Old 09-05-2009, 12:20 PM   #1
txsaturnvue2003
txsaturnvue2003 is on a distinguished road
2003
Default Hub Bearings - 2003 Saturn Vue
I have an '03 Saturn Vue with nearly 90K miles on it. The rear hub bearings are humming, and the noise level increases with speed.
Is this something which I will have to visit the dealer to fix or can I take it to another shop? Any recommendations and approximate cost of this type of repair would be helpful.
Thanks!
Add to txsaturnvue2003's Reputation
Rate the quality of this post and help txsaturnvue2003 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
txsaturnvue2003 is offline   Reply With Quote
Old 09-05-2009, 02:13 PM   #2
IMkenNY
IMkenNY is on a distinguished road
Default Re: Hub Bearings - 2003 Saturn Vue
Most shops are set up to replace hub bearings (readily available on the aftermarket)
I would expect the repair cost would be in the $300 range per bearing.
All it takes is one bad bearing to make the Vue louder than a tank.
Add to IMkenNY's Reputation
Rate the quality of this post and help IMkenNY reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
IMkenNY is offline   Reply With Quote
Old 09-05-2009, 02:37 PM   #3
txsaturnvue2003
2003
No kidding. The noise is driving me nuts (literally).
I have used National Tire & Battery for oil changes, battery replacement, alignment, rotations, etc in the past. Should I trust them with this type of repair?
Thanks!
Old 09-05-2009, 03:16 PM   #4
1saxman
I'd take it to the lowest-priced place that was half-way decent. It's not a high-tech job but usually requires shop tools to get the hub out.
Add to 1saxman's Reputation
Old 09-06-2009, 02:52 PM   #5
VTchemist
VTchemist's Avatar
I, like most 2003 owners, have struggled with the issue hubs and bearing. The best solution is to replace the whole assembly. You can find it at RockAuto.
I though about a DIY, but I don't have the proper tools to do it. So, each time (3) I've let my local mechanic replace them. Costs are around $350, parts and labor (for here is SW VA).
I read a post one time about a owner that was determined to crack open the assembly and just replace the bearings. He succeeded, but it was longer than a one day project.
Hope this helps.
Add to VTchemist's Reputation
Rate the quality of this post and help VTchemist reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 09-06-2009, 10:28 PM   #6
txsaturnvue2003
2003
VT, can you post a link to the part I will need? I have the name of a really good automotive repair shop, but want to make sure I order the correct part. Thanks!
Old 09-08-2009, 01:30 AM   #7
BryanF
BryanF is on a distinguished road
Do a search for the Timken hub assembly for your Vue. The part # will depend on whether you need front or rear, and whether or not your Vue has ABS. Rockauto.com seems so have prices that are hard to beat, but you can expect to pay about $95-$110 a piece, again depending on if you have ABS or not. This is for the part only, no labor or installation.
If you think you'll be driving your Vue for a long time, pay a couple extra bucks for the best quality part you can afford. After having two bearings go bad by 42,000 miles, I replaced all four hubs on my Vue with the Timken replacements. I've heard that the Timken's are better than the OEM bearings (I guess I'll let you know about 40,000 miles from now ), but this is the kind of thing you'll only want to have to deal with once, rather than using the cheaper part and experiencing a failure again this time next year.
'05 VUE AWD w/Honda 3.5L V6
Add to BryanF's Reputation
Rate the quality of this post and help BryanF reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
BryanF is offline   Reply With Quote
Old 09-10-2009, 11:48 AM   #8
mariopalumbo
mariopalumbo is on a distinguished road
2003 VUE 2.2L
1998 SL1
Timken is the OEM part. Check out rock auto or Autpartswarehouse both have good prices and price match each other. I have replaced 3 of my own (2 rear and 1 front), the rear is very simple without any special tools required. the hardest part is taking the rusted drum off of the shoes. Can be done in 2-3 hours for a first timer less than 45 minutes after that. The front is a different story with more specialized tools required and the front hub having aluminum corrosion issues.
Add to mariopalumbo's Reputation
Rate the quality of this post and help mariopalumbo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mariopalumbo is offline   Reply With Quote
Old 09-10-2009, 09:21 PM   #9
txsaturnvue2003
2003
Is there a way to tell which one needs to be replaced? It is hard to tell even with the windows rolled down. Should I just bite the bullet and replace both of the rear ones?
Thanks for the help guys!
Old 09-11-2009, 12:24 PM   #10
mariopalumbo
2003 VUE 2.2L
1998 SL1
Have someone sit in the backseat with the windows open (radio off) and drive at about 60-70 km/hr and listen for it. There are a lot of posts talking about driving in a parking lot doing s-turns. I can't remember which way something along the lines 'If you turn left and hear the noise and if you turn right and the noise goes away it is the right bearing' but you need to verify. Don't replace both unless you have to. Worst case you change the wrong bearing and reaplce the bad side with the bearing you removed. I did that once several years ago with my Chevy Corsica. it's alot faster the second time around
2003 ion front hub/bearings with abs kbg1 Ion General 2 12-25-2009 10:13 AM
Hub Bearings? jeffkics Vue Tech 23 07-02-2009 12:47 AM
How do you remove / replace hub bearings on Saturn SC1 2002? travisj027 S-Series Tech 2 12-25-2008 07:37 PM
2003 Vue Front Bearing Hub assembly MikeR1 Vue General 1 02-01-2006 10:36 PM
Replacing Hub Bearings The Budman S-Series Tech 5 11-24-2005 01:04 PM
