Old 06-29-2009, 12:20 AM   #1
The Critic
The Critic is on a distinguished road
The Critic's Avatar
1996 SL2
Default RF Strut Rattle
Last Sunday, I replaced all four struts with KYB GR-2 units. I also replaced the front strut mounts with KYB branded mounts. I have since put 500 miles on the car.
Starting tonight, I am hearing a little rattle from the RF strut. I'm not sure what the problem is.
When I installed the struts, I marked the old strut mount, rubber insulator and old strut assembly with whiteout. Then, I made the very same marks (in the same spots) on the new strut mount and new strut assembly. Therefore, when I did the final assembly, I just lined up the "whiteout dots" so that everything went back on in the same orientation as the original. So, I think my installation is correct?
One thing that I did not do was that I did not use the washer on the new KYB strut mounts. It didn't look like it would fit, but I didn't try either. Was I supposed to?
Anyway, any advice on diagnosing the strut rattle is greatly appreciated.
Thanks!
'10 Altima 3.5SR V6- 5k
'96 SL2- 150k!
'92 Previa- 99k
Add to The Critic's Reputation
Rate the quality of this post and help The Critic reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
The Critic is offline   Reply With Quote
Old 06-30-2009, 05:06 PM   #2
Greg1
Greg1 will become famous soon enough
Greg1's Avatar
Default Re: RF Strut Rattle
For what it is worth I did use the washer and have not had any problems.
97 SW2 5-Sp 273k -mine
02 SC2 5-Sp 67k - best friend's
Add to Greg1's Reputation
Rate the quality of this post and help Greg1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Greg1 is online now   Reply With Quote
Old 06-30-2009, 07:06 PM   #3
Depending on the size of the hole in the mount, the age of the mount, and the type of bumpy (or not) roads you deal with the washer prevents the strut from pulling through the mount. Like mine did when I found one of my new mounts got mangled and became unusable so it forced me to reuse an old mount, then I forgot to put the washer on. That was a interesting trip down/up my driveway
Rattle in rear, bad strut mount? TvSteve S-Series Tech 10 06-26-2011 07:00 PM
Rattle in front strut/shcok area of 2006 Vue Bedlam Vue General 20 03-30-2009 02:02 PM
Dealer replaced strut, strut mount, and strut bearing tomcatt1 Vue General 17 10-03-2007 04:53 PM
New Strut Braces' -> New Rattle.. - 2001 Sc2 01SIlverSc2 S-Series Tech 4 04-04-2007 06:37 PM
1994 SL2, Cold Rattle/Warm No Rattle Slight Hesitation acidburn_335 S-Series General 0 09-02-2004 08:34 AM
