Old 11-01-2009, 11:56 AM   #1
dgreen97
dgreen97 is on a distinguished road
Default Loud noise and vibration inside 97 saturn sl2
Hi everyone,
I have a 98 SL2 with 150k miles and for the past couple years I've had a large problem with noise and vibration inside the car. The noise/vibration gets worse the colder it gets, and it gets better when it heats up over time. I've checked everything from the motor mounts, the transmission mounts, dogbones, and the entire exhaust system and I can't find out where this noise is coming from. To describe it: It sounds like the engine is being amplified inside the car. It's just a louder version of what the engine sounds like outside. If the car is at idle, it's relatively quiet but when I hit the gas it becomes very loud. It doesn't sound like there is a hole in the exhaust though. Does anyone have any idea of what this could be? I'm getting really tired of my car sounding like a dump truck.
Thanks for your help
Add to dgreen97's Reputation
Rate the quality of this post and help dgreen97 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dgreen97 is offline   Reply With Quote
Old 11-01-2009, 09:43 PM   #2
Killowatt
Killowatt is on a distinguished road
1997 SW2
Happy Re: Loud noise and vibration inside 97 saturn sl2
I had much the same noise on my 97 SW2. I had the "flex pipe" replaced on the exhaust system and that sure helped. It's not "Cadillac quiet" but much better.
The flex pipe is right under the firewall at rear of engine compartment, and it looks like a woven metal mesh cover. It's supposed to flex to help remove vibration, but it apparently rusts out, but still looks OK.
Hope this helps. Good Luck
Why do so many foods have "natural flavor" added? What does natural flavor taste like?
Killowatt
Add to Killowatt's Reputation
Rate the quality of this post and help Killowatt reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Killowatt is offline   Reply With Quote
Old 11-01-2009, 09:50 PM   #3
2NDSOUT
2NDSOUT's Avatar
1999 SL
Default Re: Loud noise and vibration inside 97 saturn sl2
Not that it is going to make too much difference, but do you have a 97 or 98 model year car? You reference both years in your post...
Bryan
94SL2 HCE, "Pearl"
99 SL
94SL2 260K Miles
1/15
97SW2 266K Miles
2/15
Always
94SC1 340,501 Miles
Org. Engine/Auto Trans
2/97-10/08
Gone 3/12
92SL1
05VUE
91SC
Add to 2NDSOUT's Reputation
Old 11-02-2009, 09:08 AM   #4
dgreen97
My car is a 97 I must have accidentally typed 98. I never checked out the flex pipe before. You said that it can look fine but inside it can be rusted out and cause vibration? The noise is definitely coming from the engine compartment because it just sounds like the engine is inside the car with me. It's just a louder version of it. I was thinking it might be the flywheel being out of round or something but I don't think that is the case considering the noise is most prominent when I hit the gas whether the clutch is engaged or not. When the car is at idle, it sounds like any other car because it's quiet. When I hit the gas, the vibration starts and all of a sudden it sounds really loud inside the car. Was the flex pipe an expensive replacement?
Old 11-03-2009, 10:33 AM   #5
DonP
Does the noise change when making turns or slowing down/speeding up?
Add to DonP's Reputation
Old 11-03-2009, 04:38 PM   #6
dgreen97
no the noise doesn't changing when turning. The noise gets louder when accelerating (whether just revving the motor while staying still or getting up to speed). It sounds like an amplified version of the muffler. The tone of the muffler has a distinct sound and it just amplifies in the cabin. The muffler isn't toast though because otherwise the sound would be constant and it would be loud outside too. If I stand outside the car, it sounds fine just like any other. If I get inside, it seems all of the engine noise is amplified and I can hear it very well. I just put in some more insulation for my doors today but that didn't do anything.
What could be causing the sound to be amplified in the cabin? Anybody know? I've been trying to fix this problem for like 2 years on and off and I still haven't found what the hell is wrong with this thing.
One thing I did notice on the metal mesh for the flex pipe that connects to the front pipe is that one edge of it (the end that wraps around the pipe) has come loose a little bit. I put my hand next to it and didn't feel any exhaust coming out but could this possibly be the issue. I can't really tell if that is the sound because I'm underneath the car where the motor is and not inside.
Old 11-03-2009, 04:47 PM   #7
dgreen97
It also sounds like the noise is coming directly in front of me like around the firewall. Any ideas on if the firewall insulation is a possibility of going bad and if it would allow so much engine noise to come into the cabin?
Old 11-04-2009, 12:53 AM   #8
l0phat
l0phat is on a distinguished road
l0phat's Avatar
I had a problem with my flex tube too on my 99 sl2, might be a common issue, my car failed inspection I did not know it was bad but my top mount was failing too my car was a rattle trap. You sure all your mounts are good? Have you jacked up the engine slightly (with wood at oil pan) and hit the gas and see if that fixes it if it does it's the mounts if not it's in the exhaust? I might have gotten lucky and had a new flex tube sourced and installed for 50$. That top mount is easy to replace 35$ @ advanced auto. It's either rubbing or cavitating. gotta figure out which one. Saturns don't have much in the way of sound deadening material so I don't think it's that.
99 SL2 151K 5 Spd Stock.
Add to l0phat's Reputation
Rate the quality of this post and help l0phat reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
l0phat is offline   Reply With Quote
Old 11-04-2009, 09:09 AM   #9
dgreen97
yeah i've definitely checked all of the mounts. I jacked the motor up at different angles as well to test if the sound changes in the cabin. No difference. This is the oddest car problem I've run into so far. Nothing seems to fix it. Since the tone inside the cabin sounds a lot like the muffler tone, is it possible the muffler has gone bad inside (such as the baffles) without seeing noticable holes on the exterior of the muffler? What would make the sound change when temperature changes? The sound/vibration is always worse when it is cold out. When the car finally heats up, it gets better (less sound/vibration) but its definitely still there. I don't want to replace the muffler though if there is nothing wrong with it. Another question: If the clutch went bad, would it cause the engine noise in the cabin to get very loud and vibrations to go through the car?
