Old 09-02-2009, 09:37 PM   #1
Noogit
Noogit is on a distinguished road
1992 SL1
Default Loud squealing in reverse.
Okay, i just bought a '92 SL1. 5spd. Everything is stock. When i start the car after a day or so of sitting, and put it in reverse, it squeals rather loud. My neighbor heard it from inside his house. As soon as i push in the clutch to shift to first, it immediatly stops. Friend who owns a '94 says trans. fluid, but i checked it, and it's all good. Anybody know what might be the cause?
Stock '92 SL1.
Mods to come...
Add to Noogit's Reputation
Rate the quality of this post and help Noogit reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Noogit is offline   Reply With Quote
Old 09-02-2009, 10:10 PM   #2
Default Re: Loud squealing in reverse.
Everything is stock? This might simply be a worn out belt tensioner; if you can depress the belt between the pulleys easily then the tensioner is worn out. A '92 with 17yr old parts that old cannot last forever. Is the belt original? A worn belt tensioner allows the belt too much slack so the crank pulley squeals against the belt that's restrained by the accessories its supposed to be turning; alternator, power steering pump, and water pump.
Old 09-02-2009, 10:21 PM   #3
Col.FUBAR
Col.FUBAR is on a distinguished road
Col.FUBAR's Avatar
1994 SC2
I don't know if you could confuse this or not but my 94 is also a 5 spd. and mine whines quite loudly the faster I go in reverse as long as the clutch is engaged. The only other car that I have had that was a manual was my Geo Metro and it made same whining noise in reverse when the clutch was engaged.
Former DD: 1994 SC2 5spd. 190K, being sold to a friend
2005 Saturn ION 2 5spd. 73K
1995 Aquamarine SL2
1.9L DOHC 5spd. ~125K Miles
Add to Col.FUBAR's Reputation
Rate the quality of this post and help Col.FUBAR reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Col.FUBAR is offline   Reply With Quote
Old 09-02-2009, 10:30 PM   #4
Oh, maybe I'm the one confused. Gear whine from reverse gear running parts of the transmission backwards with poor meshing causing the noise being confused with belt squealing? Hmmmmm.........
Old 09-02-2009, 10:40 PM   #5
Col.FUBAR
Col.FUBAR's Avatar
1994 SC2
I'm not positive of the noise (this is of course a forum and it is hard to describe sounds over the interweb) but I just thought I would throw my hat in the ring
1995 Aquamarine SL2
Old 09-07-2009, 09:19 PM   #6
Noogit
1992 SL1
The whine your talking about is not the one im talking about. You're talking about the one that sounds like an RC car?
This one is louder and higher pitched.
I think it is the tensioner.
About how much does one cost?
Thanks for the input.
Stock '92 SL1.
Mods to come...
Old 09-07-2009, 10:11 PM   #7
Go to rockauto.com or saturnparts.net online to price them. Its recommended to buy the metal idler pulley and not the plastic one.
98 SL2 is sounding loud & especially in reverse, any info? destro5 S-Series General 5 01-08-2010 10:40 AM
99 SW1 When put in reverse loud clonk car jerks marionr26 S-Series Tech 1 04-02-2009 08:47 PM
Loud squealing sound. hit_n_run S-Series General 2 05-19-2007 12:07 PM
squealing noise only in reverse Debbie Haake S-Series General 5 12-13-2006 05:34 PM
REALLY LOUD *THUNK* when putting into reverse! Commuter_Crazy S-Series Tech 4 05-20-2006 05:10 PM
