Old 09-10-2009, 11:13 AM   #1
bshoop13
bshoop13 is on a distinguished road
Dizzy Throttle body cleaning
I have a 2002 saturn sl1 that im gonna be taking the throttle body off of soon to give her a good cleaning and for some reason I am having a problem finding the right gasket for it. Been to 3 places so far including the saturn dealer and got 3 different gaskets that dont look like they will fit at all. Does anyone have a picture or a dealer part number of the right gasket. Thanx in advance for any help.
Add to bshoop13's Reputation
Rate the quality of this post and help bshoop13 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bshoop13 is offline   Reply With Quote
Old 09-10-2009, 11:42 AM   #2
JerryHughes
JerryHughes has a spectacular aura aboutJerryHughes has a spectacular aura aboutJerryHughes has a spectacular aura about
JerryHughes's Avatar
1997 SL
Default Re: Throttle body cleaning
Check rockauto.com for photo and gasket---
http://www.rockauto.com/catalog/rafr...?a=G-autoparts
Old 09-10-2009, 11:47 AM   #3
PurdueGuy
PurdueGuy's Avatar
1999 SC1
Just a heads up, you can usually reuse the gasket. Might not be bad to replace it the first time, as it's got some age/miles on it, but no need to replace it every time you remove the tb.
SaturnSeries.net owner
Add to PurdueGuy's Reputation
Old 09-10-2009, 11:55 AM   #4
WellsWebDesign
WellsWebDesign is on a distinguished road
I just removed and cleaned my throttle body this weekend. 99 SL2, 130k miles. I'm the original owner, and have never cleaned the throttle body (shame on me). My gasket looked great, I was careful in removing the throttle body, and was able to reuse the gasket.
Add to WellsWebDesign's Reputation
Rate the quality of this post and help WellsWebDesign reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
WellsWebDesign is offline   Reply With Quote
Old 09-10-2009, 12:19 PM   #5
OldNuc's Corollary to Murphy's Law states that you will only be able to reuse the gasket if you have a spare one on hand.
Add to madpogue's Reputation
Old 09-10-2009, 12:31 PM   #6
azrocketman
azrocketman is on a distinguished road
azrocketman's Avatar
1997 SL1
I'm going to be the devil's advocate here. The first picture showed a coating of carbon on the throttle body. The second showed a clean throttle body. In reality, for the amount of debris shown, why bother cleaning the throttle body? Was there a problem? Did gas mileage improve? Did emissions go down? Did the engine run "better"? This seems to be a violation of the "If it works, don't fix it philosophy".
Steve
Add to azrocketman's Reputation
Rate the quality of this post and help azrocketman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
azrocketman is offline   Reply With Quote
Old 09-10-2009, 12:39 PM   #7
bshoop13
I wanted to replace the gasket because it looks alittle dark on the top by the gasket, almost like its bad and is suckiing air in there.
Old 09-10-2009, 01:31 PM   #8
WellsWebDesign
Steve
It was your basic before and after picture... I've had a very sticky throttle for about a year or two now. Through these forums, I learned that it was likely due to carbon buildup. After cleaning the throttle body, it no longer sticks, and has been very smooth. I haven't driven enough to tell if gas mileage went up, but it seems like it. Also, the car seems to accelerate a little faster. I cleaned it because I already had the air intake and battery out to replace the ECTS and figured why not? Not sure if it's related, but I was constantly being plagued by P0133 o2 sensor codes, which has not happened since then, granted it has only been 4 days.
"If it works, don't fix it" isn't always sound advice. If I can spend an hour and about $1 for cleaner to hopefully prevent a future problem (always at an inconvenient time), I think that's good advice.
Old 09-10-2009, 01:51 PM   #9
True dat
There's a reason it's called "preventative maintenance"
My shifter bushing works fine, but it's getting replaced in the next few weeks anyway. Third corollary to Murphy's says the bushing will break on the way home tonight
Fourth says that is someone picks up my old bushing and reuses it, it will turn out to be the one indestructible bushing Saturn made...
Old 09-10-2009, 01:59 PM   #10
PurdueGuy
PurdueGuy's Avatar
1999 SC1
Steve
It's simply maintenance on these cars. Not cleaning the throttlebody leads to a sticking throttle pedal and idle issues. It's a piece of cake to clean, and prevents headaches. So it's more of a "if it works, just wait and do nothing, and it'll give you issues later" kind of thing. And the idle issues a dirty tb can cause can cause fuel economy issues, so it's worthwhile in economic terms, too.
Old 09-10-2009, 05:59 PM   #11
Tiger
Tiger's Avatar
I will be another devils advocate. I have never removed my throttle body. Just cleaned it on the car. I have a silky smooth idle. It is a regular maintenance item. If I had problems with the idle air control valve then I would remove it. So, my recommendation is clean it without removing it. If that does not get the needed results, remove it and clean it.
I doubt any dealer or repair shop will remove it to clean it.
Add to Tiger's Reputation
Old 09-10-2009, 06:22 PM   #12
Zero_DgZ
Zero_DgZ will become famous soon enough
On my '02 DOHC, removing the throttle body to clean is easy, but annoying. Two of the four bolts require using a long socket extension, and the other two require a shorter one so you don't hit the underside of the hood. And all of it requires leaning over to the geometrically placed hardest to reach location in your engine bay.
On the plus side, the gasket on mine is a charming shade of neon orange and seems quite resillient. It's survived two or three cleaning jobs (that I can remember, anyway) without incident.
Add to Zero_DgZ's Reputation
Rate the quality of this post and help Zero_DgZ reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Zero_DgZ is offline   Reply With Quote
Old 09-11-2009, 08:44 AM   #13
TXSaturn02
TXSaturn02's Avatar
BTW, that is the recommendation of the legendary Wolfman as well...
New owner As of 01/01/18: 225,000 Miles
As of 05/10/18: 48,065 Miles
Old 09-11-2009, 11:17 AM   #14
Growser
Growser is on a distinguished road
Growser's Avatar
I've done a bunch of throttle body cleanings and always used the old gaskets without issues until this past weekend. When I reused the old gaskets on two this weekend both failed and with 3,000 + rpms you know you have a problem. You just never know.
7 Saturn Car Family with + 900,000 miles.
2002 SL2, 2000 SL1, 1997 SC2, 1997 SC1, 1996 SC1, 1994 SC2, and now a 93 SC2 project car.
Add to Growser's Reputation
Rate the quality of this post and help Growser reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Growser is offline   Reply With Quote
Old 09-11-2009, 05:55 PM   #15
saturnsctwo
holly christ! i'm surprised your throttle actually wasn't stuck closed! that things DIRTY!
Old 09-11-2009, 05:58 PM   #16
saturnsctwo
that's what i also do. i just spray some carb cleaner down it & scrub around with a tooth brush. especially where the throttle valve opens & closes. that's where it sticks. then wait a little while while the spray cleaner evaporates then the car runs fine...
Throttle body cleaning RobertGary1 S-Series Tech 8 04-08-2015 07:58 PM
Throttle Body Cleaning Vs. Fuel Injection Cleaning TXSaturn02 S-Series Tech 7 05-28-2008 03:56 PM
cleaning the throttle body redcannon S-Series Tech 8 01-29-2008 01:59 AM
Throttle Body Cleaning? LotusLord S-Series Tech 2 09-25-2007 06:43 PM
throttle body cleaning justVUEit S-Series Tech 8 06-10-2006 08:39 PM
