Old 07-02-2009, 01:37 PM   #1
wy2sl0
wy2sl0 is on a distinguished road
wy2sl0's Avatar
Default Got my scanner, some info inside to decode....
So some of you may know I just picked up my 97 sc2 couple weeks ago. It had a CEL which hasnt reappeared since I ran seafoam through it. I bought a cheap ebay scanner anyways, and pulled the codes and did a WOT run to find out some information on o2 stats also.
p0341 was the code I believe, other was EGR circuit low.
02's under wot were between 925-950, so that is good.
LTFT's under cruise were -2.3% so its slightly rich.
Heres the big thing. Coolant temperature during cruise etc stayed around 73-74*C. Im almost positive that is low, and could explain part of the slightly rich condition. My temp gauge reads a sliver over 1/4 usually.
What can I take from this?
Add to wy2sl0's Reputation
Rate the quality of this post and help wy2sl0 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
wy2sl0 is offline   Reply With Quote
Old 07-02-2009, 03:19 PM   #2
DonP
Default Re: Got my scanner, some info inside to decode....
If your ECTS and connector are known to be good and clean, the 73 C report corresponds to about 163 F, and that implies a stuck-open T-stat.
P0341: Camshaft position sensor circuit range/performance. This DTC will determine if the cam is synchronized correctly. it sets if the cam signal falls in the wrong location three times.
Th EGR low may have been a P0405?
Add to DonP's Reputation
Old 07-02-2009, 04:10 PM   #3
wy2sl0
wy2sl0's Avatar
Yes thats right. I read that on Saturns p0341 has to do with bad plugs/wires/coil pack connections? Is this true?
And 0405 was the code for EGR
Old 07-02-2009, 04:42 PM   #4
Fox Slaughter
Fox Slaughter is on a distinguished road
Fox Slaughter's Avatar
These cars run rich from the factory.
I'll be sitting at my desk
With a gun in my hand, wearing a bulletproof vest singing
"My, my, my, how the time does fly, when you know you're going to die
By the end of the night."
Add to Fox Slaughter's Reputation
Rate the quality of this post and help Fox Slaughter reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Fox Slaughter is offline   Reply With Quote
Understanding Scanner info ? Ignition Advance ? cboss S-Series General 2 11-04-2008 08:34 PM
Reading info on a OBD 2 scanner ? Grinch01 S-Series General 1 03-18-2008 09:37 PM
OLM inside info. GearGuy Vue Tech 4 12-18-2006 08:06 AM
My Review of the 2005 NYIAS. (Aura and Sky Info inside!) TBone1082 Aura General 21 04-06-2005 06:09 PM
Saturn SW2 vin decode? BuzzStPoint S-Series General 2 01-20-2005 12:50 PM
