Old 09-10-2009, 01:04 PM   #1
akagdis
akagdis is on a distinguished road
1993 SW2
Default Intermittent speedometer/odometer problems
I rear-ended somebody in my 1993 SW2 about a month ago. I basically damaged my drivers side corner, having the hood, fender and bumper replaced. When I got it back, my speedometer and odometer are now acting up. At highway speeds, the odometer will spin about 2-3 times too fast and speedometer will bounce about 5-10 miles higher/lower. I noticed that these problems will all of a sudden go away, then come back together. On surface streets, the odometer will run too fast also. Any ideas?
Add to akagdis's Reputation
Rate the quality of this post and help akagdis reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
akagdis is offline   Reply With Quote
Old 09-10-2009, 01:30 PM   #2
PurdueGuy
PurdueGuy's Avatar
1999 SC1
Default Re: Intermittent speedometer/odometer problems
I would start by doing a visual inspection of the vehicle speed sensor (VSS), which is above the differential. If you find were the axles enter the transmission, look for an electrical connector going into the trans housing right above there. The VSS reads notches in the differential to determine speed, and sends the signal to the PCM and gauges (might be the PCM then the gauges, not sure). I would suspect a damaged sensor or wire.
SaturnSeries.net owner
Add to PurdueGuy's Reputation
Old 11-28-2009, 09:43 PM   #3
beerhecht
beerhecht is on a distinguished road
beerhecht's Avatar
2008 Astra XR
1993 SC2
I know I'm digging up an old thread, but I have seen this problem several times before. If you open up the instrument cluster, you should see a circuit board right behind the speedometer. Look at the green side and inspect the traces. You will probably see some evidence of heat. There is a small capacitor right next to a larger capacitor that will probably look burned. It is a 63V 10uf cap. If you replace that capacitor, and nothing else was fried, your odometer *should* start working correctly again. I believe that this capacitor regulates voltage. Any electrical engineers out there?
Here's a link to a site that sells the replacement capacitor.
http://www.mcmelectronics.com/product/31-7405
Add to beerhecht's Reputation
Rate the quality of this post and help beerhecht reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
beerhecht is offline   Reply With Quote
help!! no speedometer or odometer !! samiam7156 L-Series Tech 4 05-22-2009 06:29 PM
Speedometer/Odometer Not Working Tom64 S-Series Tech 12 11-27-2007 05:30 PM
Dead Speedometer and Odometer hollywoodspider S-Series Tech 2 08-21-2007 10:32 PM
Sticking Odometer and Speedometer batmobile S-Series Tech 19 07-19-2007 12:41 AM
hesitation and speedometer/odometer problems with my 97 sl stang50 S-Series Tech 24 07-01-2007 10:22 PM
