Old 08-09-2009, 02:31 PM   #1
SC Saturn Owner
SC Saturn Owner is on a distinguished road
Default urgent help needed. 2004 saturn ion
I just used our Saturn Ion to jump start a dead car battery in a Jaguar XJ-S. After that, my wife moved the car (saturn) out of the way and into our yard. I now went to move the saturn over some and when I put the key in it was dead, and now I can't even get the key out and I can't shift the gearstick out of park and into anything else. I tried turning the steering wheel thinking sometimes I've seen it where it gets locked and that does it. no luck. I need to move this car very soon!
Also for what its worth... I hooked the cables to the saturn first, and it was not running. But the cables that were to be put on the dead battery briefly touched each other but then it was able to jump start the dead battery. Is there any chance I might have shorted it out? it did drive after this happened when my wife moved it into the yard but once she turned it off it wont start now.
Add to SC Saturn Owner's Reputation
Rate the quality of this post and help SC Saturn Owner reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SC Saturn Owner is offline   Reply With Quote
Old 08-09-2009, 02:53 PM   #2
SaturnIONSLVUE
SaturnIONSLVUE is on a distinguished road
Default Re: urgent help needed. 2004 saturn ion
Is the battery still the delco freedom battery? O.e. Batteries only last like three to four years on average some last 6+ on rare occasions. Jumping cars destroys the alternator of the car you are jumping from. I was told this by a good friend who was a service manger at ford.
Add to SaturnIONSLVUE's Reputation
Rate the quality of this post and help SaturnIONSLVUE reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SaturnIONSLVUE is offline   Reply With Quote
Old 08-09-2009, 03:10 PM   #3
SC Saturn Owner
its whatever battery came in the car I assume becase she bought the car used but only 11,000 miles or so. Does this explain why the key won't come out of the ignition though?
Old 08-09-2009, 03:16 PM   #4
SC Saturn Owner
OK I got the keys out by using that little button under the steering colum but car still won't show any signs of life, so should I first just put a new battery in?
Old 08-09-2009, 04:28 PM   #5
Get the battery tested before buying one. If its the original one its 5yrs old and most likely on the fence and can go either way. Does your battery sit in the back of the car too? If so, you may have to look over the cable ends to be sure they're not corroded and contributing to power problems.
The alternator being ruined from jump starting can't be proven as the battery is the storage device and the boost battery (when connected properly) provides the OOOMPH for the jump start, provided the booster cables are not the wimpy cheap $10 ones. A relatively expensive set of large gauge (4-gauge) booster cables, no matter how seldom they're used, provides almost an instant BOOST as the current goes directly from the boost battery through the large gauge cables to act as if the boost battery were in the dead battery's car. There's a reason why commercial tow drivers carry the heavy duty cables; less time wasted trying to charge a battery with cheap booster cables when large gauge cables provide instantaneous current to the dead battery as well as start a dead car. I know, I stole my brother's Sears 4-gauge booster cables years ago. Very flexible and provides instant boosting compared to the cheap cables. Those cables probably cost $30+ (25yrs ago) and now cost much more. My brother doesn't own a car. Go figure.
Old 08-09-2009, 04:47 PM   #6
SC Saturn Owner
this is the original AC Delco battery, I went and checked. So I guess it's possible that the jump might have killed the battery? It started the car well before today and even after the cables touched and had that little spark, the saturn started and was able to be driven but just won't do a single thing now. i can't even use the clicker on the keychain to lock the doors.
The battery is in the trunk but the connections look good as far as I can see.
If I fried the ECU do you think that's going be a huge repair bill?
Old 08-09-2009, 04:54 PM   #7
Heh-heh, GM engineering designed our electronic fuel injection systems for the eventuality of real world events like shorting out batteries. It would take a lot more than a battery short to kill ECM's (but much less for the BCM's to fail ). I wouldn't worry about the ECM as much as the battery may have buckled internally from the quickie short. Stuff happens and we learn from mistakes but I would think the battery was on its way out and the little short may have did it in. Have it tested at your favorite auto store. Who knows, maybe all it needs is a good overnight charge.
Old 08-09-2009, 05:36 PM   #8
SC Saturn Owner
OK will do, I just wanted to make sure before I go to the trouble of taking it out... I dont know why they make it so hard to take out the batteries in these cars!
Old 08-09-2009, 05:39 PM   #9
2006 ion2
2007 ION-2 Sedan
they corrode less, add balance to the car, and is unlikely to get damaged in a crash (makes a fire/explosion hazard) being in the trunk.
2007 Saturn Ion 2
2003 Chevrolet venture lt
Add to 2006 ion2's Reputation
Old 08-09-2009, 06:12 PM   #10
SC Saturn Owner
problem fixed!! battery was fine, but when I put it back in, I guess the connections werent too secure and it started right up!! thanks guys!
Old 08-09-2009, 07:59 PM   #11
crystal scan
crystal scan is on a distinguished road
2003 ION-2 Sedan
thats good everything worked out
Add to crystal scan's Reputation
Rate the quality of this post and help crystal scan reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
crystal scan is offline   Reply With Quote
2004 Saturn Ion-2 MAllison Ion Tech 7 11-08-2009 02:46 PM
Urgent help needed ASAP! - Uhaul Hitch wiring today! elektrik Vue General 2 07-03-2008 10:07 PM
URGENT: Help Needed! thewretched Miscellaneous Tech 4 08-02-2004 04:21 PM
HELP NEEDED: Im a NEW SaturnFan: Saturn Ion Quade Coupe or Toyota Corolla CE Flipn22 Ion General 26 11-11-2002 03:34 PM
URGENT! OLOA pictures help needed wei_ General Saturn Discussion 6 05-16-2001 11:53 AM
