Old 07-12-2009, 08:02 PM   #1
RichBrown
RichBrown is on a distinguished road
RichBrown's Avatar
1991 SC
Dizzy Rebuilding 95 DOHC SC2
Just a recap:
Burning 1qt every 200 miles. (29-33mpg) 133,000 mi bluesmoke @ high rpm
Guy from saturn took a quick over and states it may just be the valve stem seals... Sooo I've purchased the following so far:
1 Rebuilt Head complete.
1 Head Gasket Kit
1 Valve Cover Gasket Kit
1 Timing Chain Set
Will I be able to replace the rings with the head off and should I?.. I'm running low on funds so far What's your opinions.. If do the rings dont I need to have it honed? It also needs a clutch so I may just have to pull it entirely.. Sorry for my ignorance, first time digging this far into the engine..
Richard Brown
saturn@mhvnet.com
Current: 1995 Saturn SC2 1.9L DOHC
Dude where's my oil?
Previously Owned:
1991 SC 80k
1992 SC 92k
2001 SC2 33k
1995 SC2 131K
1993 SC2 110k
1996 SC2 101k
Add to RichBrown's Reputation
Rate the quality of this post and help RichBrown reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RichBrown is offline   Reply With Quote
Old 07-12-2009, 08:30 PM   #2
RichBrown
RichBrown's Avatar
1991 SC
Default Re: Rebuilding 95 DOHC SC2
OldNuc wrote: If ther is absolutely no metal top ridge then you can push the pistons out the top and re-ring them with standard rings. There will be a carbon ridge that you have to remove first. Drill the drain holes and make about 3 to 6 pases with a 320 grit bottle brush hone. Use lots of saran wrap to keep the grit out of the good parts and wash down with hot soapy water. Do not try and pull a piston out the bottom. It will lock in the grove below the liner and will have to be removed in small pieces.
New rod and main bearings are not a bad idea either.
Richard Brown
saturn@mhvnet.com
Previously Owned:
1991 SC 80k
1992 SC 92k
2001 SC2 33k
1995 SC2 131K
1993 SC2 110k
1996 SC2 101k
Old 07-12-2009, 08:47 PM   #3
You are burning way too much oil to be dumping it all down the valve guides. Definite ring job. Look in the classified here as someone was selling a bottle brush hone.
Old 07-12-2009, 08:57 PM   #4
RichBrown
RichBrown's Avatar
1991 SC
Roll Eyes Re: Rebuilding 95 DOHC SC2
I am still driving this car.. after purchasing a rebuilt head, should I now just grab a block from a junk yard with less mileage as a donor? As far as I can tell they are nearly all interchangeable? this way I can rebuild and throw the valve cover on last before installation?
Richard Brown
saturn@mhvnet.com
Previously Owned:
1991 SC 80k
1992 SC 92k
2001 SC2 33k
1995 SC2 131K
1993 SC2 110k
1996 SC2 101k
Old 07-13-2009, 08:15 AM   #5
Highmile
Highmile's Avatar
I would think that at 133k the block would still be ok to use. Unless it's been used really hard or all stop/go traffic the cylinders should be ok. I used a 170k mile block (all hwy miles) for my daughters '93 with nothing more than a quick hone job and it runs great and doesn't burn a drop of oil.
The oil burning you are seeing is almost without a doubt stuck oil rings. The opinon of many here (me too) is the piston design is poor. There is information on this page about how to modify your pistons to prevent it from happening again or you could take the route I did. I bought a new set of speed pro pistons from my local autoparts store. I believe I paid about $125 for the new pistons.
Remember, that if you are going this far you might want to throw a new timing chain on it too.
Also remember, the valve seals in a dohc are not really that easy to replace. It takes some special tools so make sure you have the tools you need before you jump in.
Highmile
'95 SL1 409k and counting
'93 SL2 130k and counting (daughters car)
Add to Highmile's Reputation
Old 07-13-2009, 08:21 AM   #6
A core engine is about a 100.00 part or less. So having an engine rebuilt and ready to go makes life very easy. This swap guide tells you what swaps. http://saturnwiki.org/index.php/Swap_Guide
Rebuilding the spare is the easiest way to do the job. That way there is no rush to get the daily driver going again. All of the aluminum parts can go out to be dipped and cleaned. And that does beat the heck out of scrubbing in the frame, or in the kitchen sink. The list of benefits gets longer.
Old 07-13-2009, 08:47 PM   #7
RichBrown
RichBrown's Avatar
1991 SC
Every block I can find is 160-200$ from a junk yard.. $140 from a pick and pull.. any suggestions?
Also, ANYONE in NY want to give me a have rebuilding this.. Obviously someone who has performed this before.. Thanks..
