Old 07-17-2009, 10:27 AM   #1
bjaspud
bjaspud is on a distinguished road
Default Check engine light - emissions problem?
My 2007 Aura XR, 65,000 miles is showing a check engine light. I disconnected the battery for 30 minutes and the light cleared. Two or three days later the check engine light returned. I noticed that under hot restart conditions (example, stop in a gas station and refuel) the car takes two tries of the key before it fires up and runs.
I then went to Autozone and had it scanned. Here is what the scan reads:
"EVAP flow during a non-purge condition"
"The ECM has detected pressure in the EVAP system during a non-purge condition"
"Possible cause"
1 - Purge or vent solenoid failure
2 - Plugged EVAP canister condition
3 - Failed EVAP pressure sensor
Can anyone recommend a next step for trouble shooting or repair?
Thanks,
Spud
Add to bjaspud's Reputation
Rate the quality of this post and help bjaspud reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bjaspud is offline   Reply With Quote
Old 07-17-2009, 10:43 AM   #2
Phaeton Driver
Phaeton Driver will become famous soon enough
2007 AURA XR
Default Re: Check engine light - emissions problem?
"Possible cause"
Thanks,
Spud
Not sure if this would be considered part of the power train warranty and covered by GM. If not you need a good mechanic.
It could be as simple as something blocking the tube from the gas tank to the canister, the canister might need to be opened and cleaned out (purged), or it might be a leaking/blocked vacuum line to the canister, a faulty solenoid in the in/out vapor lines to the canister.
Of course as is the case with every other computer sensor system. it might be a fault in the wiring from the sensor to the computer or a faulty sensor, or one of a hundred seemingly unrelated items.
Good luck
Add to Phaeton Driver's Reputation
Rate the quality of this post and help Phaeton Driver reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Phaeton Driver is offline   Reply With Quote
check engine light and antitheft light 2004 L300 jonus311 L-Series Tech 2 01-31-2009 08:55 AM
help me to inspect the problem about the check engine light of ASTRA jazzz Astra Tech 2 01-28-2009 09:57 AM
Service Engine light /Emissions West_Ridge Ion Tech 7 07-22-2007 02:00 AM
Check engine light problem subir S-Series General 3 01-18-2006 08:52 PM
Check Engine Light - Accelerate/Deccelerate Problem jabbarahm Ion Tech 3 11-14-2005 01:54 AM
