Old 08-10-2009, 07:18 PM   #1
melanief
melanief is on a distinguished road
Default 03 Ion engine codes, relating to ICM and o2 sensor
I have a 2003 Ion with 80k miles, and a few days ago the SES light began blinking and the car had no pick up. Took it in to get diagnosed, codes came back: P0300 - random multiple misfire, P0037 - H20 sensor something, and P0141 - o2 sensor malfunction.
Replaced ignition coil, ignition control module, spark plugs, and boots. Light came off, car is driving perfectly again.
SES light came on steady after about 15 miles. Codes are coming P0037 and P0141, but car is still running fine. I'm guessing the ICM and new coils took care of the P0300 code, but am not sure about these two remaining ones.
Could it be an o2 sensor or catalyctic converter (research on this forum seems like it could be either)? If o2 sensor, the P0037 code mentions sensor 2, but how do you know which one? Is it still safe to drive in the mean time?
I've already fixed my SC2 off this forum, and replaced the Ion ICM and coils with advice from here, and this is the best place to ask it seems!! Thanks for any help.
Add to melanief's Reputation
Rate the quality of this post and help melanief reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
melanief is offline   Reply With Quote
Old 08-10-2009, 08:56 PM   #2
2006 ion2
2007 ION-2 Sedan
Default Re: 03 Ion engine codes, relating to ICM and o2 sensor
http://foxed.ca/rx7manual/2003mazdar...200001W04.html
this is a link explaining p0037
http://www.parksoffroad.com/tacomamo...de/cip0141.pdf
and a link for p0141. it could simply be the rear O2 sensor (look under the car at the passenger side of the exhaust under the car), wiring, or the ECU, but is usually not the ECU. good luck, let us know what happens.
2007 Saturn Ion 2
2003 Chevrolet venture lt
Add to 2006 ion2's Reputation
Old 08-11-2009, 04:32 AM   #3
Maritime Storm
Maritime Storm has a spectacular aura aboutMaritime Storm has a spectacular aura about
Maritime Storm's Avatar
2003 ION-2 Sedan
I'm not sure about your local, but around here the least expensive replacement rear O2 is at Saturn, by $100. Not sure why the aftermarket one is more expensive.
Save the Earth, Ban Slushboxes!!!!!
Add to Maritime Storm's Reputation
Rate the quality of this post and help Maritime Storm reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Maritime Storm is offline   Reply With Quote
Old 08-14-2009, 02:33 PM   #4
melanief
Thanks for the advice! I think that since we don't have a lift, and it's 150 degrees in Phoenix right now, we may just bring it in somewhere.
I'll post if I do try anything else myself... we'll see!! Thanks again.
Old 08-14-2009, 03:26 PM   #5
melanief
2004 Saturn Ion threw some engine codes.. what are they? Bestmaxx Ion Red Line 7 09-05-2008 08:27 AM
MAF sensor and codes pupilot007 L-Series Tech 2 11-11-2007 12:32 PM
Question about ODB II codes & O2 sensor..... justsumguy S-Series General 6 12-29-2005 09:30 AM
O2 sensor, SES codes and STP digriz S-Series General 4 10-27-2005 06:30 PM
'02 L300 Engine Speed Sensor/Other Codes 90protege L-Series General 3 04-17-2005 08:42 PM
