Old 07-13-2009, 06:10 AM   #1
jonny772
jonny772 is on a distinguished road
2005 ION-2 Sedan
2003 ION-1 Sedan
Default jack stands and floor jack
so I am going to start doing my own oil changes, and various other maintenence. I already had jack stands and went out and bought a floor jack, my next question is where can I safely lift my car with the floor jack and brace it with the jack stands? Do I just put the jack/stands where I would lift the car with the scissor jack as if I was changing a tire? I have a 2005 Ion-2, manual trans. And before anyone says "search is your friend" I tried and cant find exactly what I am looking for, thanks.
Add to jonny772's Reputation
Rate the quality of this post and help jonny772 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jonny772 is offline   Reply With Quote
Old 07-13-2009, 08:42 AM   #2
Squareback
Squareback's Avatar
2005 ION-2 Sedan
Default Re: jack stands and floor jack
Jack and stands are great to have, but a little much for just an oil change. Get yourself a set of ramps to change the oil. Drive up on em, change the oil, and drive back off of them.
Certified Saturn Technician
Old 07-13-2009, 09:06 AM   #3
jonny772
2005 ION-2 Sedan
2003 ION-1 Sedan
I realize they are more work but its what I have to work with and I dont have alot of room to store ramps ( I live in a small apartment). But my question is, where is the best place to put the floor jack and jack stands so I dont kill myselfthanks.
Old 07-13-2009, 09:21 AM   #4
bigbird
bigbird is on a distinguished road
bigbird's Avatar
To answer your question: Look under the car, doesn't matter on which side, right behind the front wheel wells. You will see a long beam of metal, that looks like a rail, sitting under the floor pan. This rail runs from the front of the car to the rear, stopping just before the rear wheel wells. These rails are used to lift the car with a floor jack and to support the car when using jack stands. There may be brake fluid lines close to these rails. Make sure you don't pinch a line when jacking. Do not ever use the floor jack or jack stands against the flat floor pan itself. It is thin, non-structural, and will bend or puncture if you try to jack under it.
Add to bigbird's Reputation
Rate the quality of this post and help bigbird reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bigbird is offline   Reply With Quote
Old 07-13-2009, 10:31 AM   #5
jonny772
2005 ION-2 Sedan
2003 ION-1 Sedan
I just looked under my car and I saw a rail approx 2 inches wide under the car and then another one next to it further under the car, is that what you are talking about?
Old 07-13-2009, 10:41 AM   #6
Squareback
Squareback's Avatar
2005 ION-2 Sedan
Read your owner's manual, it's that thick book in the glovebox. The jacking points are illustrated in it. Use some common sense and you'll be fine.
Old 07-13-2009, 10:58 AM   #7
bigbird
bigbird's Avatar
Yes, those are the rails.
Old 07-13-2009, 11:02 AM   #8
bigbird
bigbird's Avatar
That's not going to help the OP. The jacking points illustrated in the owner's manual are for the scissor jack that is used to change a tire in an emergency. The jacking points for a scissor jack and a floor jack are very different. Your being sarcastic about the "thick book in the glove compartment" is of no help to the OP. If you had said "read the Saturn factory service manual to locate the floor jacking points", then your reply would have some merit to it.
Old 07-13-2009, 11:09 AM   #9
jonny772
2005 ION-2 Sedan
2003 ION-1 Sedan
I would also assume as close to the front of the car as possible would be the best spot for the stands?
Old 07-13-2009, 11:14 AM   #10
Squareback
Squareback's Avatar
2005 ION-2 Sedan
Really?? How so? Show me in an owner's manual anywhere that states the jacking points illustrated are for a scissor jack only. Please, give me a break. The jacking points are the jacking points regardless of the piece of equipment you are using to lift the car. In fact, when using an automotive lift, you lift it at the same points illustrated in the owner's manual "for scissor jack use only."
It certainly is help to the OP. Do you have any idea how many people have never opened the owner's manual in their car? There is plenty of good information in the owner's manual that any owner should familiarize themselves with, including jack points for the vehicle in question.
Old 07-13-2009, 11:15 AM   #11
Squareback
Squareback's Avatar
2005 ION-2 Sedan
You want the jackstand behind the front tires, right underneath the bottom of the front fender.
