#1 | ||||
![]() Join Date: Nov 2009
As the weather is now turning colder, there is a lag of 10 to 15 minutes or more before the outside temperature gauge reads correctly. When the gauge reads colder than the actual temperature (today it was reading 38 degrees), the air conditioning unit will not turn on. I took it to a Saturn dealership and was told that they could not find a problem and was told that the outside air temperature gauge has no effect on any other system in the car. Is this true and is there a fix to the problem?
#2 | ||||
![]() Join Date: Nov 2007
2008 Outlook XR
2007 AURA XR
i had a 2002 trailblazer that had the same problem and when it read low the air wouldnt turn on. it was an outside temperature sensor behind the grill. not too expensive
#3 | ||||
Press the A/C and recirc. buttons simultaneously. That will update the outside temperature display and allow your HVAC to operate properly. This is a workaround for a problem that GM never got around to addressing (as far as I know).
... Upgrades: Alpine 5 chan. amp, reQ-5 signal processor Infinity ref. components, JL Audio 10" sub Scosche BFGM bluetooth cellular, streaming audio interface Boss 318 20"/Falken FK-452 tires
| Thread Tools | |
| Display Modes | |
| Coolant temperature on gauge | wy2sl0 | S-Series Tech | 6 | 06-23-2009 08:51 AM |
| Temperature gauge broken. | J TRICK | S-Series Tech | 1 | 04-06-2007 08:30 AM |
| Engine Temperature Gauge | PlutoZePlin | Sky General | 3 | 08-19-2006 07:50 AM |
| HVAC temperature selector knob removal | burnout | Vue General | 6 | 08-09-2006 12:33 AM |
| Temperature Gauge | wat96sl1a | Miscellaneous Tech | 4 | 02-25-2000 09:13 AM |
