Old 08-01-2009, 11:55 AM   #1
cschmidt1956
cschmidt1956 is on a distinguished road
Default Spark Plug Change for Astra
With the recent Spark plug changes I decided to do a quick overview for Spark Plug R+R for our Astras. This will assume that you have some mechanical experience and just need a slight helping hand as to the how-to of all of this. It is really simple and requires a few things but most of us will have these tools.
Here is the listing of the tools and extras that I used:
Torx T-40 driver
3/8 Drive Ratchet
3/8 Drive 8 inch long extension
3/8 Drive Spark plug socket (5/8)
4 Spark Plugs
Dielectric Grease
Anti-Seize
This is my Astra, we need to remove the Valley Cover. It snaps on and off , just give it a tug starting from the right side and pull.
This picture shows the valley cover removed, but also shows one of two Torx T-40 screws that need to be removed. Also on the far right is a connector that feeds the signals to the Spark Plug distribution block. This needs to be disconnected before you pull the distribution block from the valley.
This photo shows the distribution block removed and the clear access to the spark plugs in the head. They are deep in there and I had to use an 8 inch long extension on my 3/8" drive socket to reach them.
I used Autolite Iridium XP Spark Plugs number XP-5224. The plug gap for these as per the Owners manual is .035. The plugs were gapped at .045 out of the box so I had to gap each plug. These plugs use a flat washer and as such require a 1/4 to a full 1/2 turn to properly seat and torque the plugs. I recommend using anti-seize on these plugs and you only need a little. I always wipe off the excess with a clean paper towel.
Before installing the distribution block back onto the plugs, coat the inner surface of each plug boot with a little dielectric grease. I use a Q-Tip to smear the inside of the boot on just the first 1/4 or so of the boot. This aids in installation and later remove of the distribution block at the next spark plug change.
Ensure that you connect the electrical connector back onto the distribution block and then install the two Torx T-40 bolts. I also used anti-seize on the first few threads on these bolts to aid in later removal of these bolts. I used a nut driver style Torx so I do not have a torque spec for these two bolts. I snugged them down well. Snap the valley cover back on and you are now complete.
2010 Chevrolet Camaro LT2/RS V6
2008 Saturn Astra XR 3 Door - Sapphire Black (Gone but NOT forgotten!)
2003 Jeep Grand Cherokee, Brilliant Black Metallic
1999 Oldsmobile Intrigue GLS, Black
Add to cschmidt1956's Reputation
Rate the quality of this post and help cschmidt1956 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cschmidt1956 is offline   Reply With Quote
Old 08-01-2009, 01:23 PM   #2
Nightwalker
Nightwalker is on a distinguished road
Nightwalker's Avatar
2008 Astra XR
2005 ION-2 Sedan
Default Re: Spark Plug Change for Astra
Nice, I was going to do one myself, but now I don't have to.
Just wanted to add that the electrical connector is released by lifting the tab on top of the connector from the LEFT side. Older Saturn connectors under the hood have tabs on the right side (near the wires).
My audio system thread, how to replace speakers: http://www.saturnfans.com/forums/showthread.php?t=137456
2008 Astra 3 door XR, 5-speed MT Black Sapphire, custom audio system
Add to Nightwalker's Reputation
Rate the quality of this post and help Nightwalker reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Nightwalker is offline   Reply With Quote
Old 08-01-2009, 03:18 PM   #3
BobbyP
BobbyP's Avatar
2006 VUE Red Line
2007 SKY
Still looks NEW! Very clean spark plug wells.
Any pictures of the plugs after 30k miles? The plugs on my SC showed physical wear after 30k miles.
The proper torque of the bolts would be critical because of all the plastic parts. You wouldn't want them too tight or too loose...
Add to BobbyP's Reputation
Old 08-01-2009, 07:47 PM   #4
SaturnRaycer
SaturnRaycer is on a distinguished road
SaturnRaycer's Avatar
2008 Astra XR
I changed out the plugs on mine at the recommended 25k miles. There was minimal wear on the outer electrode, unlike others where the outer electrode was 30-50% smaller (arced away).
I used the Saturn replacement plugs, which aren't cheap ~$9US. I'd be interested to get a report on how well the Autolite plugs fare.
Rex
2008 Astra XR
5 dr, 5 spd, sport package
Black Sapphire
If you're going to wave, use all your fingers.
