Old 08-10-2009, 02:47 AM   #1
Diezeltitan08
Diezeltitan08 is on a distinguished road
Diezeltitan08's Avatar
2002 SL1
Default Need Major Help With Mods sl2 dohc
I have a 98 sl2 with a DOHC and i have a cold air intake and an exaust system giving me about 10-15 bhp. i know the p/s delete with a/c delete gives a lil more go and i was wondering if there are any side effects to running with no p/s. Other than the obvious inconveniances of course lol( cant turn). Is it possible for it to damage my pinion or steering rack in any way? And does anyone know if a msd system is worth the money because i have one on my cadillac but its a distributed system v-8 so of course its gonna give that more power but im hearing that on sl2's it doesnt give much performance boost. Im tring to keep it a daily driver but destroy those pesky v-tecs that my friends have...ps any other mods out there let me know im looking for cheap but efficient power
Add to Diezeltitan08's Reputation
Rate the quality of this post and help Diezeltitan08 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Diezeltitan08 is offline   Reply With Quote
Old 08-10-2009, 05:02 AM   #2
Default Re: Need Major Help With Mods sl2 dohc
The majority of aftermarket ignition systems, from what I can tell, put out LESS power then our stock system. Kinda odd, but there you go. I think the AC Delco stuff has the highest output but I could be wrong.
It's much easier to turn a manual rack in a parking lot then a power rack with the pump disconnected. I've done both and other then the manual rack having a large turning radius I like it better then the power rack minus pump. If you change from a power rack to a manual rack you also need to change the yoke that connects the steering column to the rack, the connections are either different between manual and power or they changed year to year.
I'm mostly finished with swapping engines and transmissions (getting my '93 to the proper 5spd) and dropped the stock flywheel when I removed it from the engine. I had just removed the 8lb Fidenza from the '93's engine and wasn't expecting it to be "freaking heavy" Not everyone notices a difference with the lightweight flywheel but I did.
Old 08-10-2009, 10:57 AM   #3
plastic torpedo
plastic torpedo will become famous soon enoughplastic torpedo will become famous soon enough
plastic torpedo's Avatar
2000 SL2
1994 SC2
LOL, an intake/exhaust combo will not give you 10-15 hp. More like 2-3 hp.
Cheap and efficient (in the short term) = nitrous. Forget the ignition stuff until you're running boost, and even then it doesn't do much for you.
2000 SL2 5-speed turbo
MSnS-E fuel & spark controlled @ 17-20 psi (methanol injected)
Fully forged, P&P head and manifolds, FSR turbo cams, balanced to 9k RPM
http://www.cardomain.com/ride/3070918
Add to plastic torpedo's Reputation
Rate the quality of this post and help plastic torpedo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
plastic torpedo is offline   Reply With Quote
Old 08-10-2009, 11:10 AM   #4
PurdueGuy
PurdueGuy's Avatar
1999 SC1
Should be somewhere in between, though it depends on what the exhaust setup is.
With the steering: you have the option of looping the lines on your power rack, or swapping to a manual rack. The manual rack will be easier to turn, but takes more turns lock-to-lock.
I would suggest a SAFC2 & WBO2. It should give you more gains than your intake or exhaust, and will help you make the most of any bolt ons you may use.
SaturnSeries.net owner
Add to PurdueGuy's Reputation
Old 08-10-2009, 03:14 PM   #5
d3ad1ysp0rk
d3ad1ysp0rk will become famous soon enough
I disagree with this. If we were driving s2000s with perfectly tuned intakes and exhausts from the factory this may be true, but we're not, and a full exhaust and a good intake can net you some gains, although small.
Your biggest factor is going to be tuning. I'd buy a wideband and SAFC or megasquirt before anything else.
T3/T4, built motor, coilovers, rear disc, audio setup, etc.
