#1 | ||||
Last night, after turning off my VUE 5-speed, I heard and "winding down" noise... like a plane landing kind of sound that lasted about 5 seconds after the engine is stopped. I restarted and opened the hood and saw the cooling fan was on so I assumed it was the sound of the Fan winding down... however, I drove the car into Saturn Service less than a mile away this morning and in the lot, it happened again when shutting down. I doubt the car was hot enough after that brief ride for the cooling fan to be on. I heard the SAME EXACT sound on my old Mercury Sable when shutting down and was "told" it was my torque converter.... but that obviously isn't the case here. As some of you know, I've had a HARD time getting my new VUE into 1st gear... do you think this is related? The car only has 300 miles and I'm so worried it is something major with the tranny or something... I really don't want a one-week old car to have an engine/tranny pulled apart or something. Anyone heard of this issue? Any suggestions?
#2 | ||||
![]() Join Date: Feb 2002
Did you have your defrost on? My car makes the same noise when I shut it off and have either A/C or Defrost on. The compressor is winding down.
--Nick
#3 | ||||
![]() Join Date: Dec 2002
If its reproducible, pop the hood and have someone stand by it as you shut it off. (to see where the sound is coming from)
Was the whirring sound mechanical like something in the tranny spinning, or was it more like a fan blade? What's the problem getting it into first gear? If its when your going 15mph+ (like coming up on a stop sign) it could be the syncros in the tranny. If so, wait till your slowed down or don't push so hard on the shifter. -Joe
#4 | ||||
Problem solved guys.... there was a "STALL" error code that when cleared turned the cooling fan off.... it was running continuously.
#5 | |||||
- Tatusmi
#6 | ||||
It's not the compressor.... the compressor stops turning when the engine does. The noise you hear is the cooling fan winding down. When the AC Compressor is on, the cooling fan comes on as well.
#7 | |||||
![]() ![]() Join Date: Apr 2002
2002 VUE 2.2L
~D.J.~ ... 2002 VUE FWD4m - 105K -Power Pkg/Sunroof/CD/Alloys/Head Curtains 2008 smart fortwo Passion Coupe - 8K miles -White/Silver/Black Heated Leather -Alarm/Fogs/Comfort Pkg/6 Disc/Audio Pkg/Tach
#8 | ||||
![]() Join Date: Feb 2000
Most A/C compressore these days use swash plates to operate their pistons They don't even have a crankshaft with connecting rods that could maintain some inertia. Maybe the pressurized R134A keeps the pistons moving, causing the swash plate to wobble, giving the impression that the compressor is still turning. After the system loses pressure, the swash plate would stop wobbling. Sound plausible?
#9 | ||||
I can only speak for me.... but the sound I'M talking about sounds like a plane landing... whining that lasts 5-10 seconds after shutdown. It was, indeed, the cooling fan. I've worked on cars all my life and have NEVER heard of an AC compressor "spinning" down after the car stops.... in fact, a number of car makers actually engage the AC as the engine is turned off to prevent run-on as the drag will stop a 4-cyl. dead in it's tracks. But an AC compressor turning 20 seconds after a motor stops? If it spins that easily, it wouldn't drag down an engine while driving. HOWEVER...... when the engine stops with the AC running, you WILL hear the sound of pressurized gas in the system hissing away for 15-30 seconds. That's normal, and it can be loud, but it's not the compressor spinning down.
| Thread Tools | |
| Display Modes | |
| Popping Sound When Turning | oceanjoe89 | S-Series Tech | 4 | 06-26-2006 12:22 PM |
| Groaning Sound When Turning Steering Wheel | bklyn87 | L-Series General | 10 | 01-05-2006 05:27 PM |
| 95' SC1: Strange noise when going over bumps and sometimes turning. | JasonRW | S-Series General | 19 | 08-31-2005 11:34 PM |
| Creeking sound when Turning | DMK's Vue | Vue General | 10 | 06-21-2003 10:50 AM |
| Strange Sound When Turning-Off VUE. | jmatero | Vue General | 9 | 12-11-2002 11:12 AM |