Old 07-13-2009, 12:37 PM   #12
bigbird
bigbird's Avatar
You are absolutely wrong! The small indents under the floorpan lip for the scissors jack will not accept the large pad of a floorjack. Owner's manuals were never designed to give a car owner the information needed to use a floor jack. That info is found in the factory service manual. Ever read one? Have you ever been in any garage and seen any competent DIY'er or mechanic use the indents designed for the scissors jack as a jack point for a floor jack? Didn't think so.
Old 07-13-2009, 06:30 PM   #13
2006 ion2
2007 ION-2 Sedan
the place where the vertical lower control arm bushing bolts up is a good place for a jack or jack stand, I go on the bolt head and have never caused damage.
2007 Saturn Ion 2
2003 Chevrolet venture lt
Add to 2006 ion2's Reputation
Old 07-13-2009, 06:50 PM   #14
Squareback
Squareback's Avatar
2005 ION-2 Sedan
Really? Where does it specify what type of jack should be used at the jackpoints? An automotive lift works just fine at the factory jackpoints, and so does a floor jack. The jackpoints are just that, the places you put the jack to lift the car, and they are designed to take the weight of the car.
Why yes, plenty of times. I have a complete set I was given in Spring Hill, TN when I was trained to be a Saturn technician by the engineers who desigened and built the car. Used them on an almost daily basis at the dealership as well.
Yes, as a matter of fact I have, on a daily basis. When a car in the shop is lifted with the floor jack, the FACTORY JACK POINTS are used, since that's what they are there for. Cars were also jakced up using the factory jack points, as outlined in the owner's manual, by instructors at the Saturn Technical Training School. I suppose you know more than the people who designed and built the car though.
Old 07-13-2009, 07:00 PM   #15
bigbird
bigbird's Avatar
That is the only correct statement you have made so far.
Old 07-13-2009, 07:33 PM   #16
Squareback
Squareback's Avatar
2005 ION-2 Sedan
I'd agree with you, but then we'd both be wrong. You do it your way, I'll do it mine. Everyone's happy.
Old 07-13-2009, 08:02 PM   #17
bigbird
bigbird's Avatar
Sounds good to me. Happy jacking
Old 07-13-2009, 08:36 PM   #18
Joe270
Joe270 is on a distinguished road
The frame is painted black, too. Don't put a floor jack under any of the aluminum parts under there, they'll break. Also, don't put it under the control arm, it's painted black and looks like part of the frame, but it's not. The control arm goes out to the front wheels.
It might give you peace of mind to rap on the metal with a socket wrench or screwdriver, that way you're sure it's steel and not plastic.
Once you figure out what is and what isn't frame, then you have plenty of places to choose from.
Add to Joe270's Reputation
Rate the quality of this post and help Joe270 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Joe270 is offline   Reply With Quote
Old 07-13-2009, 08:52 PM   #19
SaturnSdn
SaturnSdn will become famous soon enoughSaturnSdn will become famous soon enough
SaturnSdn's Avatar
2007 ION-3 Sedan
2007 ION-3 Sedan
I jack my car up right there center of the first picture at the opening in the frame
I put the jack stands right at the bolt in the second picture
If you or anyone wants to place the jack or stands in another location, thats fine with me.
Add to SaturnSdn's Reputation
Rate the quality of this post and help SaturnSdn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SaturnSdn is offline   Reply With Quote
Old 07-13-2009, 09:03 PM   #20
Joe270
Here's a good idea. In the thread I started 'Anyone want to see rebuild photos', the very first photo shows the frame clearly. It also shows the 'lift points' where the garage lift was set to lift the car.
You can easily identify the 'lift points' and the frame from that photo.
I hope it helps.
How do I use jack stands? hufhouse L-Series Tech 7 03-02-2009 10:17 PM
Where are jack points and where to put stands darnell89 S-Series Tech 3 12-15-2007 11:37 PM
Jack Stands on Vue john95SW2 Vue General 3 10-31-2007 02:26 PM
? about jack stands americanbulldog S-Series General 23 11-21-2006 06:39 PM
Where to put jack stands and jack up a 1996 SL2 almies S-Series General 2 10-25-2005 02:13 PM