Old 11-04-2009, 09:10 AM   #10
dgreen97
I also checked the end of the flex tube (the metal mesh) and the edge of it isn't wrapping tightly to the front pipe coming down from the engine. I put my hand next to it and no exhaust felt like it was coming out though. When you guys replaced your flex tube, did you notice this?
Old 11-04-2009, 09:48 AM   #11
l0phat
l0phat's Avatar
Here is some info I forgot last night the flex tube piece we are refering to was called a resonator by the guy at the inspection place. Perhaps rather than cavitation I should have said resonation. It's possible the baffles went bad in the muffler I guess. Wonder if it's possible to stick a coat hanger up there to test... untested..and unknown... I can try it out for ya to see if we get different results after work... I'll let ya know what I feel. But to answer your question.. I had no idea mine was bad.. the bad mount covered the noise..
Old 11-04-2009, 09:36 PM   #12
off-track
off-track's Avatar
Try having a friend hold a rag against the the tailpipe (when it's idling) while you crawl around underneath and check for leaks. The back-pressure will make it much easier to find if you have any leaks.
Purchased 114k 10/07
Added OEM CC
Add to off-track's Reputation
Old 11-05-2009, 10:26 AM   #13
DonP
Can you isolate the source using a mechanics stethoscope?
Old 11-05-2009, 03:04 PM   #14
dgreen97
thats actually not a bad idea to check for leaks. i'll try that out and see what happens from it. no i wish i had a stethoscope so i could better identify where the noise is coming from. When you're inside the car in the drivers seat it sounds like it's all around you which is why I'm not sure if its the muffler or the motor causing the loudness/vibration. I do have a question about the firewall though. What would cause the engine noise that previously wasn't a problem to start being an annoyance? Can the firewall insulation that prevents the engine noise in the cabin go bad enough to turn the inside of the car into a noise dome?
Old 01-11-2015, 01:43 PM   #15
swidman51
swidman51 is on a distinguished road
2002 L-Series 2.2L Sedan
Thumbs Up Re: Loud noise and vibration inside 97 saturn sl2
On my 1998 SL2 at about 180,000 mi I replaced both the passenger side engine mount and driver side transmission mount with mounts from Autozone. When warm the engine noise was louder in the car than before and when below 32 deg F the sound was very loud, and when below 0 F the sound would actually hurt your ears. After then engine ran for 10 minutes or so the mounts would warm it would get better, although still quite loud. Replaced the Autozone mounts with mounts from NAPA and they were also loud. I really is amazing the engine can be so quiet outside of the car but inside it can be quite deafening.
I finally bit the bullet and bought GM mounts from the local dealer. These cost over $100 more than the aftermarket mounts but now it's quiet. The difference is unbelievable, really unbelievalbe. Probably the aftermarket mounts are from one or two suppliers so probably no matter where you get them (except GM) you will probably have the noise problem.
If you replaced the mounts with after market mounts and the car is noisy I suggest you buy genuine GM mounts for for you SL series Saturn.
Add to swidman51's Reputation
Rate the quality of this post and help swidman51 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
swidman51 is offline   Reply With Quote
Old 01-11-2015, 01:58 PM   #16
Jeeprz!
Jeeprz! is on a distinguished road
Is the engine running smooth, or does it smooth out more after being warmed up? OldNuc has posted multiple times in mount threads that if if you engine does not run relatively smooth to start with you will never get rid of all the vibrations even with new mounts.
Also, being plastic our cars act as a large resonator to start with and any vibrations and noise is amplified more than a metal car. Take a large Tupperware type container, put the lid on it and hit it - acts just like a drum does.
One more thing, my flex pipe was crusty rusty looking but looked solid, when I pulled it off it had a hole in the top of it right where the clamp holds it onto the engine/trans stiffener bracket, there was no way to see it until I removed it.
"Officer, turning on your lights and siren just because you lost the drag race is just poor sportsmanship."
"Turtle" the Green 1998 SC2 Auto DOHC 160k that doesn't burn any oil!
Add to Jeeprz!'s Reputation
Rate the quality of this post and help Jeeprz! reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Jeeprz! is offline   Reply With Quote
Old 01-12-2015, 02:46 PM   #17
xmark
xmark is on a distinguished road
xmark's Avatar
2004 VUE Red Line
I bet your TAM (top engine mount) is an aftermarket unit that was made with a non-OEM spec rubber compound that stiffens as temperature drops. When the rubber gets cold, it acts more like solid metal than rubber, and transmits engine vibration directly to the metal inner fender, which is welded to the firewall. It turns your firewall into a big resonating drum - and you are riding inside the drum.
The stiff TAM will look fine at inspection. The only way to find out is replace it.
Add to xmark's Reputation
Rate the quality of this post and help xmark reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
xmark is offline   Reply With Quote
Loud vibration noise d_rock S-Series Tech 15 02-27-2009 05:48 PM
Loud vibration inside of car, checked all motors mounts, help please dgreen97 S-Series Tech 5 12-14-2008 08:49 AM
vibration? loud noise tkelley80926 S-Series Tech 15 01-26-2007 02:16 PM
loud noise and vibration 95sl 95sl S-Series General 5 12-22-2004 11:08 PM
Vibration/rattle noise in door with loud music? jeffkics Vue General 9 12-13-2003 09:36 PM
