Old 08-05-2009, 04:57 PM   #1
Neutron
Neutron is on a distinguished road
Neutron's Avatar
2001 SW1
Default recommended Minneapolis-area repair/modification shops?
My 1994 Saturn SL2 is in need of a few repairs and I would like to know if there are any Minneapolis-area shops that fellow Saturn owners would recommend - shops other than the area Saturn dealers?
One of the things I want done is the auto-transmission valve body replacement to cure the "reverse slam". From what I've read on the forum, 100s of dollars can be saved if you can avoid having the dealer do this replacement.
The other thing is to have my dash instrument panel and theater lights replaced with LED lights. If I can pay someone to do this that has already done it before, I'd prefer that over disassembling the dash myself.
Over the life of my SL2, I've only trusted the Saturn dealers to perform repairs. If there are other shops who also deserve my trust, I'd like to know about them!
Thanks very much!
Eric
1994 SL2 Automatic AC 220,500 miles
Add to Neutron's Reputation
Rate the quality of this post and help Neutron reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Neutron is offline   Reply With Quote
Old 08-05-2009, 06:26 PM   #2
Default Re: recommended Minneapolis-area repair/modification shops?
Unless you are all thumbs you can do the valve body yourself. The LED job is a bit more complex because almost every cluster is a bit different between generations and sometimes even model years and this makes identifying the correct LED replacement assemblies a bit difficult in advance. Getting the cluster out is not a horrid job either. I think the 94 would be one of the more straight forward clusters to change over to LED lights.
Old 08-06-2009, 08:30 AM   #3
+1, DIY. Trust yourself
how to remove the instrument cluster, courtesy of Low Saturn:
http://www.differentracing.com/tech_...94cluster.html
If you can operate a screwdriver, looks like you should be able to do this. Use sealable plastic bags and label them to keep your loose screws and bolts.
What I sometimes do, since I am somewhat of a mechanical noob and don't know what everything is called, is just number the bags. First bag of screws for one area is labelled " 1 ," next bag is labelled " 2 ", etc. When reassembling, just go in reverse order.
For electrical connections, wrap a piece of tape on each end when disconnecting and label each end " A " for the first one, "B" for the second, etc. When reassembling, A goes to A, etc.
By going this route (and with OldNuc's & others' help) I've replaced a drive axle (I'm still a little fuzzy on some of the names of the pieces ) and am about 60% done with a timing chain replacement.
Freebie Haynes manual for Minneapolis/St Paul area MatL S-Series General 13 03-22-2007 11:41 AM
Moving to Minneapolis area! bc3tech Community Center 5 08-21-2006 08:44 AM
Independent repair shops outperform dealerships in Canada CanVueYes! General Saturn Discussion 10 09-20-2003 09:55 PM
Recommended detailer in MA South Shore area? BillS General Saturn Discussion 1 08-02-2002 06:44 AM
Attn: Minneapolis/St. Paul Area Owners Dr. Bob General Saturn Discussion 2 10-02-2000 12:46 PM
