Old 10-08-2009, 07:46 AM   #1
jsmith2585
jsmith2585 is on a distinguished road
Default anti theft system
I have a 2002 saturn sc2 automatic with sohc. I have been having this problem where it will randomly die and when i try to re-start it cranks but will not fire. after 20 mins or so it will start and will probably run fine for days or even a week before doing this again. I suspect the ignition control module but the problem is so intermittent that it is hard to test. I took it to my local garage that I take all my cars and after 3 days they have decided that it is a anti theft device problem. I know that the car has some sort of factory system for that but i dont have an after market system installed. I was just wondering what everyones thoughts on the anti theft system being the cause of my problem or possibly if anyone has knowledge of how to bypass it just incase this really is my problem.
Add to jsmith2585's Reputation
Rate the quality of this post and help jsmith2585 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jsmith2585 is offline   Reply With Quote
Old 10-08-2009, 08:50 AM   #2
s3nfo
s3nfo has a spectacular aura abouts3nfo has a spectacular aura abouts3nfo has a spectacular aura about
s3nfo's Avatar
2001 L-Series 3.0L Wagon
Default Re: anti theft system
Welcome to the boards.
Your answer can be found over in the S series forum. There's only like 3 people here who answer S series questions.
Jerry N
Groucho Marx
Add to s3nfo's Reputation
Old 10-08-2009, 09:39 AM   #3
As mentioned above ^ ^ ^, having an S-series car should have been posted in the S-tech forum. You're in the L-tech forum.
1-Its not likely a security issue as you haven't written anything about the security indicator flashing on during starting.
2-Suspecting an ignition issue may be correct but to be exact would require several things to check to isolate the problem. Separate a fuel issue from an ignition issue to narrow things down.
To cut to the chase based on your description; simply check for spark the next time the engine dies by removing the coil wires (after noting firing order) and have someone crank the engine while you look for spark across the coil towers. The lack of spark would indicate (in most instances) an intermittent crank position sensor (CPS) failure because many others have had the exact same symptoms. The next likely cause would be the ignition module but more cps' fail than ignition modules. The cps is behind and above the starter, mounted with one 10mm bolt. Buy it anywhere.
Old 10-08-2009, 11:17 AM   #4
jsmith2585
SOrry i thought i was in s series tech. I have reposted in the s series thread.
Service Anti Theft system seadub2 Relay Tech 11 05-23-2009 11:43 PM
Help With Radio Anti Theft System rogdevchan S-Series Tech 3 08-12-2008 04:26 PM
Anti theft system problems 2006 Vue Squid4395 Vue General 16 04-13-2006 08:09 AM
95 SL Anti-Theft removal? tjcib S-Series General 7 01-25-2005 04:59 PM
anti-theft drewsl2 General Saturn Discussion 5 10-05-2001 02:15 AM
