what's new (beta) - classifieds - forums - links - photos
Go Back   SaturnFans Forums > Models > Saturn L-Series > L-Series Tech
Register Blogs FAQ Members List Calendar Chat Room Search Today's Posts Mark Forums Read
Old 08-16-2009, 10:24 AM   #1
matzkemd
matzkemd is on a distinguished road
Default Radiator cooling fans run continuously
My 2003 L200 (110k miles) is continuously running both radiator cooling fans (pusher and puller) whenever the engine is on, cold or hot, A/C on or off. They don’t run with key-on/engine-off. I replaced the engine coolant temperature sensor before digging any deeper and the problem is unchanged. The temp gauge reads the same as always, the engine appears to heat up normally, and the thermostat opens at operating temp (by observing the temp gauge and feeling radiator hoses). I haven’t driven the car since but the engine idles fine.
My next step was the Fan Control Module, thinking that a relay was stuck. I took the circuit board out and actuated all 5 relays: each of them happily clicked back at me so this doesn’t appear to be the problem. I gave the FCM a technical tap against the workbench for good measure, no luck there either. The FCM has 10 wires: 2 large gauge wires are power in, 6 large gauge wires are power out and ground to the fans (3 each), and I’m left with 2 small gauge wires (dark blue and dark green) which read 12V with engine off and 0V with engine on and fans running.
Are these control wires from the computer? If so, what should they be reading for which fan speeds? Does the computer use the coolant temp sensor to determine fan speed?
Also, if the computer thought the engine was hot and was protecting itself, wouldn’t the fans stay on after the engine shuts off (I think I remember this from our last road trip through the desert!)?
I’m open to ideas and very much appreciate any ideas you might suggest!
Thank you!
Mark
Add to matzkemd's Reputation
Rate the quality of this post and help matzkemd reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
matzkemd is offline   Reply With Quote
Old 08-16-2009, 11:28 AM   #2
fdryer is a splendid one to beholdfdryer is a splendid one to beholdfdryer is a splendid one to beholdfdryer is a splendid one to beholdfdryer is a splendid one to beholdfdryer is a splendid one to behold
Default Re: Radiator cooling fans run continuously
Answers; yes, yes, yes, and maybe. Whatever. You ask too many questions.
Does this help? (below) And as a small favor, if you fix this problem, would you post some pictures of the opened FCM? You're the only one willing to open one up and go through the pin outs and this helps me to visualize what mine looks like if I ever have to dissect one. Yes, I'm selfish. Why would I open mine when yours is already opened? Ok, ok, seriously, it may help anyone with similar fan control module issues by having at least one opened for view.
The ECM determines which fan speed to run based on the coolant sensor information. Its not likely to be the coolant sensor but somewhere between the ECM and fcm. I haven't studied the drawing yet as I felt you needed the schematic now. It gives me some time to stall for a possible answer unless somebody else knows.
BTW, I'm old school and very much a "technical rap against the workbench for good measure" kind of technician. You'd be impressed when I steam cleaned circuit boards years ago...........................and they all worked.
The CPS is the heart of the entire EFI system. No cps = dead EFI system.
There's more to a/c than just a few cans of refrigerant.............
Old 08-16-2009, 03:43 PM   #3
matzkemd
Attached are pictures of the opened L200 fan control module. I took one with the connnectors attached so wire colors are visible. According to the diagram (thank you very much!) the V6 has an extra wire and some slightly different wire colors. I labeled the control terminals for the 5 relays (from memory, but I'm pretty sure these are correct) for someone's future reference.
Thanks,
Mark
Old 08-16-2009, 04:13 PM   #4
Thank you. The two pictures gives me, at least, a better sense of what the schematics portray.
There's a remote posibility, if you have a/c, of the combination low/high pressure switch interfering by sending incorrect signals, alerting the ECM to run the fans. Since our a/c systems will have three speeds and use both cooling fans in combination to select L, M, or H speed cooling, the a/c pressure switch may be one consideration here. The question is whether or not your a/c system is working, was being used at the time or if its disabled/broken. Other than pulling the battery negative cable or the IGN fuses to reset the ECM, I can't think of anything to have the fans running. Can you estimate what speed the fan(s) are running?
