Old 09-22-2009, 11:31 AM   #1
duncan
duncan is on a distinguished road
Default Fuel line leak
I hit something in the road last night and immediately smelled gas. When I stop a puddle of gas appears right under the driver door where I get out.
So clearly I have a leak in the fuel line but I can't get under to look at it. I have outdoor parking and it's pouring rain today. I can't do this work myself, is it likely to be an expensive fix? Is it possible to temporarily patch the line for a few days until I have time to get it fixed properly?
Add to duncan's Reputation
Rate the quality of this post and help duncan reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
duncan is offline   Reply With Quote
Old 09-22-2009, 12:08 PM   #2
Low Saturn
Low Saturn's Avatar
2000 SC2
Default Re: Fuel line leak
Without knowing exactly what the problem is, it's kinda hard to guess how to fix it.
The fuel lines are in the are you describe. Might have to replace the line that connects to the fuel pump that runs under the car.
Mike
11.809 @ 116.488 mph
www.differentracing.com
-2000 Saturn SC2
-2001 Chevrolet Suburban
Old 09-22-2009, 12:31 PM   #3
Leafy
Leafy is on a distinguished road
Leafy's Avatar
they're hardlines if I'm not mistaken, you you'd have to pull it off the car, use a mini pipe cutter to cut out a section of pipe, use a flare too to flare the ends and use flare couplers to splice in a new section, it'd be easier and possibly cheaper just to do the whole thing.
if I'm wrong and its rubber thats really simple, just splice in a brace barb splice and use good hose clamps.
1994 SL2 HCE auto 113 hp 113 lbft (wheel) backup car
2002 Chevy Cavalier SS
For Sale: FlyWheel, Shifter assembly, Clutch Hydros, 1st gen 5 spd PCM. PM me for prices.
WPI class of '12 ME
Add to Leafy's Reputation
Rate the quality of this post and help Leafy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Leafy is offline   Reply With Quote
Old 09-22-2009, 12:33 PM   #4
hholbein
1997 SW2
Please post your model year as well. Although I'm sorry to hear about the problem, if you have a mid-90s model, the debris might have struck the fuel line that's part of the fuel filter assembly (~$30), which is located near the driver's side wheel. That part is relatively easy to replace, I can't say about other fuel system lines....
Add to hholbein's Reputation
Old 09-22-2009, 02:51 PM   #5
duncan
Sorry, it's a 92 sl.
Old 09-22-2009, 04:12 PM   #6
NAPA sells a Hard line repair kit. Its either that or snag a replacement from a junk yard. The first thing to do is determine whether its the fuel pump feed line or the regulator return.
Old 10-05-2009, 05:44 AM   #7
SWMark
SWMark is on a distinguished road
I too discovered a fuel line leak in my 93 wagon last night.
Is the repair kit an easy solution or should I replace the line?
Add to SWMark's Reputation
Rate the quality of this post and help SWMark reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SWMark is offline   Reply With Quote
Fuel line specs on a 1998 Saturn Sl 1 (fuel injected) WadeNKC S-Series Tech 9 01-07-2010 05:42 PM
What happens if you kink/bend a fuel line during fuel filter installation? Dingo Warrior S-Series Tech 4 05-31-2008 09:43 PM
fuel line leak hihopes63 S-Series Tech 1 06-30-2005 11:32 PM
fuel line leak hihopes63 S-Series Tech 1 06-30-2005 02:48 PM
Uh Oh! VUE Red Line Fuel Line Recall CanVueYes! Vue Red Line 6 06-26-2004 04:03 PM
