Old 06-29-2009, 08:21 PM   #1
dkhueyjr
dkhueyjr is on a distinguished road
Default 98 sl2
HELP
I have a 1998 SL2
I am losing fuel outy the solenoid ASM-EVAP CANISTER VENT VALVE
installed a new one and same thing! I just put a used motor in this car what could I have screwed up to cause this issue? what controls the vent valve? it is pumping out gas fast... Help me please
Add to dkhueyjr's Reputation
Rate the quality of this post and help dkhueyjr reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dkhueyjr is offline   Reply With Quote
Old 06-29-2009, 08:54 PM   #2
acman
acman has a spectacular aura aboutacman has a spectacular aura aboutacman has a spectacular aura about
1999 SC1
Default Re: 98 sl2
The root cause of this problem may be the coolant temperature sensor and / or a sticking thermostat. Saturn has a bulletin, #05-06-04-049, for a false code p0442. The fix is to replace the coolant temperature sensor and connector - if corroded - and replace the thermostat. It is believed that a misreading sensor and in conjunction with a sticking thermostat that the test for the evap emission system is running at the wrong time and getting false readings.
This bulletin may or may not apply to your situation. Start by checking for stored trouble codes.
1997 SL2, 5 speed
1999 SL1, Automatic
Add to acman's Reputation
Rate the quality of this post and help acman reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
acman is offline   Reply With Quote
Old 06-30-2009, 01:31 AM   #3
adventureoflink
adventureoflink's Avatar
Default Re: 98 sl2
dude it's a '98 S-series, wouldn't an ECTS and/or t-stat (195 degrees F) be in order anyway
97 SL2
DOB: 3/19/97
Date Obtained: 5/30/07
Status: Alive, 1/2 exhaust
2004 Merc G.Marquis GS
DOB: 2/4/04
Date Obtained: 7/6/12
Status: Alive, no heat
Old 06-30-2009, 08:19 PM   #4
Default Re: 98 sl2
Welcome to the Board.
The coolant temp sensor would have nothing to do with fuel coming out of any solenoid.
Are you talking about the solenoid under the intake manifold?
Are the vacuum lines hooked up properly? All the wiring ok, not pinched?
Add to ssicarman's Reputation
00 SL2 rear roof moulding on a 98 SL2; will it fit? MadPuppy S-Series General 3 09-01-2009 09:13 AM
2001 SL2 auto trans into 1993 SL2 2003MercMaraude S-Series Tech 3 12-27-2008 06:58 PM
94 SL2 aut. gauge cluster fit 92 SL2 auto? 92[SL2] S-Series Tech 2 07-17-2007 05:10 AM
Wiring Trunk Latch Assembly from 98 SL2 Into 95 SL2 - Need Help STRNFAN93SL2 S-Series Tech 4 06-13-2007 07:05 PM
will a '00 sl2 sunroof glass/motor/etc fit a 94 sl2 Fricken eh! S-Series Tech 1 09-17-2004 01:11 PM