Old 08-16-2009, 04:25 PM   #5
matzkemd
Thanks again for the help. Fans are running high speed. Can I disconnect the A/C pressure sensors to troubleshoot them? I hear the compressor kick on/off as I cycle the climate control: this has no affect on fan speed (currently).
I think I verified the FCM is operating correctly. I rigged some jumpers between the blue connector and the FCM (which contains the 2 control wires). The computer is trying to ground both these wires as soon as the engine is turned on (checked continuity on the meter). Playing with the jumpers verified how fan speed is selected:
Neither control wire grounded = fans off
Drk Blu wire grounded = both fans low
Drk Grn wire grounded = both fans medium
Both control wires grounded = both fans high
Problem must be outside the FCM.
Old 08-16-2009, 05:13 PM   #6
You're good, very good. Theoretically, just shuting off the a/c should not have the pressure switch interfere with the ECM running the cooling fans but off the top of my head I think its ok to disconnect the pressure switch to isolate it from this problem. If I'm wrong you'll know before I do. The pressure switch is just another input sensor for the ECM in determining fan turn on/speed.
Old 08-16-2009, 06:59 PM   #7
matzkemd
Success! Unhooked the battery for 30min. On restart and test drive to town (20miles) everything works perfectly! Fans operating at normal speeds (off, then low, then medium) in 90deg weather. Thanks for the help, and I hope my explorations of the FCM can help someone else down the line.
Thanks, fdryer!
Old 08-17-2009, 05:52 PM   #8
SatL200M
SatL200M is on a distinguished road
SatL200M's Avatar
2006 VUE Red Line
If the problem comes back it may be a bad Intake air Temp sensor. Have had to replace two on our 03 L-200 as soon as the sensor was replaced problem was gone. It will evently throw the check engine light.
Add to SatL200M's Reputation
Rate the quality of this post and help SatL200M reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SatL200M is offline   Reply With Quote
Old 08-24-2009, 11:28 AM   #9
Cromy
Cromy is on a distinguished road
I am experiencing a simuliar problem with my 2001 Saturn L-200 2.2 A/C fans. I had a service engine light last year that would go on and off when the A/C fans would run. A/C cooled, check a few things, changed FCM with new, fan relay in fuse box under hood with new, no luck, asked mechanics they said not to worry. Well this year A/C went out. Replace bad compressor, new receiver/dryer, expansion valve and high pressure switch. A/C cools but have "Service Engine" and "Service Engine Soon" lights, codes P0481 & P1640 same codes as last year. With A/C on both fans come on for about 10 seconds in High speed and then shut off and then back on 10 seconds off and on. Believe high speed is coming on because of high pressure, fans lower pressure and then shut off. I never see a low or medium speed on fans. What controls the low and medium fans? I am running out of parts to change.
THANKS
Cromy
Add to Cromy's Reputation
Rate the quality of this post and help Cromy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Cromy is offline   Reply With Quote
Old 08-24-2009, 12:02 PM   #10
Normally, the pressure switch detects and sends signal data to the ECM that determines which fan speed to run. Something's not right with the repairs to cause the same error codes. Did Saturn repair the system or a local shop? It would seem appropriate that you return back to the place that did the repairs and ask them to explain why the same errors returned.
Old 08-24-2009, 12:57 PM   #11
Cromy
Had it most done at a shop, not close to a Saturn dealer bought the car used from private owner. Car has ran great for seven years until now. All I asked them to do is get the A/C working and they did. They did not claim to or have the knowledge to troubleshoot the error codes even though the offered to help. They assisted in the code reading, code clearing and troubleshooting but we did what it said (replace A/C relay, fuse, check all ground wires, loose wires or connections, etc). So are you saying that the high pressure switch controls the fans speeds? Is there a low side pressure switch? If so where is it located? On Saturnparts website it illistrates a parts breakdown and shows a #5 Pressure Valve right next to the compressor. I dont see that, what is it and what does it do? Someone mentioned a air pressure switch going bad. Would this have anything to do with it? There is three wires going to both fans and I checked with a meter and only the high speed has voltage to it when running. No voltage to any fan wires when A/C is on until the 10 seconds of high speed.
