Old 06-19-2009, 09:18 PM   #1
wy2sl0
wy2sl0 is on a distinguished road
wy2sl0's Avatar
Default Just bought used SC2, something weird in 2nd gear
Hi everyone.
If I use 15% throttle, or even wide open, the car will in second gear only mind you, seem like it is shifting into a gear that is between 2nd and 3rd and RPMS will drop, in the middle of the gear. Its so weird to explain. If I am WOT it will hang there for a couple seconds, and if im going easy it just does a mini shift it seems like, but it isnt the 2-3 because when I count its like I have 5 gears
If im on it heavy the shifts seem ok besides that so I dont think its slipping?
Thanks for reading any ideas will help! Im just doing Seafoam now so I havent changed the plugs yet but im going to change them after that and then do a tranny flush and filter.
wy2sl0 is offline   Reply With Quote
Old 06-19-2009, 09:56 PM   #2
wy2sl0
wy2sl0's Avatar
Default Re: Just bought used SC2, something weird in 2nd gear
Originally Posted by wy2sl0 View Post
Hi everyone.
Just to add I dug this up and this is EXACTLY WHAT MINE DOES, except at ALL throttle inputs
saturnfans.com/forums/showthread.php?t=117749&highlight=2nd+gea
It doesnt seem normal
Old 06-20-2009, 01:43 AM   #3
wolfman
wolfman's Avatar
During normal shifting the TAAT transaxle locks and unlocks the torque converter based on engine load, speed, throttle position etc. This will cause a change in the engine rpm. That is what you are seeing. Normal.
Old 06-20-2009, 01:50 AM   #4
Fox Slaughter
Fox Slaughter is on a distinguished road
Fox Slaughter's Avatar
Just bought an SC2 throw some Ds on dat *****! Yuck rap. ROFL.
I'll be sitting at my desk
With a gun in my hand, wearing a bulletproof vest singing
"My, my, my, how the time does fly, when you know you're going to die
By the end of the night."
Fox Slaughter is offline   Reply With Quote
Old 06-20-2009, 01:51 AM   #5
MoparNut
MoparNut will become famous soon enough
MoparNut's Avatar
wy2sl0: you didn't post up what year your car is...if it's an '02 it may have the 2-3 clutch housing issue (poor surface finish causing piston seal degradation)
MoparNut is offline   Reply With Quote
Old 06-20-2009, 07:44 AM   #6
wy2sl0
wy2sl0's Avatar
Its a 97.
I think it has the plastic ECTS also :-S
Old 06-20-2009, 08:46 PM   #7
MoparNut
MoparNut's Avatar
Ooh...def change that, and the connector if it's green. I'm too lazy to look, but I'm sure the ect sensor issue has been fully beaten to death
auto 95sw2 2nd gear doesnt fully engage until right before 3rd gear shift? kaptnjack S-Series Tech 4 01-06-2010 08:10 PM
2001 SC2 Drops hard or harshly into 2nd gear from cold start Glenn B S-Series Tech 7 09-04-2009 08:34 AM
2nd gear moses09 S-Series General 2 08-30-2006 10:21 PM
2002 SC2 popping out of 2nd gear TheGuy S-Series Tech 11 03-10-2006 10:56 PM
Bought a 2nd SL Applefool S-Series Tech 25 02-23-2005 11:53 AM