Add to d3ad1ysp0rk's Reputation
Rate the quality of this post and help d3ad1ysp0rk reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
d3ad1ysp0rk is offline   Reply With Quote
Old 08-11-2009, 02:13 AM   #6
Diezeltitan08
2002 SL1
I actually have a custom quad exaust with independent pipes for each cylinder...bet you havent seen that yet lol and my intake is a spectre running sraight off my throttle body with a underbody scoop feeding it lots of cool air haha with two flowmasters with dual in/out...i think i get 10-15...i win lol
Old 08-11-2009, 09:56 AM   #7
Where do you fit four pipes under the car? Pics?
Add to madpogue's Reputation
Old 08-11-2009, 12:19 PM   #8
I'd like to see some dyno sheets myself.
You'll find that the butt-dyno and ear-dyno are pretty inaccurate
Old 08-11-2009, 12:21 PM   #9
ruley73
ruley73's Avatar
2007 ION-2 Quad Coupe
+1
I would also like some proof. Until then by BS flag will wave.
And yep, you're right, we haven't seen four pipes yet because it's a waste of resources. Anything larger than a single 2.25" ID exhaust pipe for N/A use is pointless. Just think of all the weight you've added by running four pipes all the way back, adding another muffler, and the stuff supporting your exhaust.
Also, an under body scoop is also pointless since the fresh air will have to run by your four exhaust pipes (and the rest of the aluminum engine) and get quite warm before it reaches your cone filter.
2007 Chevy Equinox LT 183K miles
Add to ruley73's Reputation
Old 08-11-2009, 03:44 PM   #10
Diezeltitan08
2002 SL1
Originally Posted by ruley73 View Post
+1
I did do it but ive never thought about the extra wieght and heat added, guess i jus started doin stuff cuz i have access to a steel palnt worker lol he made the exaust for me and there is surprisingly a lot of room after your remove the cooling fan...jus dont get caught in trffic haha but...you think it would be better for jus headers leading to a 2.25? i can probably fit that in my budget but i was figuring my hp was 10-15 because we start of with 124...give or take a few for how many miles i have so i prolly have like 120 since i take care of my car...and my friend has a 98 b16 or b18(cant remember) civic and i smoke him by like 2 cars acceleration wise and i know are cars arent big on acceleration so i figured i had a better p/w ratio and 10-15 seemed to fit that theory because he has been dynoed at 156 hp so maybe he jus cant drive a stick but he cant beat my sl2...ima put sum pics on my car domain soon with the link, but sumone stole my saturn and when i got it back my camera was gone...so pics will be up when i steal my gf's for a while lol
Old 08-11-2009, 11:17 PM   #11
alex14
alex14 is on a distinguished road
alex14's Avatar
removing the cooling fan is dumb.
Purple 95 SC2 man.-work in progress.
Black 98 SC2 auto-SOLD!
Add to alex14's Reputation
Rate the quality of this post and help alex14 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
alex14 is offline   Reply With Quote
Old 08-11-2009, 11:52 PM   #12
dorisSL
dorisSL is on a distinguished road
dorisSL's Avatar
1995 SL
can someone translate?
1995 SL, born 12/23/94, manual, WAI 190,500, "Doris"
(I'm Ben, the car is Doris)
you can't mulch at those speeds man, that's too fast
Add to dorisSL's Reputation
Rate the quality of this post and help dorisSL reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dorisSL is offline   Reply With Quote
Old 08-12-2009, 12:32 PM   #13
I never thought about the heat and extra weight I added by not thinking my modifications through.
I just started modifying stuff because I know a guy who can work with steel. He made the exhaust for me.
There is a surprising amount of room after I removed the cooling fan, another modification which I didn't think through. Just don't get caught in traffic!
Do you think it would be better for just headers leading to a 2.25 DIA exhaust? Because I can always trust the internet to give me good advice
I was figuring my HP gain was 10-15, because we start with 124, give or take a few for how many miles are on the car. I probably have 120 HP because I maintain my car well, except for the part where I removed my 5 lb cooling fan to make room for 40 lbs of metal exhaust tubing.
