Old 06-26-2009, 12:06 PM   #1
bboynowee
bboynowee is on a distinguished road
bboynowee's Avatar
Question changing clutch oil? tranny oil?
..I never have changed my clutch/tranny fluid on my 98 SL2 manual transmission...but I want to change both....and want to do it myself...any tips guys....what oils should i use? any tips?
"Saturn are the best sleepers"
"My Saturn Kicks your Uranus"
Add to bboynowee's Reputation
Rate the quality of this post and help bboynowee reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bboynowee is offline   Reply With Quote
Old 06-26-2009, 12:10 PM   #2
PurdueGuy
PurdueGuy's Avatar
1999 SC1
Default Re: changing clutch oil? tranny oil?
leave the clutch fluid alone. The system is sealed and not bleedable.
Trans fluid is a piece of cake. Drain and refill.
SaturnSeries.net owner
Add to PurdueGuy's Reputation
Old 06-26-2009, 03:23 PM   #3
I'm pretty sure there's a richpin video in the How To library for replacing clutch fluid using a turkey baster.
As for transmission fluid, drain bolt is near the bottom of the case, lowest point facing the passenger side. Fill is throught the dipstick hole, so you will need a long funnel.
For fluid recommendations, look for posts by OldNuc with the words Amsoil TorqueDrive <--I think that's what he recommends. There are several recent threads discussing this. Might be in Tech section rather than General forum, though
Old 06-26-2009, 03:32 PM   #4
Col.FUBAR
Col.FUBAR is on a distinguished road
Col.FUBAR's Avatar
1994 SC2
To add on to alordofchaos' post. The clutch takes DOT-3 brake fluid
Add to Col.FUBAR's Reputation
Rate the quality of this post and help Col.FUBAR reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Col.FUBAR is offline   Reply With Quote
Old 06-26-2009, 03:45 PM   #5
bumpdraft
bumpdraft's Avatar
1998 SW2
My clutch pedal started to get a little catchy when slipping the clutch in first.
I'd already changed the clutch pedal bushings and lubed the heck out of everything with quality silicone grease.
Using a large syringe and fresh D.O.T. 3 brake fluid, I was changing the hydraulic fluid one master cylinder reservoir at a time. Careful not to remove too much and get air in the system.
Yesterday (hot and humid) is was very stickyand creeky
Today, I bought a new Clutch hydraulic System
Maybe I should have done preventive maint by changing the fluid years ago, or, what Perdueguy says is true.- The clutch fluid lasts until the system fails.
Add to bumpdraft's Reputation
Old 06-26-2009, 05:53 PM   #6
MikeNW
MikeNW's Avatar
1997 SL
Brake fluid, which is used in the clutch system and the brake system, is hygroscopic (attracts water).
How does water get into sealed systems? It just does after a long time.
Personally, I like to change brake fluid every couple of years (the stuff that comes out is yukky) also the power steering fluid (with a turkey baster, do it several times and you can get almost 100% of the old stuff out).
I just went through clutch misery last spring + summer, so the clutch system is good for a while.
Good call on Amsoil tranny fluid. Will have to try it
08 Burgman 400
Add to MikeNW's Reputation
Old 06-26-2009, 05:55 PM   #7
MikeNW
MikeNW's Avatar
1997 SL
oh yeah, the O.P. states that he never changed the tranny fluid in his 98, that means he never put a clutch or axles in it? Must be living a good life!
08 Burgman 400
Old 06-27-2009, 02:46 PM   #8
S3aturnR
S3aturnR's Avatar
1999 SL1
don't.
i've changed mine twice now. both times it was because i removed the gearbox and had to drain it first. the first time i did it, the car had over 165k miles on it. fluid looked pristine.
clutch fluid? never heard of that. perhaps you mean the hydraulic fluid in the clutch line? it is possible to change it even tho the shop manual states that it is a non-serviceable part, but i would just get a new one before i messed with the old one. if this part is not broke, my advice is don't try to fix it...
s3aturnr
Add to S3aturnR's Reputation
Old 06-27-2009, 03:10 PM   #9
+1^^^Don't fiddle with the hydraulics, its not broke.
No need to change the trans fluid unless you want to use a different fluid.
Old 06-27-2009, 07:12 PM   #10
eRic 02sc2
eRic 02sc2's Avatar
Post Re: changing clutch oil? tranny oil?
the clutch uses DOT 3 brake fluid and should not need changing. If yours is low then something is leaking. The hydraulic clutch is sealed and cannot be bled. The manual transaxle fluid needed to be changed once at 6000 miles. use Dexron IIE or III automatic transaxle fluid in it. It takes 2.5L
This info is in the Saturn Owner's Handbook.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
oil filter change without changing the oil? davesaturn Ion Tech 22 12-26-2009 03:22 PM
Change Oil Filter WITHOUT Changing Oil? Supermarine Vue General 5 10-21-2009 04:00 AM
Changing the oil ggking7 S-Series General 30 02-05-2007 11:17 AM
GF-4 Oil is here/coming...oil formulas are changing. Tiger S-Series Tech 9 11-01-2004 12:25 AM
Lkng 4 advice on changing to synth. oil & tranny fluid ynotps Vue General 17 08-18-2004 08:52 PM
