Old 09-06-2009, 03:51 PM   #1
saborstorm
saborstorm is on a distinguished road
Default P0141 Code, Replaced the O2 Sensor and still throws it?
P0141 Code, Replaced the O2 Sensor and still throws it? I have replaced the O2 sensor 3 times and for the first week or so no Check Engine light, afterwords it comes on and throws the same code. To me it seems like the sensor cant go bad in a weeks time on three different occasions. I'm thinking there is a short in the wiring harness. Anyone else having this same problem?
This is a 1997 SC1
Add to saborstorm's Reputation
Rate the quality of this post and help saborstorm reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
saborstorm is offline   Reply With Quote
Old 09-06-2009, 04:39 PM   #2
Default Re: P0141 Code, Replaced the O2 Sensor and still throws it?
Have you checked the heater resistance of one of the "failed" O2 sensors? Nominal value is 12 ohms. With the Key ON, pin D in the connector on the cradle should be a steady 12vDC (battery voltage). And pin C is the PCM controlled ground point. Do not try cleaning or greasing the plug or socket as that will render the sensor ruined.
P0141 Code Will Not Go Away! sr20fd3st S-Series Tech 8 10-31-2009 02:17 PM
Code P0141 O2 Sensor, Do I need to replace? cdog999 S-Series Tech 25 07-11-2009 07:13 PM
Vehicle Speed sensor replaced and still throwing code. Triggamane S-Series Tech 11 05-17-2009 03:06 PM
P0141 code marchand6@veriz S-Series Tech 4 07-27-2008 09:04 AM
p0141 02 sensor danny10301 S-Series Tech 6 09-10-2007 07:34 AM
