#1 | ||||
![]() Join Date: Dec 2006
Hello, I have a problem similar to this thread saturnfans.com/forums/showthread.php?t=50387&highlight=high+pitch+sound
When the engine is cold, I can drive for around 3-5 miles and the sound will then appear when I let off the accelerator. While I am driving or at a stop, if I press the accelerator just a tad the noise goes away. If I let off just a tad the noise comes back. THere have been a couple times that I have driven for miles and the sound doesn't rear it's ugly head *Usually when I am trying to show someone* but for the most part it does it everyday on the way to work intermittently all the way to and from. Now When I get to work or get home which is about 25miles, I put my vehicle in park and the rpms start to rise gradually until I turn off the engine. If I put it in drive the rpms kick down for what I assume are obvious reasons. I have listened for vaccum leaks but I cannot seem to find any anywhere. I noticed that when the rpms are going haywire, if I disconnect the plug from the sensor at my air filter, the rpms kick back down and the sound will only appear when I raise the rpms/press accelerator. The noise *Seems* to be coming from the air intake flapper area. Any ideas or suggestions would be appreciated.
#2 | ||||
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2008
Do you have four or six cylinder?
Will help when searching for various bulletins.
#3 | |||||
#4 | ||||
I'm sorry... It is a 6cyl 3.0L AWD
Although I know that pdf was for a 4cyl I pulled the dipstick for the sake of elimination and the noise didn't go away. Also thank you for your time with this I am going to run it uptothe local schucks tomorrow and see if they can't pull a code off of it. The check engine light also came on the same time this started. Oddly enough, I ran it through emissions a month early to avoid any rush... This happened right after that... If I hadn't ran it through early they wouldn't have tested it
#5 | |||||
I'll see if there's a squeal fix for the 3.0. Please post the code(s) if present ... they are very helpful ... there are 3.0 owners on this forum who have this stuff memorized.
#6 | ||||
Just to let you know, the code was PO171 which basically told me there was
a leak somwhere so I pulled out the stethescope at work and started probing around and found out that when I had the spark plugs replaced there was a bolt not tightened near the air intake flapper... I tightened that down and the squeal is gone and check engine shut off. Thank you for your time with this.. I appreciate it much.
| Thread Tools | |
| Display Modes | |
| Very High Pitch Noise only at high speed, and doesn't depend on engine load | StandsOnToes | S-Series Tech | 2 | 01-06-2010 05:00 PM |
| High pitch from radio after shutting down | joe525 | S-Series General | 2 | 06-12-2006 12:56 PM |
| High pitch squeal in drive | Angry_Inch | S-Series General | 5 | 02-16-2006 05:25 AM |
| High pitch grinding noise | plumsl2 | S-Series Tech | 1 | 07-17-2005 12:34 AM |
| High pitch whine over 60 mph? | geepondy | S-Series General | 5 | 09-25-2004 10:27 PM |
