Old 09-03-2009, 01:53 PM   #1
Crazy C
Crazy C is on a distinguished road
Crazy C's Avatar
1993 SL2
Default Clicking while braking
Yesterday while in stop and go rush hour traffic around town I noticed that when I was slowly coming to a complete stop there was a clicking noise coming from the front brakes. It sounded almost as if there was something stuck in the rims.. I would describe it like if you were to put something in the spokes of a bike. I inspected it when I got where I was going but didn't see anything caught in the wheels, so now I'm just curious what's causing this noise. The brakes seem to be working fine too, but could this be some kind of a warning that they're worn? I can't say I've ever heard a clicking noise like this before, and I don't want to take any chances with the brakes.. Any thoughts on what it could be?
1993 Saturn SL2 (162,271 miles): The One and Only
1995 Saturn SL2 (153,800 miles)
2003 Chevrolet Cavalier LS (150,500 miles)
Support the American auto industry! Long Live General Motors.
Add to Crazy C's Reputation
Rate the quality of this post and help Crazy C reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Crazy C is offline   Reply With Quote
Old 09-03-2009, 10:14 PM   #2
SLCraig
Default Re: Clicking while braking
There could be a few causes of this..
Number one for me (in my experience)... grime and crud in between the brake rotors and the hub itself. Whenever I do a brake job, I always clean up the mating surfaces really well, otherwise there WILL be a clicking sorta noise while coming to a stop.
Second thing I've had make such noise although you say front end, was a leaking wheel cylinder in the rear. Probably brake fluid getting onto the braking surface causing a strange coefficient of friction. New wheel cyl and some brake cleaner. No more noise.
I'm slowly becoming an expert on brakes..
Have you pulled a wheel and given it a quick visual?
Either way some suggestions to think about.
1996 SL2 5MT
1997 SL1 5MT
2000 SW2 5MT
All gone, but not forgotten.
Add to SLCraig's Reputation
Rate the quality of this post and help SLCraig reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 09-07-2009, 03:12 PM   #3
Crazy C
Crazy C's Avatar
1993 SL2
SLCraig,
Thank you for your excellent suggestions! I haven't gotten a chance to take the wheel off for a visual or jack it up yet to get underneath it, but I have peeked under the car without finding anything.
Your number one suggestion sounds very possible, although I did just use brake plate cleaner a few months back.. Is it likely for all that grime and crud to build up in a short amount of time?
As for your second suggestion, if that were the case, wouldn't I be low on brake fluid? Because I checked that and the level seems fine.
I just don't want anything to go wrong with my brakes, you know?
Old 09-08-2009, 05:43 AM   #4
97sl2DOHCaut1.9
97sl2DOHCaut1.9 is on a distinguished road
do you have plastic wheel covers ? (dont know what they are called). If so , take them off and drive the car to see if the noise is gone
Add to 97sl2DOHCaut1.9's Reputation
Rate the quality of this post and help 97sl2DOHCaut1.9 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
97sl2DOHCaut1.9 is offline   Reply With Quote
Old 09-09-2009, 03:19 PM   #5
Crazy C
Crazy C's Avatar
1993 SL2
97sl2DOHCaut1.9,
No, I do not.. I have rims on my '93 and '95 SL2. Thanks for the suggestion though, I have plastic wheel covers on my Cavalier and if the lug nuts get loose that does cause clicking and rattling.
Old 09-09-2009, 03:23 PM   #6
2NDSOUT
2NDSOUT's Avatar
1999 SL
When was the last time you had the brakes done?
Could be a caliper...brake shoe worn....bad rotors...
Only way is to remove the front wheels and take a look.
Bryan
94SL2 HCE, "Pearl"
99 SL
94SL2 260K Miles
1/15
97SW2 266K Miles
2/15
Always
94SC1 340,501 Miles
Org. Engine/Auto Trans
2/97-10/08
Gone 3/12
92SL1
05VUE
91SC
Add to 2NDSOUT's Reputation
Old 09-09-2009, 03:51 PM   #7
Does the car have ABS?
Add to madpogue's Reputation
Old 09-13-2009, 12:32 PM   #8
Crazy C
Crazy C's Avatar
1993 SL2
2NDSOUT,
I believe it has been about a year or so since I got my brakes done.. But as I said, I can still seem to brake just fine. Only problem is it makes a clicking and knocking noise sometimes when I'm coming to a stop.
madpogue,
Yes, the car does have ABS.
Old 09-14-2009, 09:55 AM   #9
Could it just be the ABS kicking in? If it is, it indicates a problem, probably with a wheel sensor incorrectly feeding a different speed to the ABS. Try this - remove the ABS fuse or relay (relay is in the underhood fuse box; I _think_ the fuse is there, too) and test. ABS light on the dash will come on, and of course, you'll have no ABS, but see if the noise continues or goes away. This will at least rule the ABS in or out.