Add to SaturnRaycer's Reputation
Rate the quality of this post and help SaturnRaycer reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SaturnRaycer is offline   Reply With Quote
Old 08-02-2009, 07:28 AM   #5
cschmidt1956
Yep. Bought it back last June (2008) and was able to keep it in the Garage most of the Winter. Our winters in New York State take a toll on the cars. I have rarely driven on rainy days also. Trying to keep it as nice as I can. Lost my Job back in December, had one job since and left there. Going back for training in the next few months to see if I can get into a new career.
Just want to keep the Astra as nice as I can until I have to sell it or it is paid off.
Chris
Old 08-16-2009, 09:21 PM   #6
Audi Junkie
Audi Junkie is on a distinguished road
Copper anti-sieze is a great product. Ideal for alloy heads (dissimilar metals) and electrical connects too. I'll probally go w/NGK Ir-Fusion.
Add to Audi Junkie's Reputation
Rate the quality of this post and help Audi Junkie reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Audi Junkie is offline   Reply With Quote
Old 09-03-2009, 09:13 AM   #7
sccannon
sccannon is on a distinguished road
sccannon's Avatar
I'm taking my Astra in to replace that tensioner on tuesday, but I was asking my service guy how much they charge to replace the spark plugs at 25,000 Mi. as the owner's manual recommends. He checked with the tech and came back and said that the Astra has 100k spark plugs in it and that there is no need to change them. Has anyone else heard this?
Chris
2008 Sandstone Astra XR 5 door
Automatic
Sport Handling Package
Premium Audio Package
Sunroof and 17's
Add to sccannon's Reputation
Rate the quality of this post and help sccannon reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sccannon is offline   Reply With Quote
Old 09-03-2009, 10:37 AM   #8
unkle bik
unkle bik is a jewel in the roughunkle bik is a jewel in the roughunkle bik is a jewel in the roughunkle bik is a jewel in the rough
unkle bik's Avatar
2007 AURA XR
2008 Astra XE
Did you have any problems with the plugs seizing in the head upon removal?
93 SW2
96 SL2
01 SL2
02 L200
08 Astra Xe
07 Aura XR
Complacency leads to mediocrity.
Mediocrity leads to our demise.
Add to unkle bik's Reputation
Rate the quality of this post and help unkle bik reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
unkle bik is offline   Reply With Quote
Old 09-09-2009, 10:42 AM   #9
spencerb
spencerb will become famous soon enoughspencerb will become famous soon enough
spencerb's Avatar
2008 Astra XR
When I took my Astra in for new plugs, they kept asking why I wanted them changed so soon. I told them because the book says so. They had to look in the manual for confirmation. They said they rarely get customers who read the manual.
I'm sure they are just used to all the other Saturn which have much longer plug change intervals.
2008 BMW 328i
2013 Subaru Outback 2.5i Limited
Past Saturns: 97 SL2, 01 SC2, 04 VUE, 08 Astra, 02 L200.
Add to spencerb's Reputation
Rate the quality of this post and help spencerb reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
spencerb is offline   Reply With Quote
Old 09-09-2009, 06:46 PM   #10
SaturnRaycer
2008 Astra XR
None at all. Apparently some wise tech writer put the step,"Apply a small amount of anti-seize compound to the threads" into the assembly manual. I applied anti seize to the new ones to make sure they behave at 50k too.
Rex
2008 Astra XR
Black Sapphire
Old 09-11-2009, 02:45 PM   #11
vanilla sky
vanilla sky is on a distinguished road
2008 Astra XR
What make are the OE plugs?
Add to vanilla sky's Reputation
Rate the quality of this post and help vanilla sky reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
vanilla sky is offline   Reply With Quote
Old 11-13-2009, 05:53 PM   #12
ironwill8282
ironwill8282 is on a distinguished road
My plugs were Bosch and they were toast at 30k.
Add to ironwill8282's Reputation
Rate the quality of this post and help ironwill8282 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ironwill8282 is offline   Reply With Quote
Old 11-21-2009, 02:06 PM   #13
Masry
Masry is on a distinguished road
At 40KM, got the Autolite 5224 copper, set of 4 is around CDN$12 tax included.
The original is Bosch R6:
FOR8LEU2 That is what's written around the metal part.
Have not driven it yet but idling seems to be smooth.
Add to Masry's Reputation
Rate the quality of this post and help Masry reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Masry is offline   Reply With Quote
Old 11-29-2009, 07:35 AM   #14
nelson.jones07
nelson.jones07 is on a distinguished road
Hey thanks man, I was looking for this because I was having this problem. This one really helped me a lot.
