Old 10-11-2009, 11:21 AM   #1
n2k2baby
n2k2baby is on a distinguished road
1997 SL1
Default what size socket for drive axle nut???
Hi all, I would like to buy the proper size socket for removing the axle nuts, before I get into a job and realize that I don't have it... thanks in advance...
It will be for either a 96 SL2 or 97 SL1 which I am sure there is no difference
Add to n2k2baby's Reputation
Rate the quality of this post and help n2k2baby reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
n2k2baby is offline   Reply With Quote
Old 10-11-2009, 11:59 AM   #2
quantumech
quantumech is on a distinguished road
Default Re: what size socket for drive axle nut???
It's a 30 mm lock nut. Make sure it's a deep well deep enough to get there.
Sasha: 2000 SL1, Manual, 130,500 miles 5-18-2014.
I learn from my experiences. If I screw up, I'm sorry.
Add to quantumech's Reputation
Rate the quality of this post and help quantumech reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
quantumech is offline   Reply With Quote
Old 10-12-2009, 06:29 PM   #3
n2k2baby
1997 SL1
thanks for the reply...
97 SL1 297K km and climbing, 5spd m/t, no a/c or options, commuter of 60miles a day
96 SL2 220K parts car,00 SL1 Auto, wife's replacement, awesome car so far 231K
Old 10-12-2009, 08:23 PM   #4
PurdueGuy
PurdueGuy's Avatar
1999 SC1
If you don't have a socket that will fit, get an axle nut socket at your local parts store. They are deeper than what you'll typically find at Sears, etc.
SaturnSeries.net owner
Add to PurdueGuy's Reputation
Old 10-12-2009, 09:08 PM   #5
Signmaster
Signmaster is a name known to allSignmaster is a name known to allSignmaster is a name known to allSignmaster is a name known to allSignmaster is a name known to allSignmaster is a name known to all
... and often cheaper too. Quite a few companies make those larger off the wall sizes for just about any common car these days.
Old 11-22-2011, 09:42 AM   #6
Patman52
Patman52 is on a distinguished road
If you don't have an impact, make sure you have plenty of penetrating oil and a large breaker bar.
I have a regular breaker bar and a 4ft long piece of black pipe that fits over it, works great.
Add to Patman52's Reputation
Rate the quality of this post and help Patman52 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Patman52 is offline   Reply With Quote
Old 11-24-2011, 04:51 PM   #7
coolbikeguy
coolbikeguy is on a distinguished road
coolbikeguy's Avatar
yep .... just took both of mine off yesterday... since its thanksgiving .... im thankful we had a 1/2 drive impact. they are tight the whole way off.
1998 sw2 5spd
Add to coolbikeguy's Reputation
Rate the quality of this post and help coolbikeguy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
coolbikeguy is offline   Reply With Quote
Old 11-24-2011, 06:36 PM   #8
amazinghl
Autozone rent out axle socket for free.
94 855 394xxx miles
00 Insight 72mpg
Add to amazinghl's Reputation
Old 11-24-2011, 11:36 PM   #9
off-track
off-track's Avatar
Watch that, and be sure to check the threads closely! We replaced a wheel bearing on my Son's car last week and the nut was hard the whole way off as well. We ended up completely hosing the new nut (and end of the shaft as well) putting it back on. We ended up chasing the threads slightly with a triangular file and the replacement went right on.
Oop! Another POTLD (post of the living dead). Just noticed the view count!
Purchased 114k 10/07
Added OEM CC
Add to off-track's Reputation
04 Vue 3.5 AWD Front Axle Nut Size louis1971 Vue Tech 10 01-25-2016 08:33 AM
axle nut size Booncha57 S-Series Tech 13 10-25-2010 10:42 AM
axle nut hamhauck S-Series Tech 2 02-04-2008 03:19 PM
Input shaft nut. Deep socket or not?? phatboy S-Series Tech 0 04-03-2007 11:50 AM
input shaft nut on A/T: where to get socket? geartooth94 S-Series General 6 05-11-2005 09:30 AM