Old 09-14-2009, 12:28 PM   #10
Crazy C
Crazy C's Avatar
1993 SL2
By the way, I totally forgot to mention this is on my '93. I apologize, sometimes I forget to say which one I'm speaking of.
madpogue,
I suppose there's a chance it could be, but wouldn't the wheels be locking up then? Because there definitely doesn't seem to be any of that. I could still test it to rule that out though, and I really appreciate your suggestion either way.
Old 09-14-2009, 12:46 PM   #11
No, quite the opposite. The ABS backs off the brakes, each (front) wheel separately, to keep them from locking up. It shouldn't do that _until_ it senses the wheels locking up, but I'm thinking that's what it's doing, falsely, because of a sensor or wiring issue.
Old 09-14-2009, 01:16 PM   #12
PIYIRIO
PIYIRIO is on a distinguished road
I think that would cause a pulsing sensation like a warped rotor. You never know though. Like every one's mentioned, pull the tire and see if anything is obviously wrong, otherwise you're literally flying blind. Check the caliper bolts, they could have loosened. I've had that happen before and it causes clicks and pops.
Add to PIYIRIO's Reputation
Rate the quality of this post and help PIYIRIO reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
PIYIRIO is offline   Reply With Quote
Old 09-14-2009, 01:37 PM   #13
My ABS have kicked in "for real" several times, and I don't really feel it in the pedal. The pulsing is all done from the ABS controller, which is downstream from the master cylinder, and since it could be doing only one of four wheels, you might not get any pedal feedback. If anything, about the only feedback I get is that the pedal goes _down_ a bit.
Old 09-14-2009, 01:42 PM   #14
PIYIRIO
Hmmm, I can feel it in my wifes CRV... all through the car, not just the pedal. Maybe its just the heightened senses and slowed time of an extreme "butt-pucker" moment.
Old 09-14-2009, 08:52 PM   #15
SLCraig
SLCraig,
Sorry for the delay in response. I was in Nova Scotia for a week. Beautiful place!
I was not low on brake fluid when I replaced my wheel cyl. When the noise started, it had just started to leak. It was not leaking enough fluid to appear low yet at that point.
As for the brake grime/rust issue.. It's really only normally an issue when the brakes are off, and reinstalled. If the brakes hadnt been off, its likely not the issue.
Just need a visual for sure.. Perhaps it could even be a crack in the brake rotor... or something as dumb as loose wheel lugs.
1996 SL2 5MT
1997 SL1 5MT
2000 SW2 5MT
Old 09-16-2009, 12:44 AM   #16
Crazy C
Crazy C's Avatar
1993 SL2
madpogue,
Thank you for explaining that to me, I had no idea that was how it worked. That definitely sounds like that could be the culprit.
PIYIRIO,
Will do, I will check that. I haven't had the time to pull the tire yet, but I will make sure to do it soon.
SLCraig,
No need to apologize! I've never been to Canada, but I hear great things about it and would love to go one of these days. Anyway, I definitely do not appear to be low on brake fluid, and the brakes haven't been off and then reinstalled. I suppose I am going to need to get a visual to investigate this further.
The weird thing is I did plenty of driving today and there was no clicking or knocking coming from the brakes at all!
Old 10-13-2009, 03:33 PM   #17
SLCraig
Hey there, just wondered if there were any updates on this Crazy C?
1996 SL2 5MT
1997 SL1 5MT
2000 SW2 5MT
Old 01-27-2010, 10:35 PM   #18
ShawnV
ShawnV is a jewel in the roughShawnV is a jewel in the roughShawnV is a jewel in the roughShawnV is a jewel in the rough
ShawnV's Avatar
2003 VUE 2.2L
I'm currently experiencing this problem with my 1996 wagon 184k. There is a clicking or ticking when I slow. The clicks progressively space out as I slow to a stop. From reading, I think it may be rear pads, cylinder, or rear sway bar links.
I recently moved to NC and am finally settled. I'm planning on putting on 4 new struts, rear sway bar, rear brakes, ball joints, tie rod ends, and anything else I see in there.
Add to ShawnV's Reputation
Rate the quality of this post and help ShawnV reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ShawnV is offline   Reply With Quote
Old 01-28-2010, 12:09 AM   #19
Your car most likely has rear drums, not discs. Very few, if any, wagons of that era were issued with rear discs.
Does the noise occur when coasting to a stop, or only when braking? In gear, in neutral or both? Automatic or manual transmission?
Old 01-28-2010, 01:21 AM   #20
SLCraig
Sounds just like the noise I had.. was a bad wheel cyl.
1996 SL2 5MT
1997 SL1 5MT
2000 SW2 5MT
braking anomaly shadestalker S-Series Tech 8 11-13-2008 01:38 PM
Clicking in dash when braking gunny1 S-Series Tech 2 11-06-2006 10:02 PM
Engine braking BonziBuddy S-Series General 0 07-24-2006 09:03 PM
New 2004 V6 VUE Clicking When Accelerating, Braking mchinn Vue General 10 12-05-2003 12:59 PM
Clicking noise when braking to a stop? MarkW General Saturn Discussion 9 07-18-2002 07:17 PM
