Old 08-04-2009, 10:01 PM   #1
mlambert77
mlambert77 is on a distinguished road
Question How long can I drive with a coke can gasket under my EGR valve?
I have a 99 SL2, 160k miles on it. Today after filling up, it started lurching and when I went below 1500 RPM the engine really bucked and eventually died. I had to put the car in neutral and keep the RPM's above 2000 at lights/stop signs.
I went to Autozone, they pulled the code and said bad EGR. I took it off so they could test it with a 9v battery, and sure enough, the pindle never moved.
I just watched this video http://www.youtube.com/watch?v=8YRq2Xl58Oo&NR=1 on how to check the EGR valve from Richpin, and he said to cut a coke can, and make a gasket and put it under the EGR and if it runs smooth, you know for sure. (at the 5:30 mark is where you'll see what I'm talking about).
My question: I don't get paid until next week. How bad will it mess up my car if I drive with the coke can gasket in between the EGR valve and regular gasket?
Add to mlambert77's Reputation
Rate the quality of this post and help mlambert77 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mlambert77 is offline   Reply With Quote
Old 08-04-2009, 10:16 PM   #2
Default Re: How long can I drive with a coke can gasket under my EGR valve?
You can drive that way until you get tired of the SES light. Eventually the hot exhaust gas will eat a hole through the can. That takes about a week.
You might want to invest in a can or 2 of carb cleaner and give that valve a good cleaning if the pintle will not move when you poke on it with a screw driver. It sounds like your valve is sticking open so a good cleaning will fix it, maybe. And, if you have an option between an aftemarket EGR valve and a good used one from a local J/Y go with the J/Y. You have to use an EGR from a 99 and newer car, the DOHC and SOHC are the same part.
Old 08-04-2009, 10:29 PM   #3
mlambert77
Ok, thanks. I normally drive about 15-20 miles a day, so a week is perfect really. I cleaned the pintle once this weekend actually, and then today this happened. I hope I didn't mess it up when I cleaned it last.
I sprayed it with some carb cleaner and used a toothbrush to brush it basically. Would it be better to spay some carb cleaner into a bowl and let the pintle soak for awhile?
Old 08-04-2009, 10:33 PM   #4
93SC2'in
93SC2'in is on a distinguished road
93SC2'in's Avatar
1993 SC2
what are the long term affects of driving without a operational egr or a blocked one? should be the question
93 SC2, 5-speed, <dead and gone>
95 SL2 5-speed, oem header, gsi TB, sprint 2.0, kyb gr2's, wb02, SAFCII, CAI, 17"s
Speed Kills - save lives, Drive a honda
Add to 93SC2'in's Reputation
Rate the quality of this post and help 93SC2'in reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
93SC2'in is offline   Reply With Quote
Old 08-05-2009, 08:01 AM   #5
DonP
Do you have to do an emissions test? That can be a limiting factor.
Add to DonP's Reputation
Old 08-05-2009, 08:31 AM   #6
rsg3
rsg3 is on a distinguished road
1999 SL
Isn't the '95-'99 valve the same part? They're the same number in RockAuto's catalog. The part number they list is different for '00 and up.
Add to rsg3's Reputation
Rate the quality of this post and help rsg3 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rsg3 is offline   Reply With Quote
Old 08-05-2009, 08:38 AM   #7
mlambert77
No, we don't have one here. I cleaned the pintle last night. I had cleaned it before, but never realized how to clean it thoroughly until reading about 40 posts on the topics here. It still shudders a bit when accelerating from a stop or around 40mph, but hasn't stopped at red lights/stop signs/etc yet. If it keeps up though, I might do the coke can test.
Old 08-05-2009, 08:55 AM   #8
If you like, stick two coins in place instead of the soda can gasket. The coins last longer.
And a few have left this blocking gasket, using coins or sheet metal, for long term blocking without any damage to the engine.
Old 08-05-2009, 09:00 AM   #9
mlambert77
Going to sound stupid, but any coins, or dimes (since they're thinner than nickles/quarters).
Old 08-05-2009, 09:38 AM   #10
I believe that 2 nickels were used. If you clean it it and it still does not function correctly block it off and see what happens. It is possible you have a different problem.
Old 08-05-2009, 09:41 AM   #11
You are right, 95-99 are the same, changed for the 2000 model and up.
Slow leaking valve gasket. How long??? Mgg4591 S-Series General 20 09-25-2009 09:43 AM
EGR Valve Gasket + sealant? and other ? AJT_Leo S-Series Tech 12 07-18-2007 07:08 AM
Long enough Valve Cover Gasket Cure TIME nmsaty S-Series General 17 06-09-2006 06:40 AM
EGR Valve Gasket Question SL1Joe S-Series Tech 9 01-14-2006 11:50 AM
How long to tell if EGR valve clean worked 07green1 S-Series General 2 04-05-2005 03:34 PM
