Old 07-21-2009, 03:09 PM   #1
99 SL2
99 SL2 is on a distinguished road
Default 99 SL2 high idle at start
I noticed a high idle when starting my '99 SL2 with 158K a few weeks ago. Idles at about 2100 RPM for 4-5 secs then goes to 1100 or so. It also seems to tach up a little more than usual when down-shifting (automatic) coming to a stop. Runs ok other than that when driving, and idles around 800 in gear. Haven't changed the ECTS so I'll do that, but how much does that affect idle speed? Should I go with a TB cleaning or will a couple cans of Techron at fill-ups help? Any ideas?
Add to 99 SL2's Reputation
Rate the quality of this post and help 99 SL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
99 SL2 is offline   Reply With Quote
Old 07-21-2009, 03:26 PM   #2
PurdueGuy
PurdueGuy's Avatar
1999 SC1
Default Re: 99 SL2 high idle at start
new ECTS and a throttlebody cleaning. If that doesn't do it, let us know. Those 2 things probably cure 80% of idle issues with these cars.
SaturnSeries.net owner
Add to PurdueGuy's Reputation
Old 07-21-2009, 03:34 PM   #3
1994Saturn
1994Saturn's Avatar
1994 SL1
Happy Re: 99 SL2 high idle at start
X2, replace the ECTS with a BRASS tip one. I even got mine at Autozone, and had no problems.
Current:
1998 SL2 Auto issues 112K
Past:
94 SL1 Sold @134K.
Add to 1994Saturn's Reputation
Rate the quality of this post and help 1994Saturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 07-21-2009, 03:42 PM   #4
Techron won't hurt - might clean up your fuel injectors, but it won't help clean the throttle body. The throttle body only gets air from the front, plus oil and crud from the PCV valve. It's a simple removal to clean - richpin video in the How To Library.
When I cleaned mine, I didn't use a brush or anything. Just sprayed it with carb cleaner until it was shiny. There were a few areas I had to rub with my finger.
x3 on the ECTS. If it tells the PCM "engine is cold", PCM makes the idle faster to warm up more quickly. If it tells the PCM "engine warm", PCM will drop it to normal idle speed.
Old 07-25-2009, 11:29 PM   #5
blueknigh7
blueknigh7 has a spectacular aura aboutblueknigh7 has a spectacular aura about
If you find out the answer, I'd like to know. My '97 SC2 has been doing this ever since I bought it used.
75k miles later (now at 175k total) it's still does it, so i figure it's not hurting too much. It seems to be exaggerated when starting cold. It jumps to 1.8-2k, for about 4 seconds, and then moves itself down to 1.2k. If the engine's warm, it might go as high as 1.6, but moves back down immediately.
I've changed the ECTS, cleaned the TB a bunch of times, and also replaced the TPS. The only thing i haven't done is changed the TB gasket, but I also couldn't find any leaks last time I checked.
Any other ideas out there? Other than this....my cars still running good.
Add to blueknigh7's Reputation
Rate the quality of this post and help blueknigh7 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
blueknigh7 is offline   Reply With Quote
Sometimes hard to start, slightly high idle Insulator S-Series Tech 5 03-15-2009 11:07 AM
High Idle @ Start HuskieJoe S-Series Tech 5 08-28-2007 11:34 AM
Abnormally High Idle at cold start daoyee S-Series Tech 1 04-01-2007 01:17 AM
high idle at start up usmc4life79 S-Series Tech 4 03-15-2007 12:58 PM
High idle only at start up HELP??? nmsaty S-Series General 2 07-16-2006 11:24 PM
