Old 10-31-2009, 01:09 PM   #1
Sevillian273
Sevillian273 is on a distinguished road
Sevillian273's Avatar
2001 SL2
Default A/C Compressor cycling on and off?
2001 SL2 - With the heat on high, and the ac button OFF, I noticed that the ac compressor still cycles on and off about 15 seconds on/ 15 seconds off. Is this normal?
Add to Sevillian273's Reputation
Rate the quality of this post and help Sevillian273 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Sevillian273 is offline   Reply With Quote
Old 10-31-2009, 01:37 PM   #2
Default Re: A/C Compressor cycling on and off?
How did you manage to have the a/c running with it OFF (''and the a/c button OFF")? Recycling ON?
If the coolinng fan is broken or the coolant sensor fails; the cooling fan will never run to keep the cooling system regulated. This also becomes a misinterpreted a/c problem; the cooling fan is supposed to be running when the a/c system is turned on. If the a/c is running and the fan isn't, the compressor will begin cycling on and off from too much heat created in the condenser coil that also creates too much high pressure within the a/c system. The detected higher pressure cause the system to shut down automatically to prevent any catastrophic blow out until pressures subside then the cycle starts over again.
Old 10-31-2009, 01:44 PM   #3
Sevillian273
2001 SL2
Thats what I dont understand. The compressor was cycling on and off in short intervals with the heat on high and ac button OFF.
The ac button turns the compressor on or off, and the recycle button selects whether or not the blower pulls air in from the outside or from the inside of the car.
I dont see why the compressor would engage with the ac button OFF.
Old 10-31-2009, 01:50 PM   #4
The a/c relay may be stuck ON. Replace it with another one like the horn relay and see what occurs.
Old 10-31-2009, 01:51 PM   #5
Sevillian273
2001 SL2
Thanks, I'll try that
Old 10-31-2009, 04:07 PM   #6
madpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to behold
In what position was the mode selector? IIRC, gen-3 cars can be programmed to run the A/C compressor when the mode selector is in the defrost position.
Add to madpogue's Reputation
Old 10-31-2009, 06:21 PM   #7
Sevillian273
2001 SL2
Lol! As a matter of fact it was! But why would they design it to do that?
Old 10-31-2009, 07:21 PM   #8
It was designed to quickly remove fogging from the windshield. It works although many complain about the slightly more use of fuel or the engine load.
Old 11-02-2009, 08:34 AM   #9
DonP
Running the A/C removes moisture from the air blown on the windshield, allowing it to defog the windshield faster (by evaporation). Many of the newer cars run the A/C when in defrost position if the ambient air temp is above ~40F. At cooler ambient temps it is sufficient to heat the air for defogging the windshield.
However, if the A/C is cycling quickly now, does it work OK when set to cooling?
Add to DonP's Reputation
Old 11-02-2009, 09:45 AM   #10
Sevillian273
2001 SL2
Yes, everything works as it should now.
Old 11-02-2009, 09:53 AM   #11
alordofchaos is a glorious beacon of lightalordofchaos is a glorious beacon of lightalordofchaos is a glorious beacon of lightalordofchaos is a glorious beacon of lightalordofchaos is a glorious beacon of light
in addition to removing moisture, cycling the AC for defrost also moves the oil carried by the refrigerant throught the system.
Betcha nobody turned on their AC systems and ran them once a week (or was it month?) for 15 minutes in the winter time, the way the owner's manual recommended back in the old days.
I read somewhere that most modern cars cycle the AC when defrost + heat are on.
Wait, what, I actually won that eBay auction?
12/2008 silver 1998 SL2 5 spd 102k, now 180k
7/2010 white Craigslist 1997 SC2 5 spd
Old 11-02-2009, 10:34 AM   #12
It wouldn't have done any good to put that into the owner's manual in the gen-1 and gen-2 cars. A/C does not run when ambient temperature, as reported by the IAT sensor, is below 40F. Workaround - I (don't laugh) saved my old ECTS; once a month or so during the winter, I take it out (it's kept inside, above 40F), plug it into the IAT connector, start the engine and run the A/C.
Old 11-02-2009, 11:13 AM   #13
I'm talking about the 70's, carbureted V8 cars, when I said 'older'... before Saturn was a twinkle in Lutz' (?) eye.
It was a complete shock first time I read that in an owner's manual Don't remember what car it was, thinking it was a Chrysler, though
Don't the gen 1 & 2 S-series AC cycle with the defrost? Dang, i just assumed it does... I'll have to go back and read the owner's manual
Old 11-02-2009, 11:49 AM   #14
Sevillian273
2001 SL2
Come to think of it, my caddy does that too when the temp is set to 90 and the defrost is on... I always thought it was a malfunction.
Whooosing/Cycling sound mrgto 2008 Vue 8 09-29-2008 11:37 AM
? about A/C compressor cycling Partymmudasti S-Series Tech 4 06-19-2007 09:17 AM
Saturn Cycling Watch tksaturn Classifieds 0 01-27-2005 12:58 PM
A/C cycling on and off 1991SL S-Series Tech 6 10-19-2003 05:51 PM
A/C cycling/draining 9TWOSC Miscellaneous Tech 5 05-07-2003 01:00 PM
Copyright ©2000 - 2016, vBulletin Solutions, Inc.
