Old 08-07-2009, 02:39 PM   #1
mlambert77
mlambert77 is on a distinguished road
Wrench Which EGR passageway should I clean?
I read on a post here once before, though can't find it now, that you should keep debris out of one of the EGR passageways/tubes.
I've had a lot of rough idle lately and I cleaned the EGR valve, which has helped some, but not a lot so I'm going to clean it again. I haven't cleaned the actual tube yet, and was wondering if I needed to clean out both tubes or just one?
I plan on spraying some carb cleaner down the tubes, letting it sit for awhile, then using a gun cleaner brush to break up the deposits hopefully.
There are some good instructions on here about how to clean the EGR valve itself (especially Richpin's), but haven't been able to find anything good on the passageway/tube.
'99 Saturn, 159000 miles.
Add to mlambert77's Reputation
Rate the quality of this post and help mlambert77 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mlambert77 is offline   Reply With Quote
Old 08-07-2009, 02:52 PM   #2
quantumech
quantumech is on a distinguished road
Default Re: Which EGR passageway should I clean?
Rev the engine with the EGR removed, that should blow anything that is on the exhaust side out, but it'll be kinda loud.
I don't believe the other side gets gummed up...at least, don't think I've seen anyone mention it.
As for the rough idle, when was the last time you looked at/changed your plugs and wires?
Sasha: 2000 SL1, Manual, 130,500 miles 5-18-2014.
I learn from my experiences. If I screw up, I'm sorry.
Add to quantumech's Reputation
Rate the quality of this post and help quantumech reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
quantumech is offline   Reply With Quote
Old 08-07-2009, 03:06 PM   #3
mlambert77
I changed the plugs this weekend, the wires about a year and a half ago. I do have a worn/stuck compression seal. Don't have the $1500 to fix the heads now so been watching oil consumption. Plan on doing a MMO soak this weekend, see if it helps any.
Clean EGR and go BOOM? Hooty S-Series Tech 5 05-09-2009 10:06 AM
how do you clean a egr valve saturncrzy S-Series General 10 05-16-2008 06:36 AM
Would it be better to just put a new EGR on, or just clean the old EGR? Token S-Series General 12 01-18-2006 12:24 AM
Necessary to clean EGR? denclar S-Series General 18 11-08-2004 11:25 AM
How do I clean the EGR valve?>>> auxmike S-Series Tech 23 01-18-2003 11:20 AM
