Old 07-02-2009, 03:07 PM   #1
Bea
Bea is on a distinguished road
1996 SC1
Default TPS or Operator idiocy?
I am trying to fix my 96 SC1, but am not liking my Haynes manual much right now. My service light came on about two weeks ago, followed by blowing fuses for my cruise control. The car ran the same, but a week later, my SES light came on for only two or three days.
After reading a few threads here, I think it may be my TPS, as my gas pedal has been known to intermittently "stick" when trying to accelerate from a stop. Also, this happened about two weeks after I started taking a route to work that involves about ten miles a day on gravel roads. ( yeah, I live in a farming area.) Other consideration is that I drove the car here to Washington state from Kentucky about a month ago, and it had no problems with any of that.
My car is 5speed 1.9L SOHC with about 182,000. I changed the plugs, wires, thermostat, flushed cooling system, changed the oil and filter.
I want to test my TPS, but really need a visual for this. I have the specs in my Haynes manual, but no clue otherwise. ( yes, I have a multimeter, too!)
Add to Bea's Reputation
Rate the quality of this post and help Bea reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Bea is offline   Reply With Quote
Old 07-02-2009, 03:29 PM   #2
rickystarshine
rickystarshine has a spectacular aura aboutrickystarshine has a spectacular aura about
rickystarshine's Avatar
2005 ION-2 Sedan
Default Re: TPS or Operator idiocy?
After the SES light came on, did you get the codes read? If not, do so & report what they are here, even if the light is not on now, the codes are probably still there, without this info, any suggestion is a guess.
Also, replace the ECTS, use the search feature of these forums to look it up.
make sure you did not install platinum plugs as well, they do not work well in these engines...
2005 ION 2 5 spd 202,155 miles
2001 SL1 Auto 298,252 miles
1997 Sl1 Auto 163,266 miles
Add to rickystarshine's Reputation
Rate the quality of this post and help rickystarshine reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rickystarshine is offline   Reply With Quote
Old 07-02-2009, 03:31 PM   #3
adventureoflink
adventureoflink's Avatar
1) did you bother to get the service wrench and the SES codes read? If not, go to a Saturn or GM $tealer or a car-x or something (yeah yeah I know, AutoZone reads codes for free, but AZ reads SES codes, and the OP has service wrench and SES on, so fwiw it'd be best to goto a $tealer)
2) I'd be looking out for a cracked head in the sohc engines
3) ECTS, did you replace it?
97 SL2
DOB: 3/19/97
Date Obtained: 5/30/07
Status: Alive, 1/2 exhaust
2004 Merc G.Marquis GS
DOB: 2/4/04
Date Obtained: 7/6/12
Status: Alive, no heat
Old 07-02-2009, 04:26 PM   #4
ahimsa1
ahimsa1 is on a distinguished road
1997 SW1
Your sticky gas pedal is most likely caused by carbon build-up inside your throttle body. It's easy to clean out, and there's a how-to here:
http://saturnseries.net/DIY%20Guides...gh%20clean.htm
97 SW1 Auto 174k
Add to ahimsa1's Reputation
Rate the quality of this post and help ahimsa1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ahimsa1 is offline   Reply With Quote
Old 07-02-2009, 04:38 PM   #5
eRic 02sc2
eRic 02sc2's Avatar
Wrench Re: TPS or Operator idiocy?
get the code read.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 07-03-2009, 12:16 PM   #6
Bea
1996 SC1
Dizzy Re: TPS or Operator idiocy?
Thanks for all the info, everyone. Once I got the throttle body off, I was suprised that the butterfly even moved at all with all the buildup inside. The IAT valve was not much better. I cannot tell you if cleaning this stuff up has solved the issues... having a hard time finding a throttle body gasket locally.
Before I took it apart, I did go to Autozone and had it checked for codes. Apparently, they cannot pull codes from a dead port. ( I removed the knee guard last week, must have made a boo boo putting it back together.)
Old 07-03-2009, 01:07 PM   #7
Here's a partial wiring diagram. It looks like only three connections to the OBD II connector. There may be more, 12v power and this may be fused so it may help to check all the fuses for the blown one.
TPS CE light, replaced TPS, light came back! DJboozeAlot S-Series Tech 6 07-13-2009 01:18 AM
Tps devolic S-Series Tech 5 07-25-2007 09:21 AM
Tps? quiksc2 S-Series Tech 3 06-22-2007 02:17 PM
eBay Idiocy THX712517 General Saturn Discussion 21 04-17-2003 12:24 PM
TPS jcesl2 Classifieds 0 08-09-2001 05:25 PM
