Old 06-11-2009, 10:20 AM   #1
Jhawk
Jhawk is on a distinguished road
Question New brake pads grinding
Hey guys. I just had the front and rear brakes replaced on my 2002 Saturn SL... the mechanic also resurfaced the rotors. I'm now hearing a pretty loud grinding coming from the brakes. The guys said the AC Delco metallic brake pads will make this grinding sound until they are broken in.
Is this true? The grinding is loud enough to turn heads when I pull up and brake.
Thanks for any advice.
Add to Jhawk's Reputation
Rate the quality of this post and help Jhawk reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Jhawk is offline   Reply With Quote
Old 06-11-2009, 10:36 AM   #2
DonP
Default Re: New brake pads grinding
http://www.saturnfans.com/forums/showthread.php?t=61513
for a discussion on the topic. IN my opinion, turning rotors is OK if there is enough material to do so and you are on a tight budget. At one time places like the now long gone Trak Auto "Super" stores would do it for free.
Add to DonP's Reputation
Old 06-12-2009, 09:53 PM   #3
rc1488
rc1488's Avatar
Unfortunately thats a rather old thread. More research has been done to determine how "warped" rotors occur.
OP You need to bed in your brakes. READ:
http://www.stoptech.com/tech_info/wp_bedinstock.shtml
A few medium speed stops will surfice in putting down an initial layer on the rotor.
Add to rc1488's Reputation
Old 06-14-2009, 03:04 AM   #4
bobbyrae
bobbyrae has a spectacular aura aboutbobbyrae has a spectacular aura about
1993 SL2
Roll Eyes Re: New brake pads grinding
If it's really a grinding noise, as opposed to a squeal or whine, I would say there is a problem. The only time I have heard grinding noises from disk brakes is when the pads were worn almost all the way down, one pad more worn than the other, causing a slight contact of the caliper to the rotor.
On another occasion, after having a front wheel bearing replaced, the backing plate had gotten slightly bent, causing a scraping noise when turning. I fixed this by poking a big screwdriver in there and bending it back!!!
Bobby Rae
Alameda, CA
1993 SL2 A/T, 80k miles, 22/33/43 mpg
1982 Accord 5-speed, 303k miles, 23/32/40 mpg
Add to bobbyrae's Reputation
Rate the quality of this post and help bobbyrae reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bobbyrae is offline   Reply With Quote
Old 06-14-2009, 09:24 AM   #5
velleguy73
velleguy73 is on a distinguished road
2001 SL
2002 SL
I gave up turning rotors about 10 years ago. I had the doorknob behind the parts counter tell me that my rotors were thick enough to turn. I agreed and re-installed my brakes. 500ish miles later, I heard some metalic grinding. The rotors could not dicipate the heat so there were radius cracks all over the surface. This generated so much heat that 2 of my brand new brake pads shatered.
If it were a truck, I would resurface the rotors. If it were factory rotors, I might try and resurface. If it was any over the counter aftermarket rotor, I'd pitch them and buy another set. My experience anyway.
Worth an inspection as posted above.
Add to velleguy73's Reputation
Rate the quality of this post and help velleguy73 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
velleguy73 is offline   Reply With Quote
Old 06-15-2009, 04:02 PM   #6
bobbyrae
1993 SL2
On one hand I have to agree that perhaps the aftermarket rotors are cheap and have a shorter life, but on the other hand, when I think about your story, it seems so hard to believe that taking about .001" off the rotor surface could lead to the over heating and cracking like that. The brakes worked just fine before that? I will keep this in mind!
Bobby Rae
Alameda, CA
Old 06-15-2009, 07:20 PM   #7
code1bob
code1bob is a jewel in the roughcode1bob is a jewel in the roughcode1bob is a jewel in the rough
code1bob's Avatar
1997 SL1
jhawk,
I had the same problem only 1 time, I used the most inexpensive type from Autozone and I had the loud grinding noise. I took them off tossed them in the garbage and replaced them with Raybestos ceramic pads. They are very quiet and produce less dust. If the noise doesn't go away soon go back to the mechanic and have him replace the pads.
Next time do the job yourself and save some money, brakes are not difficult to replace.
1997 SL1
5 speed manual
348,001 mi.+
Add to code1bob's Reputation
Rate the quality of this post and help code1bob reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
code1bob is offline   Reply With Quote
Inside brake pads worn worse than outside Pads Vue Daddy Vue Tech 7 10-27-2009 06:17 PM
grinding when braking, but not the brake pads TexasFireGuy S-Series Tech 3 08-06-2009 11:28 AM
ABS light, brakes grinding.. but pads and rotors look ok DJboozeAlot S-Series Tech 10 12-10-2006 01:18 PM
99 Sl2 brake grinding on new pads/rotors add2700 S-Series Tech 4 12-06-2006 07:07 PM
Brake grinding lc23112 L-Series General 13 06-02-2006 09:20 PM
