Old 07-04-2009, 12:04 PM   #1
sdowney717
sdowney717 is a glorious beacon of lightsdowney717 is a glorious beacon of lightsdowney717 is a glorious beacon of lightsdowney717 is a glorious beacon of lightsdowney717 is a glorious beacon of light
Default how do you set time on 2003 ion CD radio ?
I just put one in.
Also, the little central window that displays everything, is that supposed to dim with the dash lights or is it just on and off with the radio?
how about at night if radio is off, does the clock light up with the dash lights?
Add to sdowney717's Reputation
Rate the quality of this post and help sdowney717 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sdowney717 is offline   Reply With Quote
Old 07-04-2009, 12:32 PM   #2
daver
daver has a spectacular aura aboutdaver has a spectacular aura about
daver's Avatar
2005 ION Red Line
Default Re: how do you set time on 2003 ion CD radio ?
If yours is the same as mine, here's what to do:
The secret is to push in the RCL button and hold it, but you have to hit the left (to increase the hour) or the right (to increase the minutes) arrow on the Auto EQ button BEFORE you hear the beep.
P.S. If you use the "Custom" setting on the EQ, it resets to "Flat" any time the power is disconnected and you have to reset it.
The radio display should dim when you turn on the parking lights and/or headlights. Clock should display whenever power is turned on with ignition key.
Add to daver's Reputation
Rate the quality of this post and help daver reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
daver is offline   Reply With Quote
2003 Ion CD Radio in 95 SL2 sdowney717 S-Series Tech 2 02-01-2016 01:54 PM
2004 Vue radio in 2003 Ion? Leonard1818 Ion Tech 4 11-28-2009 05:28 PM
2003 Ion Radio wiring diagram Spadeislander Ion General 13 05-31-2007 07:17 AM
HELP, need 2003 Ion Coupe Radio Harness Pinout Barrycraig70 Ion Mods 0 05-10-2006 08:57 PM
FS:Pioneer ((XM)) radio & 2003-2004 Ion factory floor mats SilverExpress Classifieds 0 03-11-2004 11:25 PM