Add to nelson.jones07's Reputation
Rate the quality of this post and help nelson.jones07 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
nelson.jones07 is offline   Reply With Quote
Old 11-29-2009, 10:55 AM   #15
marx404
marx404 will become famous soon enough
marx404's Avatar
2008 Astra XE
Thanks cschmidt1956. How long should the Autolite Iridium XP Spark Plugs number XP-5224 last?
..and where can we get exact torque specs for everything?
marx404
Saturn lives on.
2007 ION.3
2008 Astra XE
2004 L300.1
Add to marx404's Reputation
Rate the quality of this post and help marx404 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
marx404 is offline   Reply With Quote
Old 11-30-2009, 12:29 AM   #16
vegetaarmy
vegetaarmy is on a distinguished road
vegetaarmy's Avatar
2008 Astra XR
Just did the first spark plug change on Saturday (24000 mi). Thank You for the great tutorial.
-Jess
Astra XR 5dr (Traded for 2014.5 Focus ST)
Add to vegetaarmy's Reputation
Rate the quality of this post and help vegetaarmy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
vegetaarmy is offline   Reply With Quote
Old 01-21-2010, 01:19 AM   #17
Audi Junkie
I ordered the iridium Autolite 5224s, but found it odd the two stores I frequent both only showed the Autolite line for our engines. I went ahead and dug up the cross reference info and got this:
http://www.globaldenso.com/en/produc...ion/index.html
It looks like the Denso K20 and others fit the same AND these stores carry the other brand's parts. The K20s are like $8.99, with a coupon the Autolitle "ir" are about $21 for all 4. Still dunno if I want the Autolite or what. The BOSCH FR7lcx and FR8lcx...but they are different heat ranges. Not sure which is ideal.
Old 01-21-2010, 01:54 AM   #18
Audi Junkie
This is a better cross-reference chart...
http://www.autolitecatalog.com/PartD...?b=A&pn=XP5224
Competitors
BOSCH 4312
BOSCH 4419
BOSCH 4512
BOSCH FGR9DDP
BOSCH FGR9DPQ
BOSCH FGR9DQI
BOSCH FR7KPP332
CHAMPION 9002
CHAMPION 9202
CHAMPION 9203
DENSO 3377
DENSO 3396
DENSO SK20DR-M11
DENSO SK22PR-M11S
DENSO SKJ16CR-L11
DENSO SKJ16DR-M11
DENSO SKJ20BR-M11
DENSO SKJ20DR-M11
DENSO SKJ20DR-M11S
DENSO SKJ20DR-M13
NGK 2477
NGK 3657
NGK 4080
NGK 4095
NGK 4757
NGK 5114
NGK 5887
NGK 5899
NGK 6441
NGK 6737
NGK 6994
NGK 7743
NGK 7746
NGK IFR7G-11K
NGK IFR7G-11KS
NGK IFR7L11
NGK IZFR5B
NGK IZFR5G
NGK IZFR5J
NGK IZFR5K
NGK IZFR5K11
NGK IZFR5L-11
NGK IZFR6F11
NGK IZFR6H-11
NGK IZFR6K
NGK IZFR6K-11
NGK IZFR6K-11S
NGK IZFR6K-13
NGK IZFR6N-E
NGK PZFR5J-11
NGK PZFR5Q-11
NGK ZFR5FIX-11
NGK ZFR6FIX-11
Old 01-21-2010, 06:01 PM   #19
Audi Junkie
Here's the thread I have going at Bob's...
http://www.bobistheoilguy.com/forums...7&#Post1750067
I'm sticking with the Autolites.
Application chart from sparkplugs.com
http://www.sparkplugs.com/results_ap...1&AAIA=1442051
Old 02-11-2010, 05:04 PM   #20
dcjlp
dcjlp is on a distinguished road
Great write up, Now I can change them.
Add to dcjlp's Reputation
Rate the quality of this post and help dcjlp reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dcjlp is offline   Reply With Quote
Spark Plug Change beensmoked L-Series General 8 05-19-2011 01:06 AM
Spark plug change, now smell gas? crj19 Vue General 13 10-26-2008 11:13 AM
2003 3.0 vue spark plug change dennisducher Vue Tech 3 10-16-2008 08:49 PM
Spark plug change on my 2000 LS2 V6 filter905 L-Series Tech 26 08-24-2006 10:06 AM
Spark Plug Wires...when to change? Fat Whacker Mods and Performance 1 05-01-2002 08:29 AM
