Go Back   SaturnFans.com Forums > Categories > General Saturn Discussion
Old 09-18-2009, 05:41 PM   #1
Charlie
Administrator
Charlie has a brilliant futureCharlie has a brilliant futureCharlie has a brilliant futureCharlie has a brilliant futureCharlie has a brilliant futureCharlie has a brilliant futureCharlie has a brilliant futureCharlie has a brilliant futureCharlie has a brilliant futureCharlie has a brilliant futureCharlie has a brilliant future
Charlie's Avatar
2008 Outlook XR
2005 VUE Red Line
Default Spring Hill Plant Builds 2 Millionth Engine
A new story entry has been added:
[drupal=3339]Spring Hill Plant Builds 2 Millionth Engine[/drupal]
According to UAW Local 1853 Chairman Mike Herron, Saturn's former Spring Hill Powertrain plant built its two millionth GM L-850 Ecotec 4-cylinder engine at around noon this past Wednesday (September 16th). The Tennessee-built engine is used in General Motors vehicles sold worldwide.
2008 Saturn Outlook XR (sold)
2005 VUE Red Line
2002 L300 (sold)
Charlie is offline   Reply With Quote
Old 09-19-2009, 02:35 AM   #2
cfg83
cfg83 is on a distinguished road
cfg83's Avatar
Default Re: Spring Hill Plant Builds 2 Millionth Engine
Charlie -
This article made me google the engine :
http://www.saabnet.com/tsn/bb/9-3/index.html?bID=113122
The L850 engine program at GM (which was eventually branded the Ecotec) was designed to be a Universal block for 4 cylinder GM passenger cars. Short note: I worked for a few years for a Tier 1 supplier of internal engine components for GM, so I have some knowledge/background on the L850 engine program, though by no means extensive. It was planned for all of the GM brands at the time (late 90's) including Saab, Opel, and Lotus, along with Chevy, Saturn, Olds, and Pontiac to use this basic L850 block (yes it is cast Al, and I believe it is also lost foam cast, which was/is a Saturn innovation). Because this block was designed from the beginning to be used in robust applications, it benefited from relatively high design limits. It was engineered for turbocharged/supercharged applications at the get go (with handy features like passages for oil jet cooling of pistons, rather than splash lubrication).
CarloSW2
cfg83 is offline   Reply With Quote
Old 09-21-2009, 12:56 PM   #3
K-1
K-1 is on a distinguished road
K-1's Avatar
2008 Astra XR
The Family 2 Ecotec engines built in Spring Hill are sand cast, not lost-foam.
Toyota: Moving Forward... off a cliff at a high rate of speed.
K-1 is offline   Reply With Quote
Old 09-22-2009, 04:17 PM   #4
spork
spork is on a distinguished road
spork's Avatar
The 1st gen ecotec I have in my L series is lost foam cast.
"Don't blame me, I voted for Kodos"
spork is offline   Reply With Quote
Old 09-23-2009, 09:32 AM   #5
K-1
K-1's Avatar
2008 Astra XR
You're correct. The Gen 1 block of the L61 was lost-foam. The Gen 2 block was upgraded to sand-casting for the LNF and LAF engines. The regular 2.4L is lost-foam cast though. The 2.2L is also lost-foam cast in Tonawanda.
Spring Hill, TN Plant rerunjas General Saturn Discussion 25 08-21-2007 11:56 AM
Spring Hill to become crossover plant robertburns3 General Saturn Discussion 16 12-24-2006 02:40 AM
Spring Hill Plant? slv01sc2 General Saturn Discussion 13 07-10-2006 04:10 PM
Spring Hill Plant Tour YELO_SC2 General Saturn Discussion 14 03-09-2005 03:22 AM
Going To Visit Spring Hill Plant ! DP49657 Vue General 11 04-26-2003 12:39 AM