I also estimated the HP gain based my friend having a '98 Civic with a b16 or b18 (can't remember which one) and I smoke him by two car lengths when accelerating. Everyone knows that taking two different drivers of unknown skill racing two different cars of unknown weight and only knowing the power of one car, over a course of undetermined length, is a good way to estimate HP gains from modifcations.
I know our cars aren't big on acceleration, so I figured I had a better power/weight ratio and a 10 to 15 HP gain fits that theory. His car has been dynoed at 156 HP, so maybe he just can't drive a stick, which would render any point I'm trying to make by racing him a totally pointless endeavor, especially estimating HP gains.
I'm going to put some pics on my CarDomain soon and post the link, but someone stole my Saturn. When I got it back, my camera was gone. So I'll put up some pics when I steal my girlfriend's camera for a while.
Just trying to be helpful
Old 08-12-2009, 12:34 PM   #14
No way, man, it gives me 5-10 HP
Old 08-12-2009, 12:36 PM   #15
PurdueGuy
PurdueGuy's Avatar
1999 SC1
Which is helpful for those 3 miles before you have to pull over to avoid overheating.
Old 08-12-2009, 12:42 PM   #16
SLCraig
Dude, didnt you know, just DON'T STOP and you'll be fine!
"Speed VII, Satty without a cooling fan!!!"
1996 SL2 5MT
1997 SL1 5MT
2000 SW2 5MT
All gone, but not forgotten.
Add to SLCraig's Reputation
Rate the quality of this post and help SLCraig reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 08-12-2009, 12:46 PM   #17
strn365
strn365 is on a distinguished road
na remove the cooling fan lighten the weigh og the car cut down on the load from the alternator. next mod should be removing all the water and cooling componets from the car bet you will gain like 100hp from it. Ok seriously saturn put the fan on there for a reason leave it alone
Add to strn365's Reputation
Rate the quality of this post and help strn365 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
strn365 is offline   Reply With Quote
Old 08-12-2009, 12:54 PM   #18
plastic torpedo
2000 SL2
1994 SC2
Old 08-12-2009, 07:08 PM   #19
Diezeltitan08
2002 SL1
Im not trying to start any kind of arguments thats not what im about. I jus want to know a couple mods to make my car get up and go. Its already moving pretty nice with the things ive done but thats light DIY stuff.
Im investing in a piggyback soon and hope that will help ( Thanks Purdueguy) and some lower profile tires for better acceleration...(less tire runout i heard correct me if im wrong)
saturns are pretty good about not overheating without a fan long as its not like 90 and ur standing still but i live in Michigan so i dont have to worry about that lol.
Only bad news is ived lightend up in the front so much i hope it still works nice in the snow...i hate driving my caddy(93 Fleetwood Brougham with 87 LT-1 329BHP-DYNO'd At Wheels...idk crank 14.98et...14 MPG lol )since ive got 30mpg now lol
but im open for mods/tricks that anyone knows, im hoping for a 14/15 sec car that i can drive every day...
my best ET is 15.86 with everything out the car...carpet trunk accessories pass seat and rear seats and my interior stripped.... idk how much my wing weighs but i like it so its staying lol...thanks everyone for the help
Old 08-12-2009, 11:03 PM   #20
dorisSL
dorisSL's Avatar
1995 SL
let me get this straight...
you took out your cooling fan to save weight and space... then you put a wing on a front wheel drive car?
just checking.
DOHC SC2 Mods Possible HP Figures? Macgyver S-Series General 13 06-29-2009 08:51 AM
94 SL2 with major problems! briansmom S-Series General 12 06-12-2006 03:04 PM
Major Confusion...97 SL2 jigawatt77 S-Series General 1 01-19-2006 04:46 AM
First-Gen DOHC mods.... JADEDSL2 S-Series General 34 06-17-2005 04:37 PM
FS: 1992 DOHC SC w/ mods! Rob92SC Classifieds 1 03-25-2002 06:47 PM
