Old 09-27-2009, 11:34 PM   #1
jjbendo
jjbendo has a spectacular aura aboutjjbendo has a spectacular aura about
Default Quill Seal/Bearing & FSM
Hi All,
Clutch started slipping. I seperated the tranny from the engine and removed the flywheel to inspect the rear main seal, RMS. The RMS was dry as a bone. However, the inside of the bell housing was soaked with a redish tint to it. Base on my reading from this site it looks like the Quill Seal/Bearing.
I followed the directions from differentracing.com to open the trans. The diferential doesn't lift out. Do I need to do something special to release it?
I'm ready to press out the old seal/bearing. Does anyone have the FSM procedure w/ pics they can post?
1995 SL2, 135,000, 5-speed
Add to jjbendo's Reputation
Rate the quality of this post and help jjbendo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jjbendo is offline   Reply With Quote
Old 09-28-2009, 12:55 AM   #2
Low Saturn
Low Saturn's Avatar
2000 SC2
Default Re: Quill Seal/Bearing & FSM
Its not pressed in or anything. A little wiggling gets it out. Thats what we did when we made that write up.
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2000 SC2
-2001 Chevrolet Suburban
Old 09-28-2009, 01:41 AM   #3
jjbendo
Thanks, I'll try more wiggling.
Anyone have a copy of the the procedure from the FSM on how to press out the quill seal/bearing?
Old 09-28-2009, 08:41 AM   #4
Leafy
Leafy is on a distinguished road
Leafy's Avatar
didnt a diff pin working its way out cause atf to be in the bell housing before it started leaking right out?
1994 SL2 HCE auto 113 hp 113 lbft (wheel) backup car
2002 Chevy Cavalier SS
For Sale: FlyWheel, Shifter assembly, Clutch Hydros, 1st gen 5 spd PCM. PM me for prices.
WPI class of '12 ME
Add to Leafy's Reputation
Rate the quality of this post and help Leafy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Leafy is offline   Reply With Quote
Old 09-28-2009, 08:49 AM   #5
jjbendo
The diff is out.
The diff pin is in it's proper location. So do I weld it or take a chance...
1995 SL2, 135,000, 5-spd
Old 09-28-2009, 10:14 AM   #6
Low Saturn
Low Saturn's Avatar
2000 SC2
Originally Posted by jjbendo View Post
The diff is out.
The tranny is all apart, might as well weld it. You'll be kicking yourself if the pin decides to ever fly out.
Mike
-1991 Turbo SL2.
-2000 SC2
Old 09-28-2009, 10:25 AM   #7
jjbendo
OK Thanks.
How do I remove the old Quill bearing/Seal
press from the inside to the outside
or
press from the outside to the inside
John B
1995 SL2, 5-spd, 135,000 mi
Old 09-28-2009, 12:53 PM   #8
jjbendo
To remove the old Quill bearing/Seal it needs to pressed from the inside to the outside.
John B
Changing quill bearing, 97 SL2 Yoda S-Series Tech 6 10-24-2006 10:44 PM
Change quill bearing 97 SL2 Yoda L-Series Tech 0 10-22-2006 09:06 PM
Quill Bearing? bobke1 S-Series Tech 4 02-04-2006 01:30 PM
Could the Quill Bearing burn out the Clutch? Longos S-Series Tech 3 10-14-2005 01:17 PM
What's a Quill Bearing? clemsonsaturn S-Series Tech 14 08-08-2005 11:44 PM