Old 08-24-2009, 02:35 PM   #12
The ECM (engine control module) determines which speed to run the cooling fans, not the pressure switch. If this was replaced then its not the problem. The pressure switch has the ability to read the various internal line pressures on the high side that is transmitted to the ECM.
The other pressure part is a blow-off/relief valve, not a pressure switch. Connected to the compressor, it opens mechanically when excessive pressures are developed above 500psi; this dangerous pressure level can cause physical damage if allowed to continue; this relief valve releases built up pressures to prevent damage to the compressor and output hoses. This valve does not have any electrical connections.
The cooling fans usually runs at low speed when the a/c is first turned on and as outside temperatures rises the internal a/c high side pressures rise in proportion - the fans can switch to medium or high speed. The fan speeds are automatically selected depending on how hot/high the pressures are to cool off the condenser coil/radiator otherwise overheating can result in the a/c system shutting down. If too much R134a or oil is used, this can lead to higher than normal system pressures, triggering the abnormal fan speeds. Pressure monitoring will tell if the high side is too high.
Have you tried what the original poster did, disconnected the battery negative cable for a few minutes to reset the electronics?
Old 08-24-2009, 03:33 PM   #13
Cromy
Yes tried unhooking the negative to the battery only to clear the codes (sometimes this works) have two codes P0481 (fan 2 control circuit) and P1640 (Driver 1 input voltage high). Unhooking the battery cleared the codes and the fan seemed to run longer and more often but after awhile both code lights (Service engine & Service enging soon) came on. If it is in the ECM can it be reprogrammed or repair? I hope it dont have to be replaced everything else runs GREAT.
I have no low fan speed only fast. A/C mechanic says high side pressure is correct and the fan run high when the pressure rises. He and I just cant get the fans to run in low or medium speeds..either high speed for a short period of time or off. Since the high pressure switch has been changed what else tells the ECM for fans to run in slow or medium speeds? I think the fans are good because the fans have no voltage going to them until the high speed kicks in.
Any ideas would be greatly appreciated. Saturn dealer not close. What can they do (reasonably priced) if I make the long trip?
Cromy
Old 08-24-2009, 04:50 PM   #14
This seems to be isolated to either the fan control module (that you replaced) or the ground connection to the pusher fan (#2) located in the left lamp area. Check all the wiring connections carefully and 'exercise' them by disconnecting/connecting them and ground for any corrosion.
Old 08-24-2009, 05:24 PM   #15
Cromy
Thanks. I will check the ground but does it use the same ground for Slow and Medium speed that the High speed uses. Because the High speed works. The fan has three wires going to both fans. One wire has is grounded at all times, one wire will have 15 volts on it when the fan runs in high speed but the other wire seems to never have any measurement on it. One other member on this post spoke about a intake air temp sensor. Does this have anything to do with my problem?
Thanks again,
Cromy
Old 08-24-2009, 06:32 PM   #16
Does this help?
Old 08-25-2009, 11:09 AM   #17
Cromy
THanks I can check a few things with this wiring diagram.
fans run on high and speedometer does not work mikeu L-Series Tech 0 12-15-2009 08:55 AM
Coolant Fans constantly run Luckie L-Series Tech 10 02-22-2009 02:17 PM
Coolant Fans constantly run Luckie General Saturn Discussion 2 12-19-2008 05:47 PM
Cooling Fans richamer1 Ion General 1 10-02-2008 08:49 AM
Radiator Fan Continuously Running Eric S-Series Tech 9 06-19-2003 11:54 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
