds kinda stupid IMO. When i install my alarm/remote start I want to have the siren for the chirp, and then add in the horn for the alarm. It's a little more complicated to install, but then if some sneaky ******* cuts the wire to my siren, the horn will still go off.
But who knows, I might get lazy and not want to grab the horn wire and do all the other crap to make it function like that. ... '04 Vue Redline AWD - Silver Nickel Metallic Mods: Tinted tails & corners - Stealth Amp and Sub system - In-Dash Navigation - Nitto INVO 245/50/18s - Custom HID Projectors
#11 | ||||
![]() Join Date: Dec 2005
I've had a CoolStart remote starter installed on my 02 for about 5 yrs. Worth every penny here in Ohio.
| Thread Tools | |
| Display Modes | |
| I want a remote start | AzBlondeRocket | Vue Red Line | 40 | 11-29-2008 03:05 PM |
| recommend replacement speakers and head unit | strutter | S-Series General | 36 | 04-08-2008 01:23 AM |
| 2000 saturnls2 wont start w;key only w/remote start PLEASE HELP(CAR STILL DRIVABLE!) | mymimi75 | L-Series Tech | 1 | 08-18-2006 11:50 AM |
| Eclipse 4400 Head Unit with remote for sale!! | BlueDevil | Old Classifieds | 0 | 12-01-2004 12:26 PM |
| FS: NEW Sony CD Head Unit (CDX-CA700X) XM Ready/ Wireless remote | mac-saturn | Old Classifieds | 0 | 08-31-2002 07:30 PM |