Thanks Guys!
Richard Brown
saturn@mhvnet.com
Previously Owned:
1991 SC 80k
1992 SC 92k
2001 SC2 33k
1995 SC2 131K
1993 SC2 110k
1996 SC2 101k
Old 07-13-2009, 08:48 PM   #8
RichBrown
RichBrown's Avatar
1991 SC
Thumbs Up Re: Rebuilding 95 DOHC SC2
OLDNUC man you are awesome! I've been away from Saturns for soo long its nice to see people still love them! It was many years ago when I owned my plethora of SC's Thanks !
Richard Brown
saturn@mhvnet.com
Previously Owned:
1991 SC 80k
1992 SC 92k
2001 SC2 33k
1995 SC2 131K
1993 SC2 110k
1996 SC2 101k
Old 07-13-2009, 09:31 PM   #9
You can search for a core block here.
http://car-part.com/
They are nice basic reliable cars. Basic is good because all of the gingerbread costs real money to fix when it breaks.
Old 07-18-2009, 01:11 AM   #10
RichBrown
RichBrown's Avatar
1991 SC
Wrench Re: Rebuilding 95 DOHC SC2
WELL The teardown was successful! The head/block bolts were a fuss but they eventually came free... Scraping, Cleaning and Hottank next. woohoo!! I have a few questions now.
Q1. The cylinder's still have clean hone marks and I don't believe they need any work, nice crisscross pattern still. The hottank will not mess any of that up?
Q2. The pistons show some hotspots on top or wear marks, you can see it in the pics.. Should I replace? or just clean and re-ring?
Q3. If you look at the Crankshaft pics there are very minor scratches, nothing my finger nail could catch on. All in all I was surprised after seeing the funked up head that nothing looked too bad aside from the pistons in the block.
Q4. The same minor scratches are on the piston shaft bearings, just replace all the bearings? Can I re-use the shafts? they look ok to me LoL.
Q5. The timing chain looked brand new, no play at all.. The one I bought is aftermarket $80 on ebay. I hear the OEM is better, should I reuse or just put on the new one?
Thats about it...
Thanks for all your answers people! I appreciate the help!
1995 DOHC 1.9L Donor
Valve Cover Removed
Timing Chain -Looked brand new! no play at all..
Holy Carbon Balls of Oil.. Mmmm Tasty
Cylinder #1
Cylinder #2 (most of that is from turning over the engine with some oil left somewhere..)
Cylinder #3
Cylinder #4
Piston #1
Piston #1 w/wear
Bearings
Crankshaft wear
Crankshaft wear
How tranquil it is out of the engine
What do you think people?
Rich
Richard Brown
saturn@mhvnet.com
Previously Owned:
1991 SC 80k
1992 SC 92k
2001 SC2 33k
1995 SC2 131K
1993 SC2 110k
1996 SC2 101k
Old 07-18-2009, 02:15 AM   #11
A1. Measure them. the hone marks are cut in with a very coarse diamond hone and are close to 10 thou deep, thats almost a 20thou bore to clean them out. Check for a ridge at the top of the cylinder, clean the carbon off with a oiled scotch brite and then feel the ridge with your fingernail.
A2. first measure the cylinders. if you have to bore then you can replace the pistons. If the wear is 3 thousands or less then it will be time to evaluate the pistons. You do that by cleaning and measuring.
A3. Once again measure and maybe you get away with a polish. The max clearance with a standard bearing should be .001 to .0015 and if its more then its either a new used crank or a regrind. Low Saturn has cranks I believe.
A4. I assume that by "piston shaft" you mean the rod journal on the crank. Same answer as above, measure and if lucky polish.
A5. Buy a Cloyes complete timing set. The sprockets wear to the chain and a new chain is instantly trashed by used sprockets.
Thats about it...
Rich
Whoever is going to hot tank the aluminum parts can do the measuring. I assume that it is a rebuild shop. They can probably do you right on gaskets and headbolts also. You are disassembling and cleaning those lifters, right?
Take a ruler and measure how much round shaft is sticking out of teh chain tensioner. It looks like its done for. The part of the piston you want to look at is the 2 thrust faces on the skirt, not the top. The top is fine. look at the 2 sides 90 degrees to the wrist pin axis.
Old 07-18-2009, 02:53 AM   #12
RichBrown
RichBrown's Avatar
1991 SC
Brand New Rebuilt head Should be here tomorrow!
