Old 08-23-2009, 03:36 PM   #1
Darren1970
Darren1970 is on a distinguished road
Idea Random no start fixed!
Ok everyone, thanks for your replies and I replaced the CPS last week. Not a bad job on that 2000 LW2. Car has been starting/running well since.
Next problem is one I forgot about... seems minor, but anyone got any clues to why the "Service" and "security" lights come on the dash when going down the road? Car is running fine when we notice that. A dirty contact somewhere? The repair demons still lurking? Will wait for response!!
Thanks everyone!
Add to Darren1970's Reputation
Rate the quality of this post and help Darren1970 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Darren1970 is offline   Reply With Quote
Old 08-23-2009, 03:56 PM   #2
Default Re: Random no start fixed!
If the service engine soon light doesn't stay on long enough to stop by Autozone for their free scanning of error codes (write them down for posting here), about the best you can do for now is removing the battery negative cable for 5-minutes to reset any, er, anomalies when the cps went nuts. Sometimes electronics acts like we do and hold grudges by refusing to go along with the program and in this case the cps sometimes generate other issues downstream where sensors and diagnostics clash generating odd ball trouble codes that stay in memory. If this is the case, simply resetting the ECM memory (where the errant codes reside) erases them to have the ECM start all over again. At best, this doesn't come back and at worst it reappears to indicate other gremlims haven't been chased away.
When the cps was replaced, did you make sure it was seated all the way into its hole before tightening its mounting bolt? Some have mistakenly bolted their cps incorrectly without checking that it seated completely, leading to more problems until it was discovered it wasn't seated correctly. The little gap left caused more intermittent engine issues.
Old 08-25-2009, 07:38 AM   #3
etp26
etp26 is on a distinguished road
Thanks everyone!
"service" light or "service wrench" light?
If its the "service wrench" light and "security" light then I have the same problem. Hope someone has some answers.... Probably a bad BCM again.
Add to etp26's Reputation
Rate the quality of this post and help etp26 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
etp26 is offline   Reply With Quote
Old 08-25-2009, 08:45 AM   #4
Guessing what the service/wrench service indicators means is doing things blindly.
1-The service light means almost any reader can decode stored errors. Tried Autozone? Generic error codes are typically P0xxx.
2-The service wrench light cannot be read by any reader except the pricier ones (like Saturn's) capable of reading manufacturer specific codes. These codes are P1xxx. Some members have spent ~$300 for their readers.
Random so start! Darren1970 L-Series Tech 3 08-19-2009 10:46 AM
Saturn SL-1 random failure to start whooki S-Series Tech 6 04-08-2009 04:24 PM
Random no start issue ob1 S-Series General 19 02-12-2009 11:03 AM
99 SL2 will not start - FIXED brianp101 S-Series Tech 4 12-09-2008 09:17 AM
I fixed a P0300 service engine light (intermittent random cylinder miss) c5f8 S-Series Tech 3 11-09-2007 12:00 PM
