Old 06-05-2009, 03:24 PM   #1
brielle
brielle is on a distinguished road
Default air cond. fuel gauge and temp gauge not working. Help??
If anyone has any advice for me, I would appreciate it. My temp gauge, fuel gauge and air cond. (still blows, but not cold) all stopped working at the same time. The fuse is not blown. Does anyone have any idea what the problem could be??
Thanks
Add to brielle's Reputation
Rate the quality of this post and help brielle reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
brielle is offline   Reply With Quote
Old 06-05-2009, 03:38 PM   #2
Default Re: air cond. fuel gauge and temp gauge not working. Help??
Welcome to Saturnfans!
Mind telling us what you're driving (make, model, year), essential information like mileage, maintenance done, etc.?
Old 06-05-2009, 03:44 PM   #3
brielle
Oh sorry. I drive a 2003 L200. It has around 78,000 miles. The only maintenance I've done are oil changes as needed. Thanks
Old 06-05-2009, 04:57 PM   #4
The fuel level and a/c request signals go through the body control module (BCM, another computer) while the temperature signal comes from the engine control module (ECM, engine computer). I can't put my finger on anything because it seems to me three different problems and that doesn't make sense. I usually can answer some simple problems like a/c system, temperature or fuel signal issues but these three don't seem to have anything in common except the battery and ground connections. Perhaps another member can suggest a better diagnosis.
What's the condition of the battery (over 4yrs?) and voltage, and has it ever been tested or replaced? Free battery and alternator testing are available at Autozone and the large auto stores if necessary. Just call around.
Old 06-05-2009, 05:21 PM   #5
brielle
My husband had the battery tested @ AutoZone and they said the it was fine. Thanks for your answer.
Old 11-11-2009, 05:47 PM   #6
shamilto
shamilto is on a distinguished road
Did you ever resolve this problem? Or can anyone else share any advise? I have a 2001 L200, and am having the same problems.....fuel gauge, temp gauge, and odometer do not adjust/change/move while the car is running...they do move to their proper position/levels each time the car is restarted though.
I am also having the same trouble with the a/c, the blower works just not the conditioning of the air. I have tested the system itself and all seems to be in working condition...this leads me to believe that it is electronic. Also as in your case, they all seem to be tied together.
Any advise or insight is greatly appreciated.
Add to shamilto's Reputation
Rate the quality of this post and help shamilto reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
shamilto is offline   Reply With Quote
Old 11-28-2009, 05:32 PM   #7
WGBWGB62
WGBWGB62 is on a distinguished road
2001 L-Series 2.2L Sedan
I own a 2001 L100 and have almost the same problem. Temp gauge, odometer, and fuel gauge do not work. It all seemed to happen at the same time. Mileage reads about 86,000. The fuel and temp gauges were working every so often but less often now.
Add to WGBWGB62's Reputation
Rate the quality of this post and help WGBWGB62 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
WGBWGB62 is offline   Reply With Quote
Old 11-29-2009, 08:32 AM   #8
s3nfo
s3nfo's Avatar
2001 L-Series 3.0L Wagon
Well, as Fdryer said, this is a weird one. Fuel gauge and odometer are both BCM related and that's a normal and common failure mode. Temp gauge at the same time is uncommon and hard to figure out, temp gauge is not driven by BCM.
We need more information from someone who's actually figured out this failure mode.
Jerry N
Groucho Marx
Add to s3nfo's Reputation
Old 06-12-2012, 08:34 PM   #9
brogers
brogers is on a distinguished road
Did this get resolved? My AC, temp, and gas gauge all stopped working when I started my car after work the other day, came back on yesterday, and do not work again today. It is summer in Phoenix so... gotta get this fixed.
I have a 2003 L300 w/79k miles. I checked the fuse for the AC and it's fine. I switched it with the radio fuse to make sure.
Could it be some loose wire not getting a connection?
Add to brogers's Reputation
Rate the quality of this post and help brogers reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
brogers is offline   Reply With Quote
Old 08-24-2014, 06:12 PM   #10
SlimSaturn
SlimSaturn is on a distinguished road
Digging this thread up, I am having similar issues.
Temp/Fuel Gauge died, Security Light came on and DRL stay on even when the motor is off.
Add to SlimSaturn's Reputation
Rate the quality of this post and help SlimSaturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SlimSaturn is offline   Reply With Quote
Old 08-24-2014, 06:41 PM   #11
No assumptions are made so piggybacking onto an old thread may or may not help, especially when posters don't follow up with a conclusion.
It may help if you start a new thread, year, model, auto/manual, engine size, mileage, maintenance done and parts replaced to give a perspective of your car's state of health. Then describe symptoms.
Old 09-14-2016, 07:52 PM   #12
Crittercage
Crittercage is on a distinguished road
Hello! Did any of you get the issue resolved? I have an 2002 L200. When I start the car until it's turned off the gas and temp gauges needle out.. They started at the exact same time. Also my odometer is stuck at 67425, my change oil light keeps blinking( at won't turn off) during driving.. Every 1 minute of so my lights do out and come back on and everything seems to restart...- change oil blinks, security, airbags. Etc like the car has just been started! I just bought the car cheap then these started happening? I was a mechanic innthe Military.. But these things seem to all be connected electronically/computer... Any answers?
Add to Crittercage's Reputation
Rate the quality of this post and help Crittercage reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Crittercage is offline   Reply With Quote
Old 09-14-2016, 08:07 PM   #13
You've found a post among many where members simply leave their threads open without any resolution.
Try searching threads explaining the body control module (BCM) function. The background info will help as your descriptions may be pointing to the bcm. Loose/corroded connections are second and would be a cheap repair.
fuel and temp gauge failure WGBWGB62 L-Series General 3 06-22-2008 04:38 PM
temp gauge not working in sw1 saturn2wagon S-Series Tech 7 11-11-2005 12:32 AM
1992 SL2 Fuel Gauge / Temp BullyCanadian S-Series General 3 05-28-2005 01:11 AM
Fuel Gauge Stopped Working chris_92_sl2 S-Series Tech 1 04-16-2003 07:19 PM
Temp gauge not working bwcistheman1 Miscellaneous Tech 1 04-30-2001 10:31 PM
