Old 09-11-2009, 02:08 PM   #1
AmandaL
AmandaL is on a distinguished road
Default Transmission swap?
I have a 99 SL1 with a bad transmission and ive found a 93 Saturn(not sure on model). My bad transmission id a single overhead cam and the new one is a double over head cam. can i swap the two out and it still work? Any help here would be great.
Add to AmandaL's Reputation
Rate the quality of this post and help AmandaL reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
AmandaL is offline   Reply With Quote
Old 09-11-2009, 02:39 PM   #2
Low Saturn
Low Saturn's Avatar
2000 SC2
Default Re: Transmission swap?
Bolt up, yes.
Function, yes if its a manual, no if its an automatic. And if its a manual, it will function, just not well.
Mike
11.809 @ 116.488 mph
www.differentracing.com
-2000 Saturn SC2
-2001 Chevrolet Suburban
Old 09-11-2009, 02:43 PM   #3
AmandaL
Its Auto.What if swapped the engines too? would it work then? My trans has a crack in it. Ive found the 93 saturn for 300 for the whole thing so......
Old 09-11-2009, 04:31 PM   #4
PurdueGuy
PurdueGuy's Avatar
1999 SC1
No, it won't work. The PCM for the '99 can't operate an auto trans from a '93 (and vice versa), and you can't just swap PCMs between those years. It just won't work.
SaturnSeries.net owner
Add to PurdueGuy's Reputation
Old 09-11-2009, 05:51 PM   #5
Leafy
Leafy is on a distinguished road
Leafy's Avatar
if you swapped the whole engine, the trans and the pcm it would work.
1994 SL2 HCE auto 113 hp 113 lbft (wheel) backup car
2002 Chevy Cavalier SS
For Sale: FlyWheel, Shifter assembly, Clutch Hydros, 1st gen 5 spd PCM. PM me for prices.
WPI class of '12 ME
Add to Leafy's Reputation
Rate the quality of this post and help Leafy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Leafy is offline   Reply With Quote
Old 09-11-2009, 06:40 PM   #6
Low Saturn
Low Saturn's Avatar
2000 SC2
You can't put a 93 PCM in a 99.
Mike
-2000 Saturn SC2
Old 09-11-2009, 08:09 PM   #7
Leafy
Leafy's Avatar
besides being emissions illegal why else not? it wont agree with the bcm?
WPI class of '12 ME
Old 09-11-2009, 08:21 PM   #8
Low Saturn
Low Saturn's Avatar
2000 SC2
99 doesnt have a BCM. The 93 PCM will physically not plug in. The wiring schematics, connector faces and electronics are totally different. And thats just one of the several reasons a 1993 DOHC wont drop into a 99. Many other parts from later models will be needed to suscessfully complete the swap. Intake manifold, fuel injectors, EGR valve, fuel rail just to name a few.
Mike
-2000 Saturn SC2
Old 09-11-2009, 08:25 PM   #9
Leafy
Leafy's Avatar
thats why I said whole engine, but i guess you'd have to add fuel system and wiring harness. ok so its a pain in the ass, but its possible.
WPI class of '12 ME
Old 09-11-2009, 08:54 PM   #10
Zero_DgZ
Zero_DgZ will become famous soon enough
Anything is possible if you have enough time, guts, and money.
Me, if I were going to pull something like that I wouldn't stop with another Saturn engine. While you're busy swapping out every moving part in the vehicle you may as well but something bigger and with more turbo in there.
'12 Subaru Impreza manual, hatchback, silver.
'99 Chevy Silverado 1500, automatic, with pixel camo. For the [i]discerning[/i] redneck gentleman.
Used to have a '02 SL2 automatic.
Add to Zero_DgZ's Reputation
Rate the quality of this post and help Zero_DgZ reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Zero_DgZ is offline   Reply With Quote
Old 09-12-2009, 12:14 AM   #11
PurdueGuy
PurdueGuy's Avatar
1999 SC1
Sometimes you need to recognize when you don't really know what you're talking about on a subject and just not comment. The wiring is completely different between a 99 and a 93. The only way it could technically be made to work is if you swapped the entire drivetrain, wiring system, fuel system, and likely a good handful of switches.
Old 09-12-2009, 07:58 AM   #12
The oil pressure switch, the knock sensor and anything else other then the CPS is different on the backside of the engine '93-'97. Fuel rail is different, have to use intake manifold that goes with the fuel rail that will work in the generation its going into. And, the only way to get a properly functioning EGR valve that I know of is to go '93 -> later not later -> '93 as they only made the adapter one way. I haven't taken the old EGR off my '93 engine to see whats different on the installed '97 but I will at some point.
Autotragics just plain suck for swapping. 2nd gens kinda suck for swapping 5spds, but only if you want cruise control to work.
FWIW My '93 has a '97 engine, '97 transmission (used to have a '94 but changed it again when I changed engines), '94 PCM and '93 ABS axles. Everything works except the EGR valve so far, well traction control doesn't work but the 5spd PCM's don't know about it until '95.
Transmission Swap gek09 S-Series Tech 5 08-21-2009 11:32 AM
Transmission swap? Mary's Vue S-Series Tech 2 06-23-2007 09:17 PM
Transmission Swap Speedy15 S-Series Mods 8 03-13-2006 10:39 PM
Transmission Swap Anyone? kevinthenerd Ion General 5 01-01-2006 06:28 PM
transmission swap trlla91sl2 Miscellaneous Tech 0 02-04-2002 06:40 PM
