Old 07-18-2012, 09:55 AM   #21
rcw3586
rcw3586 is on a distinguished road
1993 SL2
1994 SL
Default Re: How To: Clutch Hydraulic system with pics
This is a great how-to and I wish I had found it before having done this myself.
I do wish I had removed the brake master for access, as with one hand I was unable to get enough torque on the new unit to twist it into place. I ended up knocking the rubber cover loose on the new clutch master and spilling brake fluid. (this may be why it's not working well)
One other tip I would add to this:
It is far easier to access the clutch pedal and clip from above than below. I personally don't work well standing on my head.
Removing the top of the dash is simple. Just pop out the two screw covers at the ends, unscrew the two screws, carefully pry up the near edge of the dash cover and then pull it out of the retainers towards you. Just be patient so you don't break off any tabs. Remove the felt sound deadener blanket and you're in. Now you can look right down through the windshield and see everything which is in easy reach.
Add to rcw3586's Reputation
Rate the quality of this post and help rcw3586 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rcw3586 is offline   Reply With Quote
Old 01-24-2013, 12:12 PM   #22
Tercero
Tercero is on a distinguished road
Tercero's Avatar
1997 SL1
Old thread, but extremely valuable for its information.
For Canadians, I priced out the part from Ideal Supply (NAPA). They wanted $261 plus tax. A tad pricey. I found the EXACT same part on ebay from
http://www.ebay.com/itm/310494111175...A:3160&vxp=mtr
Or look up 91-99 Saturn S Hydraulic Clutch Slave/Master Cylinder.
1 year warranty and it's the complete kit.
1AAuto. It's $119 plus $14 for shipping and a $19 dollar import tax fee. A hell of a lot cheaper obviously, for the same kit.
$154.33 in total shipped to my door. The only hiccup (and it's not much of one) is they UPS it to a central clearing hub in KY, and then hand it off to USPS who then hands it off to CanadaPost. So all in all about 7 days (business) for shipping. Not bad. It'd probably quicker from Ideal but you'll pay for that won't you?
And it's an easy easy fix by the way. I did this in Jan (2013) when the outside temps in Barrie were -20C and still got it done in 45 minutes.
Thanks again for the great pictures by the way.
T>
Add to Tercero's Reputation
Rate the quality of this post and help Tercero reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Tercero is offline   Reply With Quote
Old 02-20-2016, 10:14 PM   #23
karcher
karcher is on a distinguished road
karcher's Avatar
i just did this today on a 2002 SL2. The entire job took three hours with me being very careful, refurbishing some of the bolts and wires where battery acid was spilled, and an oil change.
The only update I have is that it was easier to detach the master cylinder and anti-lock brake distribution block (keep them as one unit) and sliding the hard plastic line between them and the frame.
Thanks again for all the excellent write-ups on this site!
2002 SL2 - Manual Trans - 200,000 miles - lots of replaced parts :)
Add to karcher's Reputation
Rate the quality of this post and help karcher reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
karcher is offline   Reply With Quote
Old 04-06-2016, 03:24 PM   #24
demoncamber
demoncamber is on a distinguished road
Does this fix the issue where it's hard to get into 1st gear and reverse at times?
///M5sc2-126k-5spd-Eagle GT's
-2x Alpine TypeS 12in 1223D -Kenwood KAC8104D -Audiobahn A4401T
-Alpine SPS-600c - Infinity Kappa 62.9I - 1.5f Cap
Add to demoncamber's Reputation
Rate the quality of this post and help demoncamber reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
demoncamber is offline   Reply With Quote
Old 06-03-2016, 03:51 PM   #25
marsneptune
marsneptune is on a distinguished road
When removing the slave cylinder, the pushrod fell off and disappeared down into the clutch fork housing. So....
1. Other than the possibility of not being able to engage the clutch at an inopportune moment (because the rod had worked itself into a place that prevented clutch fork movement), is that rod likely to do any major damage if I leave it? Could it get caught in the splines of the pressure plate? could it get caught between the clutch and the flywheel?
2. What would be required to retrieve the pushrod? Would i need to pull the transmission and/or flywheel housing, or would there be some plate I could remove and gain access from the bottom?
Thanks
Add to marsneptune's Reputation
Rate the quality of this post and help marsneptune reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
marsneptune is offline   Reply With Quote
Old 07-19-2016, 06:11 PM   #26
97sl5spd
97sl5spd is on a distinguished road
Yeah just did mine on a 97 sl. So freaking easy it ain't funny.
Add to 97sl5spd's Reputation
Rate the quality of this post and help 97sl5spd reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
97sl5spd is offline   Reply With Quote
Old 08-17-2016, 02:25 AM   #27
astraowners
astraowners is on a distinguished road
Thumbs Up Re: How To: Clutch Hydraulic system with pics
Thanks for the Photos and how-to it was spot on genius how you solve your problems
Add to astraowners's Reputation
Rate the quality of this post and help astraowners reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
astraowners is offline   Reply With Quote
Q about hydraulic clutch system MikeNW S-Series Tech 13 12-22-2011 08:11 AM
Bleeding clutch hydraulic system MikeNW S-Series Tech 2 06-03-2009 12:43 PM
Help ! Air in Hydraulic Clutch System GlennWerner S-Series General 2 12-06-2007 09:54 AM
98 SL2 clutch hydraulic system Boodah S-Series Tech 2 05-15-2007 12:40 PM
Clutch hydraulic system problems clemtwist S-Series General 4 04-03-2006 07:31 PM