Richard Brown
saturn@mhvnet.com
Previously Owned:
1991 SC 80k
1992 SC 92k
2001 SC2 33k
1995 SC2 131K
1993 SC2 110k
1996 SC2 101k
Old 07-18-2009, 10:40 AM   #13
RichBrown
RichBrown's Avatar
1991 SC
Question Re: Rebuilding 95 DOHC SC2
I'm hearing alot of yaa/Naa about hot tanking.. I realize the alternative is hard work and sweat, is there a product I can pick up at a local parts store or hardware that would make it easier? I know of some nasty stuff I cant remember the name of but I'd hate to corrode the crap out of anything..
Richard Brown
saturn@mhvnet.com
Previously Owned:
1991 SC 80k
1992 SC 92k
2001 SC2 33k
1995 SC2 131K
1993 SC2 110k
1996 SC2 101k
Old 07-18-2009, 11:15 AM   #14
Strip the aluminum parts down and take them to the shop along with the crank and flywheel if its a manual. Get the flywheel surfaced and teh crank measured. Clean the aluminum and measure the bores. It will be money well spent. there is absolutely nothing that you can legally buy or dispose of that will clean that aluminum.
You can buy a gallon or 2 of this stuff and clean your smallparts like pistons, lifters etc.
The gallon Can of this stuff is available at your parts store.
http://www.berrymanproducts.com/Default.aspx?tabid=146
Or you can order some of this stuff.
http://www.orisonmarketing.com/clean...on/carbon.html
The cost of the chemicals and brushes for a DIY block and timing cover cleaning will exceed the usual charge at a shop. And you do not have to spend several days doing it. You need real hot water for the best ricing also. What will your wife or mother say about washing the block in the bath tub?
I suspect that some peoples definition of "clean" is different than mine.....
Old 07-18-2009, 11:35 AM   #15
BarnOwl
BarnOwl's Avatar
You should see what they say when you do it in the dishwasher.
Add to BarnOwl's Reputation
Old 07-18-2009, 01:11 PM   #16
The dishwasher does a real good job on small parts.
That is almost as good as curing GunCote in the oven while she is out and she comes back before you get the smell ventilated out off the house.
Old 07-18-2009, 06:05 PM   #17
blackeagle1
blackeagle1 is on a distinguished road
blackeagle1's Avatar
2000 SL2
A $10 gallon of Purple Power, a spray bottle and some small brushes is plenty to clean the block and everything else during your rebuild. You will be amazed out how easy the grime comes off with this stuff. Just rinse with water when done.
Current Fleet:
97 Black Gold SC2 Manual
97 Silver SC2 Auto
98 White SL2 Auto
00 Silver SL2 Auto
03 Pontiac Montana
00 Yamaha SUV1200 Waverunner
Add to blackeagle1's Reputation
Rate the quality of this post and help blackeagle1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
blackeagle1 is offline   Reply With Quote
Old 07-18-2009, 09:45 PM   #18
RichBrown
RichBrown's Avatar
1991 SC
Your damn right!! although I bought a bucket doe $24 and just let the parts sits for about 5 minutes and wiped/washed them down.. AWESOME difference.
Richard Brown
saturn@mhvnet.com
Previously Owned:
1991 SC 80k
1992 SC 92k
2001 SC2 33k
1995 SC2 131K
1993 SC2 110k
1996 SC2 101k
Old 07-18-2009, 09:46 PM   #19
You still get to pay to measure the crank and bores. If you drag it in and they clean it the cost is minimal as they are looking at the potential additional work. You have to buy your timing set, pistons (if required), rings, bearings, gasket set, and head bolts somewhere. You will get a better price than anywhere else from the local guy if you play it right.
Old 07-18-2009, 09:51 PM   #20
RichBrown
RichBrown's Avatar
1991 SC
I dont have access to a micrometer but I used my butties dial something so I don't know if its accurate but the piston measured 3.226 and the book says minimum is 3.233? Now the odd thing is the cylinder somehow measured 3.224? How is that possible? fyi there was NO carbon edge when I removed the head. I plan on bringing the block, pistons, and crank to a shop on Wednesday for a look over. Also going to have it hottanked while I'm there.. damn I wish these places were open on the weekend!
Richard Brown
saturn@mhvnet.com
Previously Owned:
1991 SC 80k
1992 SC 92k
2001 SC2 33k
1995 SC2 131K
1993 SC2 110k
1996 SC2 101k
Rebuilding 1.9 dohc with my daughter. Joel65 S-Series General 10 02-14-2009 01:46 PM
Completed rebuilding 1.9l dohc, piston question dsbike S-Series Tech 0 06-17-2008 08:15 PM
rebuilding 1.9l dohc, piston question dsbike S-Series Tech 5 06-12-2008 09:06 PM
Rebuilding a DOHC???? tjd83 S-Series Tech 3 02-10-2007 09:51 PM
1994 DOHC issues = replacing/rebuilding?? chadrules S-Series Tech 30 11-04-2005 12:41 AM
