Old 08-30-2009, 12:15 AM   #1
brycecrispy
brycecrispy is on a distinguished road
Default Rad fan seems to shake when on!
This just started happening today. The cooling fan seems to be shaking and vibrating and got very loud. Can this be tightened up to make this stop. Also went over halfway on temp gauge for the first time when this happened. Thanks in advance.
Add to brycecrispy's Reputation
Rate the quality of this post and help brycecrispy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
brycecrispy is offline   Reply With Quote
Old 08-30-2009, 01:02 AM   #2
saturnsctwo
Default Re: Rad fan seems to shake when on!
sounds like your fan motor just bit the dust. turn on the a/c & observe it. see if it's doing anything strange, or anything at all....
Old 08-30-2009, 08:04 AM   #3
brycecrispy
The fan kicks in around halfway up the gauge(which is when it always did). Comes on when I turn the air on as well. However the whole casing and fan shake like mad now when the fan comes on. Maybe it is on it's way out, but I was wondering if there was a chance it could have come loose and if so can it be fixed. Thanks again I appreciate any info on this.
Old 08-30-2009, 08:24 AM   #4
DonP
Sounds like an out of balance fan blade, perhaps a piece broke off for some reason. That may cause the fan bearings to fail in short order.
Add to DonP's Reputation
Old 08-30-2009, 09:42 AM   #5
Signmaster
Check the mounting points to make sure everything is solid, then from there see what is shaking/wobbling/whatever.
My guess is that the fan motor is gone. Check for broken blades etc as DonP stated to make sure you get what you need to fix it right the first time.
Old 08-30-2009, 02:10 PM   #6
saturnsctwo
that's what i was about to post, something's damaged like a piece of the fan maybe broke off causing an out of balance fan. it sounds like the fan needs to be replaced as well, maybe someing from a junkyard would be good...
Old 08-30-2009, 06:40 PM   #7
brycecrispy
Thank you everyone. This will be a great place for me to start.
Old 08-31-2009, 02:03 AM   #8
hholbein
1997 SW2
Check out Richpin's Youtube videos dealing with Radiator & Radiator Fan R&R. Very informative, and might give you ideas about what attachment points to check on the fan housing.
Add to hholbein's Reputation
rad fan will not turn on pippo S-Series General 9 10-14-2009 07:20 AM
help with rad fan issue bgrpph S-Series Tech 14 07-14-2009 07:43 PM
Rad. Fan did not turn on p-ROCK S-Series General 6 03-07-2008 06:08 PM
Rad fan aux. kingvandal S-Series Tech 5 12-18-2006 04:15 PM
occasional rad fan problem? horsesaslife S-Series Tech 6 06-13-2006 05:55 PM
